Nice Ice Installation..
Gadgeter
I believe that a LCD Screen (without player) fixed onto the car's roof ranges from about $600 upwards - depending on size and brand.
A portable DVD player without screen costs only $120 upwards - e.g. Wearnes, Akira, Shinco, etc.
A 1-din DVD player (fitted into dashboard) should be in the region of about $700 upwards - again depending on brand.
Another option is the LCD screen with built-in player - don't know how much though.
Good luck.
Genesis Audiophile A16.02
Helix Co-axial (not sure model no.)
Pioneer TS-STX99
Pioneer TS-WX22A
Butler TDB2159
Predator (don't model or power?)
Genesis Profile 2
Audio Control DQT (not tuned yet)
Alpine CDA-9835
Alpine DVA-5210E
Alpine CHA-S634
Alpine KCA-410C
Alpine TMX-R800
Helix Cap 3.3 Noise Eliminator
Lightning LSD10DT-03 (Strike) 1 Farad Capacitor x 2 pcs
Mundorf Head Cap SC68 (68,000 uF 25V with protection unit)
RE XXX12 (not installed yet)
RE 12.1 (awaiting shipment fm factory)
kwongwing> Wow!! great setup (although i dunno wat izzit) but looks cool....... wont that be complicated??
slonez>thanks for the invi, dont think i can maek it til end of yr. i was away and currently at penang for some business purposes. hope to join you guys soon.
Since i'm not interrupting, can i ask question?? hope you guys can help me to learn. since i'm a noobie, might be very very "fan"......
Wat is rms??
RMS and WATTs same?? How to differentiate?
How do we calculate the right RMS or WATTs to our speakers or woofers??
What is SQ and SPL?
How to read frequency?
What would be a good setup for a noobie?
Wat is over power and under power??
wat brand of amps and speakers is consider "okok"?
is rockford fosgate and lightning audio good??
hope it not too much of quetions that i ask.....pls do not [furious][whip] me.......noobie sure paiseh wan
tailan> my system as below:-
1. Front Spkrs - DLS UR6s component speakers
2. Front Amp - Helix B2 precision 2 channel amp bot
3. Subwoofer - Rockford Punch 2 12" with sealed box.
4. Mono Amp - JBL GTO301.1
Just do a search and you will get all the specs.
All less than 1 year. Helix, Rockford, JBL with receipt.
All installed at Chuan Sing (Sin Ming)
Asking $1600
Edited by Mizarahi
hmmm...... still ada a bit out of mind..... let me learn something xtra and try to get back to you a.s.a.p......thanks for the offer. [sweatdrop]
thanks gadgeter> appreciate the info that you provide........ But isnt the rms true to be stated at the amp?? coz i mthought most of the amp was QC by "CAE".......
and do RMS = to half of the power rated. for xample 50RMS = 100w??
Hi I'm new to ICE. so can anyone tell me wether will I blow up my 350rms woofer if i use 500rms amplifier to power it. Or is 250rms enough for my 350rms woofer???
sony 2 channel XM-SD22X amp with 2 sony 10" XS-LD105P5 woofer. If i get one more amp, tat means i bridge the amp to produce 500rms each to power each woofer, will i get louder bass???
you may have problem running only 1 sub with your amp, because your amp is 500W X1 @ 4ohm, and your sub is a DVC (double voice coil) 4ohm, you may want to get another identical sub and parallel wire them to 2 ohm each, and your amp can do a 250 X2 @2ohm
btw, have you bought the sony?
