Guinness Neutral Newbie November 30, 2003 Share November 30, 2003 Hi guys, Just wanted to find out what does aircon servicing entail? Understand that they do some kinda chemical cleaning or something? Do they dismantle the various a/c parts to do this? Also, the compressor oil has to be topped up? Is adding that Buddy Club treatment thing similar? ↡ Advertisement Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie December 1, 2003 Share December 1, 2003 "what does aircon servicing entail?" Hi! there, Guinness, What the a/c w/shop would do is remove the cooling coil & condenser to clean with a cleaning agent. This does not include the compressor, as it'd be an o/haul. Parts that are not cleaned are the a/c ducts, unless you request it. Compressor oil must be refilled after re-install, once the other parts are removed, vacuum of the system too. While you're at it, replace the a/c belt at the same time. Rgds Paul Yong Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 1, 2003 Share December 1, 2003 You only add the Buddy Club Air Con Treatment after you have done all the air con servicing...................... Link to post Share on other sites More sharing options...
Audiorook Neutral Newbie December 2, 2003 Share December 2, 2003 How often do we need to do Air Con servicing? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 2, 2003 Share December 2, 2003 once a year or two.. Link to post Share on other sites More sharing options...
Phochem Neutral Newbie December 2, 2003 Share December 2, 2003 haha... bro, haven done mine since i got my car. siaozz.. must be full of dust. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 2, 2003 Share December 2, 2003 time to do liao.....but your aircon very cold leh... Link to post Share on other sites More sharing options...
Phochem Neutral Newbie December 2, 2003 Share December 2, 2003 ..aft BC lagi cold, esp in the morning driving to work. Link to post Share on other sites More sharing options...
Phochem Neutral Newbie December 2, 2003 Share December 2, 2003 must look for you again aft cleaning the a/c. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 2, 2003 Share December 2, 2003 in that case, save the money lah since the air con is so efficient.... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 2, 2003 Share December 2, 2003 ok... Link to post Share on other sites More sharing options...
Hannson Neutral Newbie July 10, 2006 Share July 10, 2006 (edited) Hi guys, Just wanted to find out what does aircon servicing entail? Understand that they do some kinda chemical cleaning or something? Do they dismantle the various a/c parts to do this? Also, the compressor oil has to be topped up? Is adding that Buddy Club treatment thing similar? 3 things that you need to note to ensure a healthy aircon system. 1. change your aircon pollen filter at least once a year (there are pollen, HEPA and activated carbon types.. take your pick) 2. check your refrigerant level yearly especially after the 2nd year. 3. decontaminate your aircon system either in a workshop or a DIY product like this http://www.cleanair.com.sg. If workshop, try not to go for: a. those who dismantle and manually clean and there's potential for physical damage b. those which use foam as this would become liquid to flush out the dirt.. imagine what happens if you have cracks in your aircon piping.. leakage into our electronics-filled cars are on very fun :) .. also none of the service centres which uses foam-based product will work on conti cars. Edited July 10, 2006 by Hannson Link to post Share on other sites More sharing options...
Lokech34 Clutched July 10, 2006 Share July 10, 2006 Hi there, Any good workshop servicing car air-con??? Thks Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 10, 2006 Share July 10, 2006 Hi Hannson. If u want to advertise your product, u must seek approval from the admin or moderators. Just letting u know otherwise they might delete your posts. Cheers Link to post Share on other sites More sharing options...
Adrianli Hypersonic July 18, 2006 Share July 18, 2006 My Sunny will be going for its 40K servicing on Sat. I spoke to the SE and was told many many fluids will be replaced and done except aircon servicing. My concern is here, I used to drive COE car n only did corrective maintenance. Now with tis Sunny, I would like to practise preventive maintenance as its coming to 2yrs old also. Reading thru all the aircon threads, I realise there is two school of advises. 1. To do aircon servicing every 2 yrs. 2. Do not touch the aircon at all. Spoilt then service. The SE quoted me S$1XX plus for the aircon servicing. There is no problem to the aircon at all so contemplating with this servicing. Moreover tis will be my last agent servicing and will service my sunny else where after tis. Therefore need to make use of the labour now if not next time kena cut throat prices. Please input ur advises b4 tis Sat. Thks. Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 18, 2006 Share July 18, 2006 Firstly is your Ac having any problems like air coming out is not cold, smell or less air coming out? If u dont have any problems, maybe just leave it. If u have those AC filter(Hepa etc) u might need to change it since it cud b quite clogged/dirty by now. U might also want to spray some Lysol up the front footwell near the firewall with the blower on full blast to get it into the cooling coil to disinfect it from mold & mildew or fungus. This will prevent bad smells & also clogging up. For the removal of the parts, I normally dont till there is serious problems cos if not properly replaced,u may have some leaks to the AC gas which will mean more repairs very soon. Check the receiver drier glass "window" if there r many bubbles when the AC is running cos it means you need to top up the gas. The quote of $100 plus by SE includes what? If only general cleaning, then it's quite expensive as u can do some spraying of Lysol for abt $5 a can only. I dont disturb the AC unless it's got problems & even then I only go to Markcool as their work is the best i've seen so far. Their prices also very reasonable compared to others. Markcool charged me $50 to strip the whole cooling coil & throughly wash including the blower Then fill up gas & compressor oil. Link to post Share on other sites More sharing options...
Adrianli Hypersonic July 18, 2006 Share July 18, 2006 Nope, aircon no problem at all. Juz thinking of preventive maintenance. Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 18, 2006 Share July 18, 2006 If it aint broke, dont fix it. ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Aircon Cabin Filter
Aircon Cabin Filter
Aircon oil renewal necessary?
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
