Trex101 3rd Gear October 12, 2004 Share October 12, 2004 Hey, I did this cylinder de-carbonizing today and wow it really works. Engine was smoother and when accelerating, the first 3 gears were pulling really strong. Basically its a really easy and cheap maintenances to DIY. WARNING: Do not stick the whole hose down and suck up the water too fast, you will blow your engine. For further infor how to do it pls look into this link provided by one of bobistheoilguy forumer. http://www.automotiveforums.com/vbulletin/...ad.php?t=283211 ↡ Advertisement Link to post Share on other sites More sharing options...
Genie47 1st Gear October 12, 2004 Share October 12, 2004 So what did you use? My bro had this wild idea of using the Karcher steam cleaner with have and blow high pressure steam mist into the TB or something. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie October 12, 2004 Share October 12, 2004 How much water did you use? Should be lesser than the 1.7l they use, right? Link to post Share on other sites More sharing options...
Genie47 1st Gear October 12, 2004 Share October 12, 2004 Looking at the video. Each round is about 1 cup. So have to repeat untill all the 1.7L of water is gone. Link to post Share on other sites More sharing options...
Genie47 1st Gear October 12, 2004 Share October 12, 2004 You want some 18-Megaohm wate I have? Link to post Share on other sites More sharing options...
Trex101 3rd Gear October 13, 2004 Author Share October 13, 2004 (edited) I use abt 3 oz acetone mix with 250ml of water. btw, i tried to spray the mixture through the TB but the noise level of the TB is too loud, even at 1/3 throttle open. So i use the hose from the brake line to intake TB, good vacuum but got to do it nice and slow.. Edited October 13, 2004 by Trex101 Link to post Share on other sites More sharing options...
Trex101 3rd Gear October 13, 2004 Author Share October 13, 2004 what's this 18-Megaohm wate? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie October 13, 2004 Share October 13, 2004 bring it on... Link to post Share on other sites More sharing options...
Genie47 1st Gear October 13, 2004 Share October 13, 2004 Ultra pure ion free water. Link to post Share on other sites More sharing options...
Trex101 3rd Gear October 13, 2004 Author Share October 13, 2004 oic, but i think that by adding some sort of solvent may aid in the cleaning process so i add some acetone. Maybe next time, i try using 500ml of water with 12oz of acetone. Link to post Share on other sites More sharing options...
Ahboy88 Neutral Newbie October 15, 2004 Share October 15, 2004 Hi, saw the video clip but can tell me exactly which pvc line? Me driving ek4. Tks.. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 15, 2004 Share October 15, 2004 Make sure all the water is out of the cylinders. As especially for interference engine configuration, presence of water can cause hydraulic lock resulting in serious damage to valves, con-rod etc. Water will tend to reduce and dilute the amount of oil coating on the cylinder walls. Too much washing will cause cylinder walls and pistons to have metal-to-metal contact - the consequence is loss of compression resulting in loss of HP. Link to post Share on other sites More sharing options...
Trex101 3rd Gear October 15, 2004 Author Share October 15, 2004 Actually no need specific pvc line, any vacuum line towards your TB will do. Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie October 21, 2007 Share October 21, 2007 thanks bro for 'feeding' my ride water today and boy oh boy, did we smoke steam the premise! this water decarbon is really something good maintenance esp for old and high mileage like my Presea. the aftermath is really as u stated smooth acceleration have to drive with care now and not be 'throttle happy' thanks again! ↡ Advertisement Link to post Share on other sites More sharing options...
Ferrari 12Cilindri
Ferrari 12Cilindri
