Arah Neutral Newbie August 25, 2004 Share August 25, 2004 Not bad the setup but quite excessive use of the cables but for $50 bucks installation & cable inclusive a reasonable price. Too bad we are all here to do DIY, maybe the cost would be higher but the knowledge & friendship gain "priceless". ↡ Advertisement Link to post Share on other sites More sharing options...
Acemundo Supercharged August 25, 2004 Share August 25, 2004 maybe u can provide his contact so any bros interested can contact him. Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 25, 2004 Author Share August 25, 2004 bro, take a pic of your setup and post here for all to see lah. i think the workmanship quite neat for yours Link to post Share on other sites More sharing options...
Reliable Clutched August 25, 2004 Share August 25, 2004 I prefer to DIY too. like to do everything on my own for my car if possible. hehe saw alot of ppl overseas do their own servicing, change parts, tuning etc. quite nice. Its a good learning experience. waiting for the workshop to start and meeting up with u all Link to post Share on other sites More sharing options...
Reliable Clutched August 25, 2004 Share August 25, 2004 if u all want the contact number can get from this url. http://page.auctions.shopping.yahoo.com/sg/auction/84922584 He post it at yahoo auctions. Link to post Share on other sites More sharing options...
Ah_veo Neutral Newbie August 25, 2004 Share August 25, 2004 brudder, maybe you can organise a 'group grounding installation'. more ppl do cheaper mah. maybe $35-$40 nia. worksmanship very neat. see oredy oso shiok. Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 26, 2004 Author Share August 26, 2004 mass quite difficult, cos each car needs about 1.5hrs to do leh. if 10 cars turned up... the mechnic must work from morning to nite liao Link to post Share on other sites More sharing options...
Seaweed 1st Gear August 26, 2004 Share August 26, 2004 how come each car need 1.5hrs ??? don't think need so long especially if all same car....he can prepare the wire first....so just fix very fast 1....think can be done in 15mins.... Link to post Share on other sites More sharing options...
Seaweed 1st Gear August 26, 2004 Share August 26, 2004 humm...it's simple...just like i say...grounding is easy...difficult is to ground the best pt.... Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 26, 2004 Author Share August 26, 2004 ic ic. so those who told me 1.5hrs mech. are probably unfamiliar with aveo... then better dont go to them liao Link to post Share on other sites More sharing options...
Seaweed 1st Gear August 26, 2004 Share August 26, 2004 (edited) 1.5hr...probably for you to see where to ground....cut the wire...crimp the wire...everything...if wire all cut to right lenght and crimp...installation is easy...put the adaptor on the bat negative and install the cable one by one...after that secure them properly using cable tight can liao lor... anyway...i see if I got time to get the cable everything ready...if can then i will ground mine on sat morning.... Edited August 26, 2004 by Seaweed Link to post Share on other sites More sharing options...
Arah Neutral Newbie August 26, 2004 Share August 26, 2004 Bro, how to prepare the wires first...cause each with different lenght. If he uses all the same lenght then its a waste of resources and wont be tidy. Fixing the wires plus lubing the srews and fastening the cable ties would take at least 30-45min for 5 points IMO. Never seen one done in 15mins....wow must learn from him, his systematic approach of fixing the wires man. Link to post Share on other sites More sharing options...
Seaweed 1st Gear August 26, 2004 Share August 26, 2004 15 min is assuming you know exactly where to ground....have done it before on same car...with all wire cut to lenght etc.... for me...I will buy the cable then measure the lenght needed first...then slowly go home cut the wire...crimp it...put some solder...under the nice aircondition...ha ha ha...then after that it's just putting the wire into their respective location....but one problem i have now...i need a screw for a certain pt...but i don't know the size...ha ha ha Link to post Share on other sites More sharing options...
Reliable Clutched August 26, 2004 Share August 26, 2004 hopefully got ppl know where to ground for my car. old carbreutor car. Link to post Share on other sites More sharing options...
Kopikao Neutral Newbie August 26, 2004 Share August 26, 2004 Is this the alternator which one of the grounding should go? sorry... dunno about car parts... Link to post Share on other sites More sharing options...
Seaweed 1st Gear August 26, 2004 Share August 26, 2004 pal..this is your aircon....don't play play...don't try to run your light blub here...hee hee Just joking...the alternate very easier to tell...you see inside got coil of wire 1... Link to post Share on other sites More sharing options...
Seaweed 1st Gear August 26, 2004 Share August 26, 2004 (edited) the RX7 your car ?? it's a rx7 right ?? i not very good at recognizing car... Edited August 26, 2004 by Seaweed Link to post Share on other sites More sharing options...
Ah_veo Neutral Newbie August 26, 2004 Share August 26, 2004 mass quite difficult, cos each car needs about 1.5hrs to do leh. if 10 cars turned up... the mechnic must work from morning to nite liao then gota Staggard timing liao. machiam army....Alpha & Bravo eat b/f first. Charlie & Delta draw arms. ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended workshop with reasonable labour charges?
Meetup this saturday for traditional 0808
Workshop for simple jobs
