Mondeost220 Neutral Newbie September 11, 2003 Share September 11, 2003 both the RX-7 (FC) and RX-7(FD) are powered by rotary engines...what's so special about rotary engines?and how much they able to punch out so much HP and torque from such a small powertrain(1300cc)?does it have any weak point? ↡ Advertisement Link to post Share on other sites More sharing options...
Flaser Neutral Newbie September 11, 2003 Share September 11, 2003 (edited) Hi there, hope this helps. http://travel.howstuffworks.com/rotary-engine.htm/printable From the article, seems like more advantages than weak points. Wondering why we don't see more of these wonderful engines? Reproduced part of the article below. Key Differences There are several defining characteristics that differentiate a rotary engine from a typical piston engine. Fewer Moving Parts The rotary engine has far fewer moving parts than a comparable four-stroke piston engine. A two-rotor rotary engine has three main moving parts: the two rotors and the output shaft. Even the simplest four-cylinder piston engine has at least 40 moving parts, including pistons, connecting rods, camshaft, valves, valve springs, rockers, timing belt, timing gears and crankshaft. This minimization of moving parts can translate into better reliability from a rotary engine. This is why some aircraft manufacturers (including the maker of Skycar) prefer rotary engines to piston engines. Smoother All the parts in a rotary engine spin continuously in one direction, rather than violently changing directions like the pistons in a conventional engine do. Rotary engines are internally balanced with spinning counterweights that are phased to cancel out any vibrations. The power delivery in a rotary engine is also smoother. Because each combustion event lasts through 90 degrees of the rotor's rotation, and the output shaft spins three revolutions for each revolution of the rotor, each combustion event lasts through 270 degrees of the output shaft's rotation. This means that a single-rotor engine delivers power for three-quarters of each revolution of the output shaft. Compare this to a single-cylinder piston engine, in which combustion occurs during 180 degrees out of every two revolutions, or only a quarter of each revolution of the crankshaft (the output shaft of a piston engine). Slower Since the rotors spin at one-third the speed of the output shaft, the main moving parts of the engine move slower than the parts in a piston engine. This also helps with reliability. Challenges There are some challenges in designing a rotary engine: Typically, it is more difficult (but not impossible) to make a rotary engine meet U.S. emissions regulations. The manufacturing costs can be higher, mostly because the number of these engines produced is not as high as the number of piston engines. They typically consume more fuel than a piston engine because the thermodynamic efficiency of the engine is reduced by the long combustion-chamber shape and low compression ratio. For more information on rotary engines and related topics, check out the links on the next page. Edited September 11, 2003 by Flaser Link to post Share on other sites More sharing options...
Mondeost220 Neutral Newbie September 11, 2003 Author Share September 11, 2003 wah..that's really good information... but i kinda find them "legend"..haha...mayb im too engrossed in the initial D cartoon.. Link to post Share on other sites More sharing options...
Selespeed156 Neutral Newbie September 11, 2003 Share September 11, 2003 This is what i have gathered: a. rotary engines requires overhaul"ing" sooner and more frequent (in the car's life span) than the rest b. They drinks!!!!! c. Not many mechanics know how to fix them Link to post Share on other sites More sharing options...
Davidklt Supercharged February 22, 2024 Share February 22, 2024 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic February 23, 2024 Share February 23, 2024 On 2/23/2024 at 1:42 AM, Davidklt said: More appropriate here Link to post Share on other sites More sharing options...
Volvobrick Hypersonic February 23, 2024 Share February 23, 2024 On 2/23/2024 at 1:42 AM, Davidklt said: Very nice.... But still concept. And those slick flip up headlights unlikely will ever make it to production. Link to post Share on other sites More sharing options...
Davidklt Supercharged September 5 Share September 5 (edited) Ah ma parts with her RX7 of 25 years. Edited September 5 by Davidklt 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic September 5 Share September 5 On 9/5/2025 at 8:44 PM, Davidklt said: Ah ma parts with her RX7 of 25 years. This is an MT RX8 ↡ Advertisement Link to post Share on other sites More sharing options...
Win a Limited-Edition Mazda RX-7 Diecast in Sgcarmart livery!
'Surrounded by love': Ozzy Osbourne dies, aged 76
Death of a Soccer Legend : Pele Passed Away at 82
Lancia returns to rallying with an electric Delta Integrale
Carlos Kaiser... Legend for the wrong reasons
Nets Cashcard Transaction History Legend
The legend - 金庸 RIP
The legend - 金庸 RIP
