Johnchong Neutral Newbie April 23, 2004 Share April 23, 2004 Yesterday changed my front tires. But after tat the car seems to drift left slightly with the steering wheel centred. Also, i seem to feel excessive vibration of the steering wheel when goin at abt 110kmh. Anybody any ideas on the problem and wat to do? thanx ↡ Advertisement Link to post Share on other sites More sharing options...
Soya Supersonic April 23, 2004 Share April 23, 2004 need to do alignment & hv the shop high-speed balance it. but let the tyres scrub-in abt 300km first to settle down. Link to post Share on other sites More sharing options...
Orangie Neutral Newbie April 23, 2004 Share April 23, 2004 Have to do high speed balancing. Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie April 23, 2004 Author Share April 23, 2004 thanx for the info.. But where can i do the high speed balancing and alignment? Autobacs? And how much is it gonna cost? Those small tire shops cannot ar? cuz i'm gonna change my rear tires there anyway... btw, any views on the Dunlop LM 702??? Also thinking of Bridgestone Turanza... Link to post Share on other sites More sharing options...
Cheekg99 Neutral Newbie April 23, 2004 Share April 23, 2004 wow, sounds like ur car may overturn ... Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie April 23, 2004 Author Share April 23, 2004 hehe, rite... must go and lower ride height.. haha... Link to post Share on other sites More sharing options...
Virus 2nd Gear April 23, 2004 Share April 23, 2004 You can try Riverview Auto, at AMK. Check out their contact in Resource Folder. Contact Kenny. Link to post Share on other sites More sharing options...
Phochem Neutral Newbie April 23, 2004 Share April 23, 2004 thanx for the info.. But where can i do the high speed balancing and alignment? Autobacs? And how much is it gonna cost? Those small tire shops cannot ar? cuz i'm gonna change my rear tires there anyway... btw, any views on the Dunlop LM 702??? Also thinking of Bridgestone Turanza... As Virus have mentioned, give Riverview a call. Their service very pro. Kenny's the man to look for. Link to post Share on other sites More sharing options...
Guyver 1st Gear April 29, 2004 Share April 29, 2004 Yesterday changed my front tires. But after tat the car seems to drift left slightly with the steering wheel centred.Also, i seem to feel excessive vibration of the steering wheel when goin at abt 110kmh. Anybody any ideas on the problem and wat to do? thanx Think the shop that u bought the tyres from should do that for you... they took u for a ride... Link to post Share on other sites More sharing options...
Kytl68 Neutral Newbie May 2, 2004 Share May 2, 2004 Go to Malaysia if you need high-speed balancing (on-wheel) .. it will cost you alot lesser I think about RM$10-12 per tyre. For front set it will cost you about RM$20 .. Singapore easily S$30. Thatis if you are going to Malaysia anyway. Link to post Share on other sites More sharing options...
Orangie Neutral Newbie May 3, 2004 Share May 3, 2004 Dun go so fast lah Link to post Share on other sites More sharing options...
Orangie Neutral Newbie May 3, 2004 Share May 3, 2004 Thanks, will take note of that. I'm sure that will save me some $$ Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie May 3, 2004 Author Share May 3, 2004 ok, the tire shop balanced the wheels already. now the vibration at high speed is gone. But i still feel tat it drifts slightly to the left... Hmmm, can i do alignment at Kah Motors? Since I do servicing there anyway... Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 3, 2004 Share May 3, 2004 (edited) Not a serious problem, probably a slight adjustment on the toe will cut out the crab-like movement (technical term - tyre scuffing or side slip ) Edited May 3, 2004 by Yeobh Link to post Share on other sites More sharing options...
Goodspeed Clutched May 5, 2004 Share May 5, 2004 i have the SAME problem as you. the car Sway slightly left at high speed. went to Riverpt to align and even change the tie rod... still like that. braking at high speed worse sway, i service rear Brake to reduce the problem but still like that..HELP>?? suggestion anyone? Link to post Share on other sites More sharing options...
Spoon Neutral Newbie May 5, 2004 Share May 5, 2004 did u do anything to the car prior to having the problems?how old is ur ride btw? Link to post Share on other sites More sharing options...
Goodspeed Clutched May 5, 2004 Share May 5, 2004 i just change the tie rod because it is worn... the tires is also new one dunlop LM702 my ride is abt 6years old. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 5, 2004 Share May 5, 2004 Pulling to one side at high speed braking can be due to a) both front tyre are not of the same make and model b) both front tyres are at different stage of wear c) Loose tie rods, ball joints or front wheel bearings d) The diference in brake force of both front wheel is more than 10% ↡ Advertisement Link to post Share on other sites More sharing options...
Singpost courier dishonesty with incredibly lousy service
