Sunnypatrick Neutral Newbie December 14, 2003 Share December 14, 2003 Hi, Recently installed a new power amp and component front speakers while the HU driving the back component speakers at AutoBac. The sound system is fitted with high quality shielded RCA from HU to power amp. Not sure about the cable from CD Changer to HU. I realised that the new setup is very sensitive to handphone interference. At times the static noise from the handphone reception could be heard from the front component speakers even when the sound system is turned off!! Occasionally, not sure if i notice correctly, i could heard the high pitch sound of the engine when the car accelerates...BEfore the upgrade i did not hear any of such noises. Anyone has similar experience? How to remove this? Will installing HVS helps to clean up the noises in the electrical system? ↡ Advertisement Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie December 15, 2003 Share December 15, 2003 Welcome to MCF Your 'aeroplane' sound is caused by improper installation due to the cables. Go back to the installer and get them to rectify your problem FOC Do join our weekly meetup at Bishan Link to post Share on other sites More sharing options...
Raycsk Neutral Newbie December 16, 2003 Share December 16, 2003 I think your amp's grounding is not too good. Contrary to many audio shops and buff, I think the negative terminal of the amp should be wired directly to the battery instead of the chasis. This optimises the amp's performance and minimises any magnetic flux or intefering frequencies. As for handphone frequency, I thionk there is nothin you can do about it. Heard that by adding a noise suppressing capacitor should help. Never tried it cause never really had this problem. My phone is placed on the windscreen to the right of the steering wheel. Link to post Share on other sites More sharing options...
Starlet Neutral Newbie December 16, 2003 Share December 16, 2003 Hi I also have the handphone interferance if i place my handphone near the headunit. Suggest placing the handphone away from the headunit or cables. cheers Link to post Share on other sites More sharing options...
Waipor Neutral Newbie December 16, 2003 Share December 16, 2003 agree with you, grounding the amps directly to the battery should help to optimize their performance, however, running the ground from the batter to the amp will expose the wires to more interference, thus increasing the risk of air-plane noise. wanted to ground my amps to the battery, got the cables and everything ready, but just too damn lazy, returned all the cables to put the idea till after CNY. Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie December 16, 2003 Share December 16, 2003 ever considered using shielded power cables? dunno if this helps Link to post Share on other sites More sharing options...
Waipor Neutral Newbie December 16, 2003 Share December 16, 2003 too lazy, but good ideal . hows your new "project" coming along? ready for audition? Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie December 16, 2003 Share December 16, 2003 Currently Stock, AudioCheck's system is Superb Grab him if can find him at the meetups Link to post Share on other sites More sharing options...
Waipor Neutral Newbie December 16, 2003 Share December 16, 2003 still STOCK ? been busy? my buddy just passed me a rockford 300 watt amp, intend to use it to power my subs but been too lazy lah. also something i'll put off till past chinese new year. did he change his ride too? Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie December 16, 2003 Share December 16, 2003 slowly, step by step Still collecting ideas for my install RF Power 300??? Very good and fine classic amp, i still got mine, semi retired it. Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie December 16, 2003 Share December 16, 2003 forgot to add, his ride still the same Link to post Share on other sites More sharing options...
Raycsk Neutral Newbie December 16, 2003 Share December 16, 2003 ever considered using shielded power cables?dunno if this helps Yah forgot to mention... shielded cables eliminate the possibility of interference. Also the positive and negative should not be laid side by side to further minimise this. Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie December 16, 2003 Share December 16, 2003 thanks for the tip so.... we need 4 cable paths? 1. +ve power cable 2. -ve power cable 3. Interconnect signal cables 4. Speaker cables Can mix any of these? ↡ Advertisement Link to post Share on other sites More sharing options...
Is Singapore Safe From Earthquakes ?
Favourite Japanese Songs from 1980-90s
Component speakers, no amp?
Yusheng from Singapore, Malaysia or China
How to trace owner from vehicle registration number?
Black flakes from washing machine
