Andrewkb Neutral Newbie October 10, 2002 Share October 10, 2002 Hi Guys, The Stream brake is pretty weak especially when depressed all the way down. Some Japanese Stream Owners placed a metal plate in front of the Master Brake Cylinder to stop the Master Brake Cylinder from protruding out. It can be seen at this website: http://www28.tok2.com/home/streamcar/sub27.htm (P.S: Use http://world.altavista.com to translate ... gotta copy and paste the text). However, the article did mentioned about potential damage to the Master Brake Cylinder ! It was also mentioned that new batches of Stream had this piece of metal installed. Need to seek you guys comments on whether this is feasible at all ! Thanks in advance ↡ Advertisement Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie October 11, 2002 Share October 11, 2002 Change to steel braided hose, slotted rotors and semi-metallic pads.........sure stop better. If still not enough, a 4-pot caliper and larger rotors should do the trick. Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie October 11, 2002 Share October 11, 2002 The steel braided hose is a good investment. It gives me a more assured feel..... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie October 11, 2002 Share October 11, 2002 Ahhhhh........almost forgot you've changed yours recently. Managed to get them to change the fluid to DOT 5.1 as well? Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie October 11, 2002 Author Share October 11, 2002 Any place to recommend me to go for Steel Braided hoses and roughly how much does it cost ? Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie October 11, 2002 Share October 11, 2002 Hmmmm..... tricky issue. I called them after you called me that day. They told me they have the DOT 5.1 fluid and will replace for me. When I reached there, I asked them what brand of DOT 5.1 did they use? They told me some brand (which I dun remember). But when I asked to see the bottles, they told me throw away liow. So can tell me how to tell whether the fluid is DOT 5.1? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie October 11, 2002 Share October 11, 2002 I'm using Sparco for my babe and it costs me $240 for the whole set, excluding installation. You've gotta find one that fits your car. Alternatively, you can do what Mondeo and Sparetyre did and save a lot of legwork! They have it custom-made at Autofix, I think. They use Goodrich steel braided hose and custom make to fit in your car. Simple really, it's just the length and connectors............. Quite competitively priced too. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie October 11, 2002 Share October 11, 2002 Sounds fishy, very fishy! It is very unlikely they have only 1 or 2 bottles left and has used them all for your car. Throw away the bottles? C'mon! Don't tell me they use until 'jun-jun' when filling up the resevoir. Problem is, you can never check just by eyeballing. Well, nvm, just buy a DOT 5.1 and change it the next time you flush your hoses, like 20000km down the road................ There's also a problem of what fluid to top up if the level drops. Pray it don't drop too much! Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie October 11, 2002 Share October 11, 2002 Anyway, I rest my case. Maybe will buy from Mr Lu and bring down to C&C during next service. Will try to see whether they can do it for free......I mean "goodwill".... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie October 11, 2002 Share October 11, 2002 Once you have changed your fluid with DOT 5.1, it is of utmost IMPORTANCE for you to stick a label "USE DOT 5.1 FLUID ONLY". Those helpful mechanic may fill it with DOT 4 otherwise. Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie October 11, 2002 Share October 11, 2002 Thanks for the advise. Maybe I should assume that they have changed it to DOT 5.1 and place the label now. Just in case...... Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie October 11, 2002 Share October 11, 2002 And ensure the ".1" still there too, otherwise DOT 5 ......... Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie October 11, 2002 Share October 11, 2002 U still have 'Goodwill' at C&C meh, u demander. Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie October 11, 2002 Share October 11, 2002 Hmmmm...... actually they quite scared of me..... Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie October 11, 2002 Share October 11, 2002 (edited) Then call me go down together, I want to test drive if they scare of U I watched last night BBC's TopGear that the driver spinned the TVR almost 6 round 360degree, so I want to see whether the AMG Benz also can do this. Edited October 11, 2002 by Mondeo Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie October 11, 2002 Share October 11, 2002 hahahaha Then I better not go with you...... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie October 11, 2002 Share October 11, 2002 DOT 5 even more 'jialat'. Maybe you can see an actual separation of fluid!!!! Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie October 11, 2002 Share October 11, 2002 They've even tried this on two Focus auto, but only one round~ still work! ↡ Advertisement Link to post Share on other sites More sharing options...
Another Kungfu actor/master pass away
Malaysian airline plane goes missing! MH370
Singaporean woman goes missing in Spain, family appeals for information
Anyone missing a car plate?
Ferrari 12Cilindri
Ferrari 12Cilindri
New stations, line extensions planned for Singapore’s MRT
Pets' Lost and Found
