Puzzled?!?!
Scottieparker
Hello folks. Hope you can help me out here:
What does it mean when the brake light is on but but parking brakes are released? My foot brake has a problem? But I just changed brake pads.
Advanced thks to all kind folks out there.
That you are stepping on the brake? [sly][laugh][laugh][laugh] To my little knowledge, the activation of parking brake has nothing to do with brake lights. It's sole activation is the foot brake so if it's on even if you are not pressing the footbrake, there's some electrical fault along the line. Get your mechanic to have a look.
Hi there,
a similar thing happened to me about a month ago..
mech readjusted the parking brake and accidently broke the screw (plastic) to the micro switch.
Din realise that brake lights (including 3rd brake light) were ON throughout until I returned from my work to find it staring brightly at me. That eventually depleted my batteries and it couldn't start my car.
I had to pull the fuse to the brake lights to allow some 'reserve' power back to the batteries.
A kind driver assisted to jump start the car and thereafter went to get the screw replaced.
Hope this situation fits your description to the problem. So long as the brakes still work and dun jam, you'll be alright. thumbsup.gif
Nothing to do wif your foot brake. does your car hv brake light sensor? i.e tells u when your brake light bulb is blown. could oso be a warning on low brake fluid. if it's neither of this, it's probably juz a wiring short circuit.
but his car is not that old, so most likely is that while replacing the brake pads, the caliper will be force open to fit the pads in (brake oil will over flow in reservior), then they will pump the brakes to move/sit the pads onto the rotor (brake oil may fall below the minimun level) wink.gifwink.gifwink.gif
or maybe tube got air and since they bled the brake lines, maybe some air got released and reservoir level went below the 'LOW' point.
yep.. good to check the brake fluid level.
Also maybe E-brake handle switch got stuck ?
don't think they'll bleed the brake line as they are only replacing the pads unless they are changing the brake oil sly.gifsly.gifsly.gif
