Car-Inspection-Related grounding.
Ravinged
Hi folks,
I don't know what I am typing up there in the topic [laugh][laugh][laugh] ... but anyway, here's my query.
I read from hardwarezone that there has been many cases of cars failing inspection due to grounding items under the bonnet, and this is something which I actually did not think about all these while.
What can we say about stuffs like grounding? Or even voltage stabiliser that comes with grounding cables as well? Are this "pass-able" for inspection?
Ed
The two main guidelines in formating the bi-annual inspection checks is a) safety & b) pollution
Unless grounding and voltage stabiliser can caused sudden engine lost of power while the car is in motion - then it is considered an undesirable/unsafe add-on components. Under road safety rules, the inspection centres can insist you remove the add-on components.
Edited by Yeobh
So being LTA-compliant doesn't necessarily mean it is "pass-able" during inspections? Absurb isn't it?
Ed
LTA compliant who say one first....if said by the shop...they will even tell you that George Bush Jr. limo also uses it...so no count. Only LTA says compliant then got count...even then you must follow their installation guideline.
I was reading hardwarezone.com ... the auto forum ... and one of the forumner there actually said one of his friends failed inspection due to grounding. [confused]
Ed
confirm anyhow sian.... jus went for my inspection.unimpressed.gif i'm 8points grounded.... wink.gif then they saw something blinking near my batt, they said" si mi lai eh" and i replied "HVS"..... laugh.gif all this items confirm can pass inspection. nod.gifthumbsup.gif
Edited by Phochem
That's good! I'm thinking of going HVS upgrade ... butt itchy liao now that the oil leak and lousy clutch is a thing of the past. [laugh]
What do you think of the Pivot Voltage Stabiliser? Any good? Heard stories from both side, undecided at the moment.
Ed
Haha... I have 13 point grounding. Alway passed my annual inspection few months ago.
Maybe the grounding work was like sxxt. Wire goes all around the engine, that's why can failed. [dead]
That's why I mean. Anyhow lay the cable. Maybe must asked to take a picture of that grounding work and see how bad it is. [laugh]
don't need. I myself is already a guru. most importantly, the grounding cable must not lay across the engine top and must not be hanging freely. And all point to point must be secure properly.
