Kardachia Neutral Newbie January 17, 2004 Share January 17, 2004 Is using normal water good enough or otherwise any brands to recommend? ↡ Advertisement Link to post Share on other sites More sharing options...
Bcyn Neutral Newbie January 17, 2004 Share January 17, 2004 what i actually heard is for every amount of coolant u pour in, u muz double it with water. so mixture should actually 1:2 respectively. in sg normal tap water will do but some car owners really go the distance and use pure distiled water instead. it is said that distiled water wont have impurities and will not corrode or rust the radiator walls. whatever it is remember, DO NOT use mineral water. Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 17, 2004 Share January 17, 2004 merc is a good brand. but i personally feel that distilled water is good enuff....the so called coolants more anti rust than cooling effects..... Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 17, 2004 Share January 17, 2004 it depends on what you buy. read the instructions first. Shell coolants are premixed so you need not mix with water anymore Link to post Share on other sites More sharing options...
Kardachia Neutral Newbie January 18, 2004 Author Share January 18, 2004 Thank you all for your info. appreciate it. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 19, 2004 Share January 19, 2004 Well, you do want some anit-rust properties, right? Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 19, 2004 Share January 19, 2004 yah lah....come to think of it, time to flush mine too Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 19, 2004 Share January 19, 2004 Er......isn't out tap water 'mineral' water too? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 19, 2004 Share January 19, 2004 DIY? BTW, are you working today? Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 19, 2004 Share January 19, 2004 i on leave till next week Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 19, 2004 Share January 19, 2004 What is your programme today? Lunch? Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 19, 2004 Share January 19, 2004 lunch? ok lah, give you a call later coz will be at pin liang with a friend Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 19, 2004 Share January 19, 2004 Wah lau......your life is pretty centered around your mistress lately. Your 1st wife no complain arh? Link to post Share on other sites More sharing options...
Super7 Turbocharged January 19, 2004 Share January 19, 2004 want to add mist spray to your engine anot??.... got lobang here... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 19, 2004 Share January 19, 2004 Don't think I need. At one time I was on a project to do a mist spray over the radiator. Even bought a motorised water pump together with water bag...........but it never got off the ground. And since I'm enlightened now, I can safely say 'I do not need this'! Link to post Share on other sites More sharing options...
Super7 Turbocharged January 19, 2004 Share January 19, 2004 my fren has the technologies and workshop for mist coz he product mist-fans for kopitiams etc Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 19, 2004 Share January 19, 2004 Yah, the project stalled becos we cannot get proper nozzles and lines. BTW, does it need high pressure to run the mist nozzle? You cannot have a big motor as it will take up space and add weight. Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 19, 2004 Share January 19, 2004 mix the coolant with water will do, ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Coolant question
Coolant question
Coolant level going down
