Soya Supersonic December 10, 2003 Share December 10, 2003 If wheel wobble is not noticible when on the balancing machine (balance 0:0) but vibrates when driving. Some say rim may be warped but how to tell? How do i know it's not the tyres instead? ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 10, 2003 Share December 10, 2003 in that case, it could be your suspension at fault...do an on-wheel balancing, it will eradicate the vibration... Link to post Share on other sites More sharing options...
Soya Supersonic December 10, 2003 Author Share December 10, 2003 Tried that, still vibrates. SM claims suspension is ok, fault is wif the rims since i deviated from their stock rims. Rims shop claims rim is ok, suspension faulty. Grrrr....damn frustrating Link to post Share on other sites More sharing options...
Chippz Neutral Newbie December 10, 2003 Share December 10, 2003 i had that problem too, mech did a high speed balancing for me, and it solved the problem. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 10, 2003 Share December 10, 2003 you tried on wheel balancing? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 10, 2003 Share December 10, 2003 How abt this?...try to swap with a fellow T4 a set of rims/tyres and try it and you will know whether it is the rims or the suspension at fault... Link to post Share on other sites More sharing options...
Raycsk Neutral Newbie December 16, 2003 Share December 16, 2003 If wheel wobble is not noticible when on the balancing machine (balance 0:0) but vibrates when driving. Some say rim may be warped but how to tell? How do i know it's not the tyres instead? When yopu bought them rims, they should come with precision rings specifically for your hub. This positions the rims exactly in the centre and ensures the rim sits correctly. If that is present then... Rotate your tyres from front to back and test for wobbling. If there is no wobbling, the the rim is suspected to be imbalanced/warped. Send to another tyre shop and check the rims (without tyre) for balance. Also, is the offset correct? Ray Link to post Share on other sites More sharing options...
Soya Supersonic December 16, 2003 Author Share December 16, 2003 remembered seeing them fit some rings to the rim. rotated and it got worse. had to re-rotated it back. the 40 offset is within the 37-44 range. do u think the tyres could be 'out-of-round'? Link to post Share on other sites More sharing options...
Smiley Neutral Newbie December 16, 2003 Share December 16, 2003 maybe you hv shaky hands ..... sorry bad joke. Link to post Share on other sites More sharing options...
Soya Supersonic December 16, 2003 Author Share December 16, 2003 remind me pop some ecstacy pills b4 i drive next time. Link to post Share on other sites More sharing options...
Smiley Neutral Newbie December 16, 2003 Share December 16, 2003 then not only shaky hands, shaky heads somemore. Link to post Share on other sites More sharing options...
Rs60 Neutral Newbie December 16, 2003 Share December 16, 2003 If wheel wobble is not noticible when on the balancing machine (balance 0:0) but vibrates when driving. Some say rim may be warped but how to tell? How do i know it's not the tyres instead? you got spacers issit? Link to post Share on other sites More sharing options...
Rs60 Neutral Newbie December 16, 2003 Share December 16, 2003 Tried that, still vibrates. SM claims suspension is ok, fault is wif the rims since i deviated from their stock rims. Rims shop claims rim is ok, suspension faulty. Grrrr....damn frustrating chey.. wat nonsense. thats wat manufacturers always say. once you don't use aftermarket products, it MUST be those faulty. Link to post Share on other sites More sharing options...
Soya Supersonic December 16, 2003 Author Share December 16, 2003 nope, din put spacers. Link to post Share on other sites More sharing options...
Rs60 Neutral Newbie December 16, 2003 Share December 16, 2003 so u mentioned wobbling is the steering wheel trembling issit? at high speed or any speed? Link to post Share on other sites More sharing options...
Arkaneslayer Neutral Newbie December 16, 2003 Share December 16, 2003 " remind me pop some ecstacy pills b4 i drive next time. " hand will be more shaky ... hhhhhhmmmmmmmmm if you have other purpose .... Link to post Share on other sites More sharing options...
Soya Supersonic December 16, 2003 Author Share December 16, 2003 above 110. now lessened oredi coz had SM fix something in the front. Link to post Share on other sites More sharing options...
Soya Supersonic December 16, 2003 Author Share December 16, 2003 wif the pills and my beng music pumpin' away, it'll be like zouk on 4 wheels!... ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre Rotation and balancing
How to tell if your coffee is good
Tyre puncture
Tyre puncture
Continental closing Alor Setar plant
