Unknown_G7 Neutral Newbie May 20, 2005 Author Share May 20, 2005 I did switch on the a/c when the idle rpm at 200, but the idle rpm is still the same. ↡ Advertisement Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 20, 2005 Share May 20, 2005 high chance u need to change the choke. cost me $20. maybe u try adjust higher rpm, and monitor first. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 20, 2005 Share May 20, 2005 Have to rev a bit higher at between 1k - 1.6k to change gear. If normal rev to above 2k, the engine will roar. Last time, my car hit 90km at 2.5k rpm. Now 90km at between 1.6k - 1.8k rpm. What u saying here don't make sense??? How can the RPM b lower now when travelling at 90km/h. Do u mean u r in the same gear (ie. 5th gear on the manual gearbox)? If so, it's NOT POSSIBLE. Only explanation is the RPM meter is faulty. Get it checked. Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 20, 2005 Author Share May 20, 2005 Tomorrow morning I'll open bonnet to check where is it Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 20, 2005 Share May 20, 2005 maybe he is saying need to have min. rpm 1k above before changing gear....hee...i also not sure... Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 20, 2005 Share May 20, 2005 gd luck Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 20, 2005 Share May 20, 2005 Yah. I don't really u'stand what he is trying to say. Don't make much sense. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 20, 2005 Share May 20, 2005 I did switch on the a/c when the idle rpm at 200, but the idle rpm is still the same. Car can idle at 200 rpm??? Engine sure die leh. Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 20, 2005 Author Share May 20, 2005 Correct. It's 90km on 5th gear. Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 20, 2005 Share May 20, 2005 same thinking...200 idling is way too low to maintain the engine running... Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 20, 2005 Share May 20, 2005 wah when i hit 90km..my rpm already 2500 rpm liao....urs only 1k++ rpm...not bad leh. still got lots of horsepower to go more...cheong cheong cheong Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 20, 2005 Author Share May 20, 2005 This is what happened whenever I start the car. But no engine stall leh Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 20, 2005 Share May 20, 2005 Only carburated engines have manual or auto choke.EFI engines us the lambda sensors to regulate the fuel. Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 20, 2005 Share May 20, 2005 thks for the update....pardon for being "half pail water" Link to post Share on other sites More sharing options...
York Clutched May 20, 2005 Share May 20, 2005 obviously ur tachometer is not accurate...petrol engine cant stay idle @ 200rpm...even @ 400rpm ...the engine will be 'shaking' badly...the engine rubber mounting in no time will be Suggest u get a workshop diagnostic machine to chk... Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 21, 2005 Share May 21, 2005 maybe he is saying need to have min. rpm 1k above before changing gear....hee...i also not sure... How to change gear at 1k rpm??? Car cannot even move off in 1st gear with only 1k rpm. Looking at his posts, I thing he is trying to make a fool of us. Or he has bought some strange car. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 21, 2005 Share May 21, 2005 Sorry buddy, but what u have posted here don't make any sense at all. My only suggestion to u is to send your car to a reliable workshop to get all your problems checked by a professional. Not much more advise I can give to u. Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 21, 2005 Author Share May 21, 2005 OIC ↡ Advertisement Link to post Share on other sites More sharing options...
To be Happy, start thinking about Death!
Feedback
Feedback
The 2017 Alfa Romeo Giulia
Budget 2025 - February 2025.
Dealer re-sell problem car
