Undercarriage Lights
Aceveo
Need help to know where can I install the undercarriage lights. Actually just want to install light at the bottom of the rear bumper and be connected to the reverse gear. It is meant for easy parking for my wife. Would like to know will it be very ex.(more than $50).
Thanks
Rightfully, its illegal to fit these undercarriage lightings. jus be sure to remove it before inspection.
Depending on the size/length of ur light tube, should cost more then 50 with installations. tink most car audio shop should have them. smile.gif
Edited by Phochem
Undercarriage light won't give much brightest toward the rear view, only to the bottom. You might as well fix a spotlight near the rear screenpanel (similar to 3rd stop light), and only switch on when necessary instead of connected to reverse gear. nod.gif
As least inspection won't question about it.
Thanks for the info. Will look ard a few audio shop. Basically, just need lights at the bottom so that my wife will not hit the kerb and for her to see the lot divider. She is a bit poor in judgement.
