Brake Caliper Painting/Spraying
Hcgiv942
$20+ is it with the spray/paint and labour? [sweatdrop]
and also is it for 1 pc or 1 pair?
Edited by Hcgiv942
Hehe...yah..I'd do it myself if I had the time. Read Presea's Painting Caliper project.. [sweatdrop]. Saw a can of VHT paint going for S$9 a can at a Self-Fix DIY shop. But will also need to get other stuff like fine sandpaper etc also. Have been quite busy tho. [:p]
Edited by Assassin
Its located at St Michael's Rd
Turn left at the 2nd overhead bridge (old wooden type - 1st bridge is concrete type)
when coming down from Serangoon Rd [;)]
www.autowerke.com.sg
You can try other VHT dealers too like GarageR, Autofix, etc.
Check the list below [;)]
http://www.powerkits.com/TBC-Applicators.htm
As for pricing, I'm not too sure ... sorry ... [:p]
I got mine done by McWell before and another time at Yap Brothers. but not using VHT paint though [;)]
Edited by Lightspeed
I did DIY painting on my brick's calipers (all 4 done in Silver) with Hammerite paint. First I degreased the calipers and uses a medium sanding block to prep the surface. I didn't use a fine sandpaper as I wanted a rough look, washed the calipers again and painted 2 layers with 20min in between the layers. The entire exercise lasted half day for painting 4 calipers and optional ECA like;
rotate tires, clean the inside of the rims and apply Klasse to the rims! [thumbsup][;)]
"I did DIY painting on my brick's calipers (all 4 done in Silver) with Hammerite paint. First I degreased the calipers and uses a medium sanding block to prep the surface. I didn't use a fine sandpaper as I wanted a rough look, washed the calipers again and painted 2 layers with 20min in between the layers."
I was thinking of using black for mine. What can I use for degreaser ? You painted all calipers at the same time ? Coz I've only got one car jack and only remove one tyre at a time. [:/] Think will do a few coats also. And also put on a clear coat if possible. [:p]
Cheers [:p]
No need to spray black, it becomes that colour once you don't wash! U really should go for some more exotic colour like BLUE, RED or Purple [jawdrop]
[laugh] I know...the thing is...once I dun wash...it becomes a greenish blackish colour lah. [:/] I was considering red actually....but it would be too conspicuous on my car. Altho there are some tuners that already have a purple and black brake caliper models for my car. Anyway, its gonna have to be one of these 3 colours .... black, red, or purple... in order of preference. [:p]
Hammerite paint can be gotten from Carrefour or Homefix DIY shops. U can get brake parts cleaner from Autobacs or Waterloo Centre, alternatively use engine degreaser. [;)]
