Jermy Clutched September 5, 2005 Share September 5, 2005 abt 2 weeks plus. Haven't driven up to m'sia yet but i guess i would advise against prolonged driving on dusty roads if u r using the hurricane. ↡ Advertisement Link to post Share on other sites More sharing options...
Geminian1906 Neutral Newbie September 6, 2005 Share September 6, 2005 wah... i gotta go malacca ard 4 times a year... using hurricane will have serious problem or not? Link to post Share on other sites More sharing options...
Jermy Clutched September 6, 2005 Share September 6, 2005 well, in that case i wldn't advise u to use it la. Perhaps u can consider K&N instead. But make sure u oil it regularly Link to post Share on other sites More sharing options...
Dennisk Clutched September 6, 2005 Share September 6, 2005 ask lammy for advise Link to post Share on other sites More sharing options...
Geminian1906 Neutral Newbie September 7, 2005 Share September 7, 2005 Hello Lammy, care to comments? Link to post Share on other sites More sharing options...
Geminian1906 Neutral Newbie September 7, 2005 Share September 7, 2005 Link to post Share on other sites More sharing options...
Lammy Neutral Newbie September 7, 2005 Share September 7, 2005 Its ok to use Hurricane. A customer who uses oil based foam filter switch to Hurricane and was very happy bout the performance. He say Hurricane is alot easier to maintain. He travels twice a month to KL. Link to post Share on other sites More sharing options...
Freeman 1st Gear September 8, 2005 Share September 8, 2005 I think Hurricane hasn't being long enuf in the market to conclude whether it will cost any problem to the engine in a long run. Link to post Share on other sites More sharing options...
Phantom76 Neutral Newbie September 8, 2005 Share September 8, 2005 you speaking about me is it? i am back to using the open pod. better for highway travel. Link to post Share on other sites More sharing options...
Dennisk Clutched September 22, 2005 Share September 22, 2005 323 hurricane coming soon? Link to post Share on other sites More sharing options...
Lammy Neutral Newbie September 23, 2005 Share September 23, 2005 (edited) Yup... its just in. Please give me a ring @ 93820113. Sorry for the long wait. Edited September 23, 2005 by Lammy Link to post Share on other sites More sharing options...
Fluffy Clutched September 23, 2005 Share September 23, 2005 i think the main problem is not that it hasn't been in the market, but rather, what filtration it offers. what is the filtration efficiency? what size of particles does it filter out? if you don't use a good filter, than you may have just destroyed your car worth thousands of dollars for a little bit of performance/fuel efficiency with a filter worth about a hundred bucks. An effective air filter blocks/traps harmful microscopic air particles that can cause engine damange and also damage to the combustion chamber. this question is, can you weave stainless steel thread close enough so that these microscopic dust particles don't go into the engine? what holds the particles in the filter? basically, how do you know you aren't just buying a wire mesh from a cooker hood (of course, that is for oil, but usually also comes with a fiber filter)? have you ever heard of a wire mesh HEPA filter? hmmm.......... Link to post Share on other sites More sharing options...
Fluffy Clutched September 23, 2005 Share September 23, 2005 more info on airfilter http://www.bobistheoilguy.com/airfilter/airtest1.htm Link to post Share on other sites More sharing options...
Renegade Neutral Newbie September 23, 2005 Share September 23, 2005 Question - do such filters come with model names such as "Katrina" and "Rita"? Link to post Share on other sites More sharing options...
Fluffy Clutched September 23, 2005 Share September 23, 2005 wonder if they do the same damage too ?? Link to post Share on other sites More sharing options...
Unltd 5th Gear September 24, 2005 Share September 24, 2005 Hey actually I would like to know the specs for this filter as I am thinking of changing to it, has any testing been done and what kinda filteration does it offer?? in terms of micron its about 80? I think wif more technical specs there would be higher confidence in hurricane. juz my tots Link to post Share on other sites More sharing options...
Airwave05 Neutral Newbie September 24, 2005 Share September 24, 2005 Hi Lammy FYI, your "Jazz" Hurricane filter does fit well onto my AIRWAVE. I've used K&N in my previous car, and extremely new to yr product i.e. in another word, not very convince + do not see much accolade as compared to K&N. Does your Hurricane Filter c/w any 3rd party test certification and endoresement by any reputable Non-Profit Motoring Body? I was told that the Wire Mesh will expand when he engine warms up after some time; i.e. thus allowing more air to pass thru for better AFR. Is that TRUE? BTW, inorder not to damage the engine, what is the minimum allowable (recommended) MIRCON size for air-filter? Any idea? I must agree that the ease of cleaning has very much improved with Hurricane. However, care must also be exercised; i.e. as one drop and possible dent will jeopadise the overall meshing size[sweatdrop] . Lammy, appreciate your expert view on these. Cheers! Link to post Share on other sites More sharing options...
Dennisk Clutched September 24, 2005 Share September 24, 2005 think have to try then you know....after more people start trying then there will be more feedback on it... ↡ Advertisement Link to post Share on other sites More sharing options...
Air Purifier Discussion - tips and info
DIY engine oil change
Steel cabinet
Steel cabinet
Recommendation for water filter
Dyson Zone, the real deal or has April fool's day come early?
Replacing fuel filter
TRD Engine Air Filter
