Soya Supersonic December 31, 2002 Author Share December 31, 2002 Wet performance is not bad. I usually drive 110kmh even in the wet and still very stable, no aquaplanning feeling. I'm satisfied wif the dry performance tho i find the ST115 still grips bettter. But the ES100's ride is a notch above the ST115. ↡ Advertisement Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie December 31, 2002 Share December 31, 2002 Hi Wildswan, the check engine light is just a basic warning system that sense there's an error code be sent by the ECU. You'll have to check with SM and get them to pull the error codes and see what's indicated faulty. If the parts have been changed and the same fault code comes out, then it could be another part that triggers the same code. Kinda like "one leads to another" type of scenerio If ECU kaput, then get SM to do a proper ECU diagnostics or at least re-flash the ECU program and see whether the check engine light comes again.... ↡ Advertisement Link to post Share on other sites More sharing options...
How to find equivalent offset to replace stock wheel?
Wide body fender roll (Clear low offset)
Question on rim offset
Resigning and using leave to offset notice period
Hellaflush
Hellaflush
Good and reasonable price offset printer in malaysia
Will 245/40/R18 with Offset of 32 fit Superb 09?
Mazda gets patent for offset wheel-mounted electric motor
