Fortress Clutched July 10, 2006 Share July 10, 2006 Note that it said to be a temporary repair, however, some can be used up to 50,000 km, which means the lifetime of the tyre. As for the brand, never really paid attention to it, just the cost and whether do I need an extinguisher, which i have. Note, based on my personal experience, that if you are driving an Alfa or other high end performance cars, which requires all wheels to be balance, will cause the car to vibrate at high speed, ie, 120kmh and above. ↡ Advertisement Link to post Share on other sites More sharing options...
Genie47 1st Gear July 10, 2006 Share July 10, 2006 OK this type of thing is actually polyurethane foam. Basically when you inject the thing in, it will polymerize into solid polyurethane. In the end, you will have a semi-solid tire filled with foam plastic. It is quite rigid actually. Now the thing about it is that it can last quite a fair bit. The bad thing is that you cannot take your car up to high speeds. The foam will melt. A nice plus about it is that it is puncture proof. Link to post Share on other sites More sharing options...
Hyun Neutral Newbie July 10, 2006 Share July 10, 2006 you will need to inform the mechanice to remove the chemical. Else he wun know. oh, so can remove ah? so the problem of balancing tyre is solved liao, just ask him remove before repairing. probably charge extra labour? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear July 10, 2006 Share July 10, 2006 might cost a bit more... Such is just for emergency... in case no spare or spare already in use? Link to post Share on other sites More sharing options...
Lukie102 Clutched July 10, 2006 Share July 10, 2006 i'll probably prefer this as a temporary measure than to change tyres. will go get myself a can. thanks Link to post Share on other sites More sharing options...
Lukie102 Clutched July 10, 2006 Share July 10, 2006 yeap. intention was to have it as temporary measure before i go to the tyre shop and properly mend the tyre. thks Link to post Share on other sites More sharing options...
Aimnfire 4th Gear July 11, 2006 Share July 11, 2006 i did use this thing b4 on my bike that time already 3 am when i feel my rear bike wobbling check....i got a flat go petrol kiosk to pump air and notice i got a punture so no choice buy the can spray ask my friend to jack up the bike while spraying the foam into the tyre at the same time rotate the tyre so it will cover the puncture never did change the tyre though but downside is once the foam hardern..........my bike balancing is out as i can feel 1 side is heavy Link to post Share on other sites More sharing options...
Chris24 Neutral Newbie July 18, 2006 Share July 18, 2006 good to have... but hopefully it'll never be used Link to post Share on other sites More sharing options...
Brock 1st Gear July 18, 2006 Share July 18, 2006 Lukie, I'm already using one already. I took out my spare and just carry the can. NTUC, AMK sells them. Carrefour too. Made in Mexico. $8.50. I think. I too prefer to inflate it and drive it to nearest tyre shop to get it properly fixed or replaced. Safety more important than money. Here's a pic of the can that I'm using: Link to post Share on other sites More sharing options...
Lukie102 Clutched July 18, 2006 Share July 18, 2006 ahh....but i have a problem. no place to put my spare tyre except my waist Link to post Share on other sites More sharing options...
User12343 Clutched July 18, 2006 Share July 18, 2006 how u know how much air is enuf for the tyre? agar agar one? Link to post Share on other sites More sharing options...
Princey_anne 1st Gear July 18, 2006 Share July 18, 2006 I have two in my car, the last time two of my tyres punctured in Malaysia. I changed one tyre and used the other can. Now I keep two all the time. Link to post Share on other sites More sharing options...
Brock 1st Gear July 19, 2006 Share July 19, 2006 1 can 1 tyre. The instruction will inform you to deflate the tyre first before using it. Link to post Share on other sites More sharing options...
Brock 1st Gear July 19, 2006 Share July 19, 2006 Haha! Cute! I place my spare tire under my office table! Link to post Share on other sites More sharing options...
Lukie102 Clutched July 20, 2006 Share July 20, 2006 huh?? office space not mine. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 21, 2006 Share July 21, 2006 but hor, this can, does it make the tyre messy until cannot do a repair, must throw away the tire? or damage the rims? no mess lah. just used it last sunday. the only complaint by the tyre guys is that it stinks Link to post Share on other sites More sharing options...
Spherex 1st Gear July 21, 2006 Share July 21, 2006 you will need to inform the mechanice to remove the chemical. Else he wun know. any idea how he remove the chemical? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear July 24, 2006 Share July 24, 2006 for mine.. they just take out the tyres and pour the chemical inside out. ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
