Spinner Neutral Newbie March 19, 2002 Share March 19, 2002 A novice qn: My pal says that changing the exhaust box at the tail is a total waste or money. I think he is refering to changing it to something like Hotbits etc. What he meant is that the ROV will never pass such a change during the inspection. What he adviced is to get the exhaust shop to open up the existing exhaust box (is that the right term?) and remove all those wires and gauzes in there so that the restricted flows are rectified. He said you end up having a original "looking" exhaust without running risks of ROV inspection failure. Can anyone confirm these "words of wisdom"? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie March 19, 2002 Share March 19, 2002 Hi! there, Spinner, For inspection, as long as there're no labels, brand name, etc., and your tail-pipe is original looking, without chrome, DTM styled, big diameter ends, it should pass the inspection. A straight-through exhaust system with a DTM tailpipe failed an inspection. After cutting off the tailpipe and welded a normal tube, it passed, even though the tail doesn't have much use other than looking nice. Rgds Paul Yong Link to post Share on other sites More sharing options...
Watzup Neutral Newbie March 19, 2002 Share March 19, 2002 heard that superdynamics mufflers made in thailand one, true???? a bit fishy Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 19, 2002 Share March 19, 2002 I tot SD from Taiwan.....hummmm......perhaps Vietnam? Link to post Share on other sites More sharing options...
Spinner Neutral Newbie March 19, 2002 Share March 19, 2002 Tks Paul for ur kind comments! BTW , what is DTM? Hi! there, Spinner, For inspection, as long as there're no labels, brand name, etc., and your tail-pipe is original looking, without chrome, DTM styled, big diameter ends, it should pass the inspection. A straight-through exhaust system with a DTM tailpipe failed an inspection. After cutting off the tailpipe and welded a normal tube, it passed, even though the tail doesn't have much use other than looking nice. Rgds Paul Yong Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie March 19, 2002 Share March 19, 2002 Hi! there, Spinner, DTM is the German Touring races, the tailpipes angled upwards, like in your face, when the flames come out of it. Rgds Paul Yong Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie March 19, 2002 Share March 19, 2002 Paul, Any name for those twin tailpipes angled downwards like my mondy?! Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie March 19, 2002 Share March 19, 2002 Hi! there, Mondeo, When I see your car on Sat., or Mon., I'd sift through my memory to see whether they've already name it. ???Exhaust heat spitting for road drying to assist driver behind to wrestle their car between wet and dry lines??? Rgds Paul Yong Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie March 19, 2002 Share March 19, 2002 Actually, whole car heats run under the car as they claimed new design , on the otherhand ---bloody hot. Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie March 19, 2002 Share March 19, 2002 Hi! there, Mondeo, Stick your head over my car when I pop the bonnet, very good for cold climate, and it's only the engine, as the rest of the drivetrain is behind, under the car. Rgds Paul Yong Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie March 19, 2002 Share March 19, 2002 Try it on meet-up, but not me time to bed man.. Link to post Share on other sites More sharing options...
MkIIToledo Neutral Newbie March 20, 2002 Share March 20, 2002 heard that superdynamics mufflers made in thailand one, true???? a bit fishy Yup, went to Man Exhaust to fit muffler. And Aman sayz SD is from Thailand!! He temporary fitted the SD for me to try. Warrao, fibre glass (used for sound damping inside) was flying out as I rev man!! Scared of the fishy quality man!! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 20, 2002 Share March 20, 2002 UTM???? Link to post Share on other sites More sharing options...
MkIIToledo Neutral Newbie March 20, 2002 Share March 20, 2002 Help is urgently needed Recently installed a high flow muffler to my Xsara. The result was not to my expectations. Low end torque almost gone. Previously my Xsara was pretty responsive at low rev as peak torque arrived at 3000rpm. After the installation, can see the rpm needle taking its own sweet time to climb the rev range. Only after ard 4K rpm do I see an surge in the rate of increase (putting a smile back into my face). But anyway, conti cars are not high revving machines and the SG driving conditions seldom need me to rev beyond 3K on normal days. Even my wife can feel the diff (she though I was saving fuel after the recent price hike . Any ideas (short of swapping back my stock muffler, luckily kaisu and ask to keep it) of improving the situation. Have not change the cat yet though (waiting for so good stuff to come in from overseas [angelic] TL Hi TL, Like you I fitted panel K&N filter, aftermarket muffler done too. But I did not loose my low end much. Only diff from you was that I got a straight-thru Hotbits instead. BTW, where did you get it done? Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie March 20, 2002 Share March 20, 2002 Hi Torquelover, How is yr babe now? Is the sound loud after installation? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 20, 2002 Share March 20, 2002 I fitted a Super Dynamics resonator once to substitute my cat once and the fibreglass material inside got roasted!!! The exhaust was roaring like crazy and that was under a month of running in the SD resonator, quality sucks IMHO. Not Aman's quality of work though Link to post Share on other sites More sharing options...
MkIIToledo Neutral Newbie March 20, 2002 Share March 20, 2002 I fitted a Super Dynamics resonator once to substitute my cat once and the fibreglass material inside got roasted!!! The exhaust was roaring like crazy and that was under a month of running in the SD resonator, quality sucks IMHO. Not Aman's quality of work though Is there a running-in period for resonator/mufflers?!?! Yup, Aman has a cult following....was there and Hondas start to form a queue liao! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 20, 2002 Share March 20, 2002 Well, what I meant was the exhaust fibreglass burnt so fast. There's no official "running in" of exhaust, but as mufflers ages, they tend to get louder. Not within a month of course ↡ Advertisement Link to post Share on other sites More sharing options...
Carbon monoxide poisoning misdiagnosed as lymphoma
Advice on exhaust.
Advice on exhaust.
Ford invents retractable exhausts
Are You A Big Spender For A High End Bed Mattress?
ACS boy dies during high adventure course
High-rise littering
High-rise littering
Exhaust Welding job, MAN, Jeep Chee or Fong Kim
