Kieran1975 1st Gear May 18, 2007 Share May 18, 2007 Hi, need advise whether the Genesis Profile Two Channel Amp is good enough to drive my CDT CL62 component speaker? CDT CL62 6.75" 2-Way component set Mid: Stamped 6.75" Crossover: EX-450 24 dB. Elliptic 2-Way Built-in Image enhancement Tweeter design Tweeter: TW-25S 1" silk twtr Power Handling: 160 watt RMS 100Hz high-pass Frequency Response: 60-20kHz Sensitivity: 92.3 dB Impedance: 4Ohm Surface & Flush mount Tweeter Titanium Tweeter optional (TW-25T) Genesis Profile Two Channel Amp Power Source: 10.8 ↡ Advertisement Link to post Share on other sites More sharing options...
Protege 1st Gear May 18, 2007 Share May 18, 2007 Guess you are looking the ads at SGSound. Anyway Genesis amps are great amps and they will be more than enough to drive your CDT CL62. As for street price. I am not sure. Link to post Share on other sites More sharing options...
Kieran1975 1st Gear May 18, 2007 Author Share May 18, 2007 Looking for warmer and clearer sound from my front CDT CL62 speaker and not sure is it the right amp for it. Link to post Share on other sites More sharing options...
Protege 1st Gear May 18, 2007 Share May 18, 2007 Amplifiers do play a part. But the main sounding characteristic comes from the speakers. Genesis is a good amp which should give warmer soundng to the CDT CL62. Link to post Share on other sites More sharing options...
Protege 1st Gear May 18, 2007 Share May 18, 2007 (edited) In my opinion, the Genesis may cost much more than the CDT CL62. Its a good choice as you can match a better component speakers to it next time if you want to upgrade! Edited May 18, 2007 by Protege Link to post Share on other sites More sharing options...
Kieran1975 1st Gear May 18, 2007 Author Share May 18, 2007 Pls give me some comment on my ICE setup(passive) HU:Clarion WXZ466MP Front : CDT CL62 componet speaker. Rear: Lanzar 2way coxial AMP: Firefox 2 channel 180Watt for CDT Sub: Pioneer TS-WX22A Active Subwoofer 150 watt Soundproof: 2 layers front & rear doors AMP will be going for upgrading soon...... Link to post Share on other sites More sharing options...
Kieran1975 1st Gear May 18, 2007 Author Share May 18, 2007 The price for the Genesis amp is 2X more than my CDT speaker..... Not sure whether is it a over kill to get this AMP to drive my CDT... Link to post Share on other sites More sharing options...
Protege 1st Gear May 18, 2007 Share May 18, 2007 It can be considered an overkill. But if you plan to upgrade your CDT in the future, its a good amp. Link to post Share on other sites More sharing options...
Kieran1975 1st Gear May 18, 2007 Author Share May 18, 2007 Upgrading for my CDT likely not going to be happen for the next 2 year .... So any good and cheap recommendation AMP to match my CDT CL62 ..... Link to post Share on other sites More sharing options...
Protege 1st Gear May 19, 2007 Share May 19, 2007 To me, its always good to invest in a good amp. If not, look out for the lower end Rockford amp or Alpine amps. Link to post Share on other sites More sharing options...
Linus Clutched May 19, 2007 Share May 19, 2007 allo bro, early morning start the poison liao ? [laugh] Link to post Share on other sites More sharing options...
Xiaogary Neutral Newbie May 19, 2007 Share May 19, 2007 (edited) I using a Cadence 4 X 74w at 4 ohm amp to drive my CDT CL62. I only use 2 channel to drive it passive. I put it in the rear for rear fill. The mid is very clear and good. Wise choice. But the tweeter lose out. I tune it higher and sharper with PX701, it sound a bit tired. I wonder how it sound if I do it active in front. Is it worth the effort? 2 X 75w is enuf for normal listening. BUt Genesis is definitely an overkill for the price. And I fear its not power enuf in term of wattage when u wish to hear decent deep bass. Genesis is SQ amp. CDT is not so SQ. It can produce very decent bass too if given enuf power amp. So your bass may not sound as deep or full with Genesis. I suggest u buy cheaper 4 X 100w or 4 X 125w amp. Since 75w is actually underpowering. But nevertheless its enuf for normal listening. Just that u wasting money so ex 2 channel amp. Wih same money can buy 4 channel amp good for future if you plan to drive it active. Edited May 19, 2007 by Xiaogary Link to post Share on other sites More sharing options...
Route88 2nd Gear May 19, 2007 Share May 19, 2007 I'm using genesis P2 Very good amp England made....use since 2003,continue the tradition to my new car. Drive my CDTs b4 ,but new car drive my Rainbow spkrs Link to post Share on other sites More sharing options...
Route88 2nd Gear May 19, 2007 Share May 19, 2007 Quite expensive Link to post Share on other sites More sharing options...
Route88 2nd Gear May 19, 2007 Share May 19, 2007 BUt Genesis is definitely an overkill for the price. And I fear its not power enuf in term of wattage when u wish to hear decent deep bass. Genesis is SQ amp. CDT is not so SQ. It can produce very decent bass too if given enuf power amp. So your bass may not sound as deep or full with Genesis Spot on abt CDT. I find it much clearer on my Rainbow tag team with Genesis P2 Link to post Share on other sites More sharing options...
Xiaogary Neutral Newbie May 19, 2007 Share May 19, 2007 Bcos rainbow is not that power hungry comapared to CDT. The nominal rms wattage required for rainbow is lesser than CDT. So the matching of rainbow and Genesis P2 is better. A speaker and amp is only how good they are mixed and matched. U buy a very good amp and very good speaker, but their power doesnt match also no use. Link to post Share on other sites More sharing options...
Kieran1975 1st Gear May 20, 2007 Author Share May 20, 2007 Hi Xiaogary , So which AMP will you recommend to match my CDT CL62? You input will be appreciated..... Thanks...... Link to post Share on other sites More sharing options...
Kieran1975 1st Gear May 20, 2007 Author Share May 20, 2007 Which model of Rainbow speaker are you using? how much is the damage? So Rainbow is better with Genesis Amp? ↡ Advertisement Link to post Share on other sites More sharing options...
Genesis back in Singapore ?
[Official] 2021 Genesis GV70
2021 Genesis G70
2021 Genesis G70
2022 Genesis GV60
2022 Genesis GV60
2021 Genesis G80
2021 Genesis G80
JD Power Says Korean Cars Beat US and Europe in Quality
Genesis G90, the superman
