Catalytic converter...will it expire?
Wolverine
Any mechanic bros out there can advice, if i were to buy a USED catalytic converter but it is out of the car for like 1 - 2 years how can i ensure that it is still in working condition? i duwan to have this thing plug up my exhaust system and blow up my engine....help. thanks
It should NOT be a problem, provided you keep it in good condition. It is the Lambda or O2 sensor that is worrying. What did you do when taking it out, did you short the O2 to prevent it from giving a signal.
Ivan
Edited by Fortress
eh...who is Man..am lost.
Sensors need to be closed so that the ECU will not refuse to work. Did it once before, took out the Cat and run it straight through. The car is quite power thereafter.
What car are you driving.
Ivan
Edited by Fortress
By default if I'm not wrong you should have 1 or 2. Usually suppress the sound. I have 1 reson and 2 cats for my stock. changed the entire turboback exhaust to aftermarket with just 1 reson and 1 hi flow cat and its about 89-91db [sweatdrop]
Bro, how do you make the o2 sensor closed? Coz my fren had just done his exhaust (Toyota Vios) in JB. Having his extractor replace (4-1) and straight thru exhaust with cat removed & operated muffler. But right now his engine light keep coming out. With such a mod... the car should perform very tok kong, but I think it's due to the warning light keep on appearing which causes the car to lost it's power.
Hope I can get some help here. [sweatdrop]
That's the name of the Malay boss of Man Exhaust. [thumbsup]
Blk 11 Sin Ming Ind Est Sec B #01-77 Singapore 575655
Telephone : 6458 7053
Hi,
Do not really know about Japanese cars, especially Vio. Anyway,there are 2 wires to the sensors, I cut the wire and close the circuit by joining them together. The system actually thought that it is still working. That simple. Learnt it from an Alfa 164 guys.
Ivan
Edited by Fortress
Wow.. so easy ah. That I better tell my fren to ask around his Vios group fren better. other wise, once it's cut off.. and still won't work. the o2 sensor is gone forever liao. [laugh]
Eh no one answered my question lay... i have got an original CAT (1-2 years not used - removed from car) and now i have a Straight thru CAT done by MAN Exhaust. I think my inspection should come soon so i wanna put that ORIGINAL back so as to clear inspection...But i am worried tht the original cannot be used any more....
Don't need to change back mah. Get a workshop to sent you car for inspection your behalf lor. They will know what to do if you told them wat you mod. But must pay a bit more lor.
oh so cheap ah? than better go weld back lah. I have from my fren that doing such will cost about $150 - $250. Think it's most suitable for those ppl who mod their car super serious type. [;)]
