Pizza Neutral Newbie May 25, 2004 Share May 25, 2004 Do u all warmup ur car when the engine is cold? Any pros or cons to warmup ur engine? ↡ Advertisement Link to post Share on other sites More sharing options...
RadX Moderator May 25, 2004 Share May 25, 2004 Do u all warmup ur car when the engine is cold? Any pros or cons to warmup ur engine? Most modern engines do not need the warming up of the engine. Just crank and drive off. In fact, stationary and letting the engine warm up can do more harm as it creates carbon-build up. Just remember, go gentle when you drive off and dun over-rev or hit high RPMs when the engine is still cold as it may shorten ur engine life. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 25, 2004 Share May 25, 2004 Once the oil pressure is up, you get start moving. Link to post Share on other sites More sharing options...
Assassin Clutched May 25, 2004 Share May 25, 2004 Hi Pizza, Welcome to MCF ! Do enjoy your stay here and come along for our weekly meetups. More details in the MEETUPS folder. For other automotive and contacts info, do check out the RESOURCES folder and the TIPS & TECHNICAL RESOURCES folder. You cans tart driving off once u start the engine, however, do make sure the engine has sufficiently warmed up before you start revving it. Cheers Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear May 25, 2004 Share May 25, 2004 Unless you are driving a vintage car that requires warming up cos cold engine will stall...there is no need to warmup your engine. Drive off after you have start your engine. This will allow the engine oils to circulate to parts of the engine rather than letting the oil stays at the oil sump. Try not to switch on your aircon until the engine has reach optimum temp....this is to reduce the load on a cold engine. For a normal engine, it would take around 1km of driving to get it up to the require temp. Link to post Share on other sites More sharing options...
Ah_veo Neutral Newbie May 25, 2004 Share May 25, 2004 yessss!! learnt another new thing abt car today!!! after on engine, i always sit inside car for abt 1min. duno how many 1mins i've wasted liao. kekeke..... thot muz let the engine oil to get into engine first before i move off. damn i was wrong. Link to post Share on other sites More sharing options...
BoneStock 5th Gear May 25, 2004 Share May 25, 2004 Do u all warmup ur car when the engine is cold? Any pros or cons to warmup ur engine? don't need to warm up but if you want can let the engine run for a while...say 30 to 60sec to let the engine oil circulate to the top of the engine to lub the moving parts there. as for me, it's start and go most of the time ↡ Advertisement Link to post Share on other sites More sharing options...
