Magfocus 5th Gear September 13, 2002 Share September 13, 2002 So it seems that most people have different tyres front and back.. ↡ Advertisement Link to post Share on other sites More sharing options...
RadX Moderator September 13, 2002 Share September 13, 2002 Yep, yep!!! Dun feel the diff tho, but if the threads are similar, then shld be ok. Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie September 13, 2002 Author Share September 13, 2002 Yeah like Mike said I think front and back different is ok but left and right different definitely not OK because then one side would have different traction levels. At the least this would cause the car to not track straight! Yah lor same situation as the rest, the rear still looked quite good so decided to let them stay, when they wear then I'll put the current Kumhos (if they're still ok) at the back and get new ones for the front. unless I bring the car to the track someday and they all get chewed up But I heard Sepang isn't as bad as PG which eats tyres.. Link to post Share on other sites More sharing options...
Magfocus 5th Gear September 13, 2002 Share September 13, 2002 Sounds logical enough.. So now if my two front Kumhos wear out, i would just shift the remaining 2 rears to either side and just get two for the other side Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie September 13, 2002 Author Share September 13, 2002 (edited) What's 7 flowers water may I ask? Where can I get it? Edited September 13, 2002 by Yttrium Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie September 13, 2002 Author Share September 13, 2002 Huh? Why do you want to do that? Link to post Share on other sites More sharing options...
RadX Moderator September 13, 2002 Share September 13, 2002 (edited) ......and why wud u want to do dat??? as in '.....7 flowers water.......' Corect me if I am wrong, think it has sth to do with washing away bad luck or sth! Normally mixed with Lime, etc Give the body a real good wash of 'bad' stuff! Edited September 13, 2002 by E46RadX Link to post Share on other sites More sharing options...
Magfocus 5th Gear September 13, 2002 Share September 13, 2002 Save some money J/K Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie September 13, 2002 Author Share September 13, 2002 Oooh.. OK then that I don't need Now I know what it is... Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie September 13, 2002 Author Share September 13, 2002 But then you'd end up with worn tyres on one side and new ones on the other? Same effect as using different tyres on each side leh... since one side is worn that side is gonna be less grippy.. esp in the wet since you have less thread left? Link to post Share on other sites More sharing options...
Magfocus 5th Gear September 13, 2002 Share September 13, 2002 I know i know, thats why i said i was J/k Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie September 13, 2002 Author Share September 13, 2002 didn't know you were joking... heh Link to post Share on other sites More sharing options...
Magfocus 5th Gear September 13, 2002 Share September 13, 2002 No worries, good point made though Link to post Share on other sites More sharing options...
Sky8807 1st Gear September 13, 2002 Share September 13, 2002 Don't know whether they sell Kumho tyres, but michelin, sure have. They also sell battery and sport rims. Shop name : Southern Tyre Co Contact : 67643708 Link to post Share on other sites More sharing options...
Sky8807 1st Gear September 13, 2002 Share September 13, 2002 Imagine the front wheel is rotating smoothly and the rear wheel is shaky from the view of the other driver. The driver of the car might not noticed it because the whobbly rear might not transmit to the steering wheel, so you don't know. If you are a sensitive driver, you might notice something not right, like noise, cornering ability and high speed handling defeciency. If you find that your tyres especially rear one is unevenly worn, it might be too late, suspension, wheel bearing and related component is worn out faster due to unbalance tyres. If the tyre shop tell you that the rear wheel balance is not important, then I suggest that you not go again. Link to post Share on other sites More sharing options...
Sky8807 1st Gear September 13, 2002 Share September 13, 2002 If the other guy driving the same car balance the tyres normally and do not have any vibration, why should you pay extra and do high speed balancing? Think about it. IMO those who do high speed balance in-situ are those car that have some problems and need this kind of balancing to correct it. Something is amiss and a well balance tyres still vibrate the steering might means the steering system worn or the wheel is bad or poorly build and during rotation can't rotate on its centre axis. Millions of car runs at speed without vibration and do not do a high speed balancing, it indicates normal wheel balancing and a sound suspension and wheel system is sufficient for driving a high speed. Should not waste money, unless necessary. Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie September 13, 2002 Share September 13, 2002 "you have your fantastic suspension system to help you" Hi! there, Magfocus, There's the advantage that I have which will drive alot of people crazy, when it comes to choosing tyres. It let me setup my ride without worrying about the car's handling. So, I put a wet-biased type of tyre in front & a dry one behind. When it's time to change tyres, it's usually the front ones that are changed a second time before the rear ones. Rgds Paul Yong Link to post Share on other sites More sharing options...
Yttrium Neutral Newbie September 13, 2002 Author Share September 13, 2002 I agree on not wasting money unless necessary. That's why I would only do it as a last resort. Anyway I don't think there's anything wrong with my suspension, steering etc.. since the vibration only happens at a particular speed. Which I think happens to be the natural frequency of the wheels... ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre Rotation and balancing
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Wheel Hubs
Wheel Hubs
Paddle shifters - fixed to wheel or column?
Wheel spacers - the real truth...
