Danapj Clutched July 10, 2004 Share July 10, 2004 Hi What is the difference between IK16 and IKH16? Which car are you driving? How long can it last? ↡ Advertisement Link to post Share on other sites More sharing options...
Wykh Neutral Newbie July 11, 2004 Share July 11, 2004 The diff is in the length of the Spark Plug, I think in general Toyota uses IK series and newer Nissan use IKH series. I am driving a Nissan Primera p12. Local context, anything from 20K to 100K. Don't know who to believe. Note: Denso do not put a value on their box, when to change Ir Plugs. However, at their US site DENSO advises replacement after 30,000 miles (approx. 48,000km) You can go to their US site for more info. http://www.densoiridium.com/faq.php Link to post Share on other sites More sharing options...
Darkness Neutral Newbie July 11, 2004 Share July 11, 2004 wat my mech told me was even if i use better spark plugs, the improvement will be very marginal to be felt...also it will be better only during the first few thousand KMs.... so in other words use normal sparks and change every 10/20 k the best Link to post Share on other sites More sharing options...
Hoppe Clutched July 13, 2004 Share July 13, 2004 is it better to get cheap copper plugs, change them every month or... get those expensive ones? Link to post Share on other sites More sharing options...
Darkness Neutral Newbie July 13, 2004 Share July 13, 2004 no need to get cheap ones...but just get OEM ones for ur car...should be quite cheap still....then change it every 20 k but where spark plug cables are concerened i have never changed this b4 so cannot comment Link to post Share on other sites More sharing options...
Bryanho Neutral Newbie July 13, 2004 Author Share July 13, 2004 So far, I'm on copper plugs.. on hind sight.. maybe I'll just change them over the course of 10,000km... . My ride is virtually showroom speced(not condition-I got no GLARE, TOUGH SEAL etc ), even the "upgrade" of rim size is approved by Borneo.. Link to post Share on other sites More sharing options...
Bryanho Neutral Newbie July 13, 2004 Author Share July 13, 2004 I don't know if this is the best... but I'm doing that for my ride.. it seems to be doing okay..... The only thing I'll do is switch between OEM brands of NGK and Denso. Even ferrari's OEM plugs are platinums and not iridiums, but if they're true performance enthusiasts.. most likely, it would be upgraded to iridium. I'll just an everyday urban driver. Link to post Share on other sites More sharing options...
Kytl68 Neutral Newbie July 15, 2004 Share July 15, 2004 Bro, you should try the Denso SK series plugs next time ... I am on it now ... quite good ... it has iridium 0.7mm tip and platinium coated ground ... just found out it can last 100,000km Link to post Share on other sites More sharing options...
Shoi Neutral Newbie July 16, 2004 Share July 16, 2004 (edited) where can i get it? i called ric-tat do not have SK16R-P11 series leh. Edited July 16, 2004 by Shoi Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 17, 2004 Share July 17, 2004 im using the iridium plugs for my car...its good,but it will also cost a bomb... it depends on the type & where you get it from Denso IK16/20 are @ $63 for a pack of 4 Link to post Share on other sites More sharing options...
Goffy3 Neutral Newbie July 17, 2004 Share July 17, 2004 Hi Vtim IK20 buy from u is it? Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 17, 2004 Share July 17, 2004 Bro, you should try the Denso SK series plugs next time ... I am on it now ... quite good ... it has iridium 0.7mm tip and platinium coated ground ... just found out it can last 100,000km with our Start-Stop driving traffic, I think 60~70k km will be a good time to check them & see if they need to be change, instead of 100k km, IMO Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 17, 2004 Share July 17, 2004 shhhhh..... I'll PM you because of this http://www.mycarforum.com/forum/gforum.cgi...t=177279#177279 Link to post Share on other sites More sharing options...
Dirtrider_ak Neutral Newbie December 11, 2005 Share December 11, 2005 I don't know if this is the best... but I'm doing that for my ride.. it seems to be doing okay..... The only thing I'll do is switch between OEM brands of NGK and Denso. Even ferrari's OEM plugs are platinums and not iridiums, but if they're true performance enthusiasts.. most likely, it would be upgraded to iridium. I'll just an everyday urban driver. As long car starts y change spark plugs? Waste money! When they dun produce spark is when you replace them. That means spark plug is dead or gap too wide. All you need is to clean and regap. I have driven for so long with oem spark plugs no issues except it rust at the thread? wd40 an waola! clean it and apply high temp grease can liao. back in service. Kenna con by marketing! Anyway the only spark plug that actually shorted to ground are only on 2 strokes engine when there is too much 2T or it is flooded by petrol. If a 4 stroke engine does that it is time to send it to the grave! LOL Link to post Share on other sites More sharing options...
Newsunny Neutral Newbie December 12, 2005 Share December 12, 2005 Hi bro vtim, You have lobang for NGK LFR5AGP plugs? (26.5mm reach type, replacement for LFR5A-11) If so, how much for set of 4? Thanks a lot for your help. Link to post Share on other sites More sharing options...
Willwill Neutral Newbie December 17, 2005 Share December 17, 2005 hi guys, anybody know where to get bosch super 4 plugs? Link to post Share on other sites More sharing options...
Genie47 1st Gear December 17, 2005 Share December 17, 2005 Not all cars can use the Super 4. Unless you have used them before, don't change to them. Marketing BS. Use regular plugs the best but if you can get platinum plugs at regular plug price, get them else, stick to regular copper plugs. Link to post Share on other sites More sharing options...
Blitzza Neutral Newbie December 17, 2005 Share December 17, 2005 New LEXUS IS350 need 12pcs separk plug V6 engine, double injector + double separk plug. ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Tool to change Spark Plug
Plug-and-play vaccine
Spark Car Care
Spark Car Care
Class 2 Bike Choices
Aftermarket vs. OEM Spark Plug Wires
Replace spark plugs
Replace spark plugs
Denso Iridium Spark Plug (IK20)
