Vroomtattat 2nd Gear July 8, 2010 Share July 8, 2010 What is this AMSOIL thingy, sounds interesting. Is it that good? Hmmm... ↡ Advertisement Link to post Share on other sites More sharing options...
Trex101 3rd Gear July 8, 2010 Share July 8, 2010 If E9 spec then IIRC schaeffer 9k 5w40 also meet leh. Yes you are right, seem like both are ACEA E9 spec. Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear July 8, 2010 Share July 8, 2010 Hi brudder Trex101, What would you recommend for my 3 years old Sunny? Thanks! Link to post Share on other sites More sharing options...
Trex101 3rd Gear July 8, 2010 Share July 8, 2010 Hi brudder Trex101, What would you recommend for my 3 years old Sunny? Thanks! Depends on what you after? If want best FC, you can choose Redline 0w30, Mobil 0w30 or Amsoil SSO 0w30. If heavy footer who sometimes goes track then 10w30, 5w30 would be a balance of both. Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear July 8, 2010 Share July 8, 2010 Depends on what you after? If want best FC, you can choose Redline 0w30, Mobil 0w30 or Amsoil SSO 0w30. If heavy footer who sometimes goes track then 10w30, 5w30 would be a balance of both. Oh? okay. Then for me should be a balance of both . . . . 5w30 for me then. Thank you, brudder! Link to post Share on other sites More sharing options...
Trex101 3rd Gear July 8, 2010 Share July 8, 2010 Oh? okay. Then for me should be a balance of both . . . . 5w30 for me then. Thank you, brudder! No worries, you are most welcome Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 9, 2010 Share July 9, 2010 can i check if Schaeffer 9k 5w40 meets/exceeds ACEA-C3 requirements? i cant find this info in their website Based on info provided by Trex101, ACEA C3 are engine oil which has low SAPS. SAPS refer to Sulphated Ash, Phosphorus and Sulphur. Requirement for ACEA C3 specified engine oil to contain a maximium Sulphated Ash of 0.8%, Phosphorus 900ppm and Sulphur 0.3%, among other requirement such as HTHS, NOACK & TBN. The data sheet for Schaeffer 9000 5w40 did indicate it contain Sulphate Ash of 1%, hence failed ACEA C3 requirement. A check of VOA and UOA in BITOG show that Schaeffer 9000 5w40 the phosphorus typically exceeded 1000ppm. which also failed ACEA C3 requirement. Therefore, I doubt it qualify for ACEA C3. Link to post Share on other sites More sharing options...
Robin 4th Gear July 30, 2010 Share July 30, 2010 thanks very detailed explanation Link to post Share on other sites More sharing options...
Robin 4th Gear July 30, 2010 Share July 30, 2010 yes, saw the ACEA C3 printed on the amsoil bottle will be joining an MO for it in another forum.. the organiser should be getting the Eo from u Link to post Share on other sites More sharing options...
Horsee Clutched July 30, 2010 Share July 30, 2010 can pm me the forum for amsoil MO? Link to post Share on other sites More sharing options...
Servic Clutched July 31, 2010 Share July 31, 2010 yeah i am interested to join in the MO too if it is possible. =) Link to post Share on other sites More sharing options...
Black6 2nd Gear August 4, 2010 Share August 4, 2010 yeah, i am interested in the Group buy. Have to change soon. Which forum is having group buy. Thanks. Link to post Share on other sites More sharing options...
Slvo85 Neutral Newbie September 18, 2010 Share September 18, 2010 hi guys, i am not sure if i should chnage to 5w30 or 5w40 for my ride?? may i know wat the difF?? i am driving 2l laner and hitting 30k. thansk!! Link to post Share on other sites More sharing options...
Desmondband Neutral Newbie September 18, 2010 Share September 18, 2010 Amsoil is good. currently using SSO. cheap too. changed during half tank and i can go 50km more! Link to post Share on other sites More sharing options...
Mini-itx Clutched September 18, 2010 Share September 18, 2010 hi guys, i am not sure if i should chnage to 5w30 or 5w40 for my ride?? may i know wat the difF?? i am driving 2l laner and hitting 30k. thansk!! 30wt oil will do for you. 30K is not high mileage. Don't need 40wt. Link to post Share on other sites More sharing options...
Mini-itx Clutched September 18, 2010 Share September 18, 2010 Btw, I just drained my Motul 300V oil and put in Amsoil ARO 20W50. Engine is smooth man! I don't care what others said about Motul oil but I don't like it and it doesn't like my engine as well. Its not as smooth as Amsoil and it doesn't last. I will never buy Motul oil every again.... Link to post Share on other sites More sharing options...
Piggy83sg Clutched September 18, 2010 Share September 18, 2010 seem alot ppl choose amsoil over schaffer. ↡ Advertisement Link to post Share on other sites More sharing options...
Any amsoil alternatives?
Where to get cheap AMSOIL EO?
Explosion rocks central Bangkok, casualties seen
Assistance needed!
Assistance needed!
Amsoil VS Redline
Amsoil VS Redline
CSC3 Rocks!
CSC3 Rocks!
Amsoil oil distributor
