Alky 2nd Gear May 12, 2005 Share May 12, 2005 Does any of the VAG brothers here know how to reset the service indicator? Just did my servicing a few weeks back but I think they forgot to reset it. Now it's blinking whenever I start the car. I thought it can be done without the VAG tool, right? ↡ Advertisement Link to post Share on other sites More sharing options...
Skodee Neutral Newbie May 12, 2005 Share May 12, 2005 (edited) Pay a visit to Eurohaus or Servo to get it reset with their VAG tool...1 min job. Unless you have a PC running VAG software OBD II with connectors worth a try Check it out http://www.softwareforcars.com/OBD-software.htm Edited May 12, 2005 by Skodee Link to post Share on other sites More sharing options...
Jhoo Neutral Newbie May 12, 2005 Share May 12, 2005 http://www.vagsg.com/forums/viewtopic.php?...highlight=reset I hope it helps Link to post Share on other sites More sharing options...
Skodee Neutral Newbie May 12, 2005 Share May 12, 2005 (edited) Just cut and paste here for reading pleasure: 1. Press the right dial lever down and simultanously turn ignition key halfway till dial lights come on. 2. Service warning light will appear without flashing 3. turn left dial lever clockwise and service light will disappear 4. start car and let it running for about 2 seconds 5. switch engine off and remove key. I wonder what dial is he saying? Edited May 12, 2005 by Skodee Link to post Share on other sites More sharing options...
Virus 2nd Gear May 12, 2005 Share May 12, 2005 Dial on the meter?? Right for adjust clock and left for reset odometer ? Link to post Share on other sites More sharing options...
Steady Neutral Newbie May 12, 2005 Share May 12, 2005 I think should be the other way around. Right for resetting odometer and left for clock. I just reset mine yesterday, very easy. Link to post Share on other sites More sharing options...
Alky 2nd Gear May 12, 2005 Author Share May 12, 2005 Thanks very much to all for your inputs. I shall try that tomorrow morning. But there is only one dial on my car (Toledo). Without pressing, turn left to adjust hour and right to adjust minutes. Press to reset trip meter. I think it should work the same. Link to post Share on other sites More sharing options...
Phalanx Neutral Newbie May 12, 2005 Share May 12, 2005 (edited) I thought we got two dials? Darn my memory failing? Hmm... Edited May 12, 2005 by Phalanx Link to post Share on other sites More sharing options...
Mel4fun Neutral Newbie May 12, 2005 Share May 12, 2005 Errr...one dial for reseting the trip meter (Etc.) What have you been doing lately ..... getting too distracted by other cars ??? heh heh Link to post Share on other sites More sharing options...
Fluffy Clutched May 13, 2005 Share May 13, 2005 alky, the instructions are in the manual, i tried it on my tody before.........didn't work though..........(could be my iffy trip meter that self resets every 2000km) don't seem to need it now that i service at CAS, they have the VAG tool too! Link to post Share on other sites More sharing options...
Phalanx Neutral Newbie May 14, 2005 Share May 14, 2005 Hush Link to post Share on other sites More sharing options...
Lightspeed Clutched July 22, 2005 Share July 22, 2005 Something clearer... from Briskoda The service interval display should normally be reset by the Skoda dealer on completion of a service. However it is also possible to reset the service interval display with the reset knob of the instrument trip counter as follows: * Switch off the ignition and press the reset knob on the trip counter below the speedometer and hold. * Switch on the ignition and release the reset knob. The message service or service now appears in the display. * Turn the knob for setting the clock to the right until the message is reset. The manufacturer does not recommend resetting the service interval yourself as this may result in incorrect settings and thus in possible faults in the vehicle. After resetting the service interval display on models fitted with LongLife Service, the service messages are displayed in the same way as on models not fitted with LongLife Service. For this reason the manufacturer recommends having the service interval display reset in a Skoda Dealership. The service interval display is correctly reset by the Skoda Dealership using a diagnostic tester. Link to post Share on other sites More sharing options...
Coke21 Neutral Newbie July 29, 2005 Share July 29, 2005 So if we only have one then how? What do we do? Link to post Share on other sites More sharing options...
Jenson Neutral Newbie July 30, 2005 Share July 30, 2005 The service manual have indicate how to reset. Theres 2 dail one is clock n one is speedo u sould turn the dail on the speedo anticlockwise but not pressing it. I have done it alot of times but i always see manual sorry dun rem all the steps liao. Link to post Share on other sites More sharing options...
Fortress Clutched August 1, 2005 Share August 1, 2005 Thanks. May I ask where can I find it on the manual and which model of Octavia your have there. Link to post Share on other sites More sharing options...
Fortress Clutched November 4, 2005 Share November 4, 2005 Just gotten it done this morning, try using the following steps. Press and hold button (A) Switch ignition ON Release button (A) Depressed and hold (A) Turn button on clock, clockwise and hold to reset. Switch ignition OFF ↡ Advertisement Link to post Share on other sites More sharing options...
Singpost courier dishonesty with incredibly lousy service
National Service in Singapore
How to feedback on hospital service?
The ownself service car hobbyist! Pls come in Share your lobangs/parts hoot
Bad service from Top93, ubi
House painting
House painting
