Rdtws Neutral Newbie January 29, 2005 Share January 29, 2005 (edited) I have just upgraded my component speaker to MA audio 5 1/4" (140W) connected to a 1000W amp. However with engine at idle the tweeter is making a tick tick sound. When driving, i can hear my engine roar from the tweeter. When playing using battery power, all the noise is not vaild. Anyone know what's wrong, please advise. Thanks. Edited January 29, 2005 by Rdtws ↡ Advertisement Link to post Share on other sites More sharing options...
Deanchew Neutral Newbie January 31, 2005 Share January 31, 2005 Hi RDTWS: The most likely cause is due to poor grounding of your amplifier and poor interconnects used. If the connections mentioned above are confirmed good, then you probably need to install a device called Alternator Noise Filter for the DC supply to your ICE units. Hope my suggestions help... Link to post Share on other sites More sharing options...
Jackfoo 1st Gear February 2, 2005 Share February 2, 2005 i have the same problem on my tweeteralso. any ideas how much it cost to install the so-call Alternator Noise Filter? where can it be done? thanks Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear February 2, 2005 Share February 2, 2005 You have the dreaded aeroplane sound... What could happen is that your installer have route the signal cables too close to the power cable hence its electrical interference that your tweeter is picking up. I suggest that you ask your installer to re route the wiring. Do not accept them using a gadget call the suppressor to cure this....its a easy and lazy way to solve this problem. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear February 2, 2005 Share February 2, 2005 (edited) The gadget you referring to is the suppresor. Dun use that. It sucks power off your system. A good installer will not use it to solve the problem. The best way is to re wire the whole system. Edited February 2, 2005 by Ghostrider Link to post Share on other sites More sharing options...
Ahdi Neutral Newbie February 2, 2005 Share February 2, 2005 yeah...agree wif u...... my sound sux when i use this supressor, but after got it remove and tune by pro..the sound got betta... anyway got supressor..anyone intersted? Link to post Share on other sites More sharing options...
Deanchew Neutral Newbie February 3, 2005 Share February 3, 2005 My suggestion to using the noise suppressor which is passive by nature whould not suck up power like you mentioned, it only filter the noise element by shorting them to ground. It should be used as a last alternative if all ways like proper orientation of cables, proper grounding and quality cables and connectors are used. Link to post Share on other sites More sharing options...
Yongsin Neutral Newbie May 21, 2005 Share May 21, 2005 the suppressor how much you want to sell? Link to post Share on other sites More sharing options...
York Clutched May 21, 2005 Share May 21, 2005 I have just upgraded my component speaker to MA audio 5 1/4" (140W) connected to a 1000W amp. However with engine at idle the tweeter is making a tick tick sound. When driving, i can hear my engine roar from the tweeter. When playing using battery power, all the noise is not vaild. Anyone know what's wrong, please advise. Thanks. serious boh...connect a pair 140W tweeter on a 1000W AMP...lidat ur Amp gain button got lower below the mid level...which'll udr utilised tis component... Link to post Share on other sites More sharing options...
Josephtan1234 Neutral Newbie May 21, 2005 Share May 21, 2005 I have just upgraded my component speaker to MA audio 5 1/4" (140W) connected to a 1000W amp. However with engine at idle the tweeter is making a tick tick sound. When driving, i can hear my engine roar from the tweeter. When playing using battery power, all the noise is not vaild. Anyone know what's wrong, please advise. Thanks. You might want to start with just moving the tweeter wiring from the cross over into a different position first. If that works, you save yourself a lot of trouble. Mine was solved that way. Link to post Share on other sites More sharing options...
Ivan0507 Neutral Newbie May 21, 2005 Share May 21, 2005 bro,poor installer.normally if u put all the cables together u will get this problem.i believe yr installer put all the audio cables in one location .eg all at right side towards the rear rite or all at the left side towards the rear .just reinstall again .put yr power cable on the left and all others cables on the right .that should be alright. Link to post Share on other sites More sharing options...
Slonez Clutched May 21, 2005 Share May 21, 2005 I have just upgraded my component speaker to MA audio 5 1/4" (140W) connected to a 1000W amp. However with engine at idle the tweeter is making a tick tick sound. When driving, i can hear my engine roar from the tweeter. When playing using battery power, all the noise is not vaild. Anyone know what's wrong, please advise. Thanks. No shortcut, re-wire your system using installer who knows what they're doing. Link to post Share on other sites More sharing options...
Psfong Clutched May 23, 2005 Share May 23, 2005 I have this problem also. I believe you have the Lanzar 424? I managed to solve it by lowering the gain on the amplifier (while engine is running). Try it before doing all the rewiring and supressor stuff. ↡ Advertisement Link to post Share on other sites More sharing options...
Steering rack noise on 2010 Altis
Extending quiet time by 1½ hours among recommendations to tackle neighbourhood noise in Singapore
NEA to lower vehicle noise levels from 2023
Brake squeak every morning
Hissing/static sound when playing from DSP
