Elfenstar 3rd Gear May 13, 2011 Share May 13, 2011 Just a link to a lifehacker page which will teach you how to do some stuff a lot of people don't know about Android & iPhone How To's ↡ Advertisement Link to post Share on other sites More sharing options...
Happily1986 5th Gear October 27, 2011 Share October 27, 2011 If you find yourself using your Android phone's GPS facility frequently then you will find my post useful. basically i have compiled a self help DIY which will help you to acquire faster and more accurate GPS locks. This method works for all ROMs for Gingerbread only 2.3.x I have managed to acquire GPS locks under a minute at the windowside (indoors) with an accuracy of 6 to 8m. This is taken from my own thread at xda forums. My Thread Before you continue further, here are the prerequisites 1.) Root permissions 2.) Root explorer or similar file manager with root access Please google on how the GPS transceiver in your Ace works. Basically what i am doing is to change the ntp time servers that your Ace contacts. You will be tasked to change the time servers to those which are physically closer to your current location. Why? Because before the GPS transceiver is able to establish the rough position(s) of the satellite, it needs to contact time servers. Also, Skyhook (again please google) and A-GPS will enabled in your gps.conf that will help your Ace acquire GPS locks more quickly. There are two files that you need to acquire from here. gps.conf and secgps.conf gps.conf Code: NTP_SERVER=0.sg.pool.ntp.org NTP_SERVER=0.asia.pool.ntp.org NTP_SERVER=3.asia.pool.ntp.org XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin XTRA_SERVER_4=http://xtra4.gpsonextra.net/xtra.bin INTERMEDIATE_POS=0 ACCURACY_THRES=0 DEBUG_LEVEL=3 ENABLE_WIPER=0 ENABLE_XTRA=TRUE SUPL_HOST=supl.google.com SUPL_PORT=7276 SUPL_SECURE_PORT=7275 SUPL_NO_SECURE_PORT=3425 SUPL_HOST=supl.skyhook.com SUPL_PORT=7278 CURRENT_CARRIER=common #REPORT_POSITION_USE_SUPL_REFLOC=1 DEFAULT_AGPS_ENABLE=TRUE DEFAULT_SSL_ENABLE=FALSE DEFAULT_USER_PLANE=TRUE #START_MODE=WARM #OPERATION_MODE=STANDALONE PHONE_TYPE=UMTS Instructions: Observe that in the top most section of the code there is the line "NTP_SERVER=". I want you to go to this website http://www.pool.ntp.org/en/, click on your country and find the list of NTP servers that can be used. For e.g. for my case in Singapore it will be 0.sg.pool.ntp.org 0.asia.pool.ntp.org 3.asia.pool.ntp.org Next, insert the servers which you have just copied onto the line "NTP_SERVER=" immediately after the = without the quotations. Please verify by using cmd in Windows to ensure that the time servers you have chosen are active and online. Just simply do a ping and a tracert. Note: if you find the ping times are ridiculous, you can opt to use the continental time servers e.g. i can use Asia NTP servers instead. Good ping times are about 20ms or less. Ok, now copy and paste the whole code (which you have inserted your new NTP servers earlier on) onto Notepad and saved as gps.conf (all files instead of .txt) Copy and paste this gps.conf to overwrite the original gps.conf at /system/etc. Original gps.conf Code: NTP_SERVER=north-america.pool.ntp.org XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin SUPL_HOST=supl.google.com SUPL_PORT=7276 PHONE_TYPE=UMTS secgps.conf Code: #Generated by GpsLocationProvider. #Thu Dec 02 13:09:21 EST 2010 SSL=1 SSL_TYPE=0 POSITION_MODE=7 OPERATION_TEST_MODE=0 ACCURACY=50 SESSION_TYPE=1 SERVER_MODE=0 ENABLE_NMEA=false START_MODE=HOT GPS_LOGGING=0 AGPS_MODE=0 DYNAMIC_ACCURACY=1 ADDRESS_MODE=1 TIME_BTW_FIX=2000 OPERATION_MODE=MSBASED USE_DEFAULT=true DYNAMIC_ACCURACY_VALUE=50 SUPL_PORT=7276 ENABLE_XTRA=true SUPL_HOST=supl.google.com NUM_OF_FIX=999999999 TIMEOUT=3600Instructions: Copy and paste the code above for secgps.conf onto Notepad and save as secgps.conf (all files type instead of .txt) Use Root explorer to copy and paste this file in /data/gps. ================================================== ================================================== ===================================== I was inspired by the thread over here http://forum.xda-developers.com/show....php?t=1034631 My motivation to do up my gps.conf and secgps.conf is partly of the fact that PFGPS fix didn't work for me and configuring the GPS using the secret code ie *#*#1472365#*#* didn't work as well. Please don't blame me if this breaks anything. I have tested this on my system and i got a GPS lock by the windowside (indoors) under a minute. Accuracy is 6~8m which i thought was impressive. it should work on all ROMs because i have tested this on a stock ROM, XXKPO. Note: if you have applied PFGPS fix, this WILL overwrite whatever settings PFGPS fix has made. Be warned. Link to post Share on other sites More sharing options...
Jman888 Moderator October 27, 2011 Share October 27, 2011 But AGPS need 3G data network to connect, will it still work without that? I find iPhone GPS faster in locating. Link to post Share on other sites More sharing options...
Blackyv Turbocharged October 28, 2011 Share October 28, 2011 If you find yourself using your Android phone's GPS facility frequently then you will find my post useful. basically i have compiled a self help DIY which will help you to acquire faster and more accurate GPS locks. This method works for all ROMs for Gingerbread only 2.3.x I have managed to acquire GPS locks under a minute at the windowside (indoors) with an accuracy of 6 to 8m. This is taken from my own thread at xda forums. My Thread Before you continue further, here are the prerequisites 1.) Root permissions 2.) Root explorer or similar file manager with root access Please google on how the GPS transceiver in your Ace works. Basically what i am doing is to change the ntp time servers that your Ace contacts. You will be tasked to change the time servers to those which are physically closer to your current location. Why? Because before the GPS transceiver is able to establish the rough position(s) of the satellite, it needs to contact time servers. Also, Skyhook (again please google) and A-GPS will enabled in your gps.conf that will help your Ace acquire GPS locks more quickly. There are two files that you need to acquire from here. gps.conf and secgps.conf gps.conf Code: NTP_SERVER=0.sg.pool.ntp.org NTP_SERVER=0.asia.pool.ntp.org NTP_SERVER=3.asia.pool.ntp.org XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin XTRA_SERVER_4=http://xtra4.gpsonextra.net/xtra.bin INTERMEDIATE_POS=0 ACCURACY_THRES=0 DEBUG_LEVEL=3 ENABLE_WIPER=0 ENABLE_XTRA=TRUE SUPL_HOST=supl.google.com SUPL_PORT=7276 SUPL_SECURE_PORT=7275 SUPL_NO_SECURE_PORT=3425 SUPL_HOST=supl.skyhook.com SUPL_PORT=7278 CURRENT_CARRIER=common #REPORT_POSITION_USE_SUPL_REFLOC=1 DEFAULT_AGPS_ENABLE=TRUE DEFAULT_SSL_ENABLE=FALSE DEFAULT_USER_PLANE=TRUE #START_MODE=WARM #OPERATION_MODE=STANDALONE PHONE_TYPE=UMTS Instructions: Observe that in the top most section of the code there is the line "NTP_SERVER=". I want you to go to this website http://www.pool.ntp.org/en/, click on your country and find the list of NTP servers that can be used. For e.g. for my case in Singapore it will be 0.sg.pool.ntp.org 0.asia.pool.ntp.org 3.asia.pool.ntp.org Next, insert the servers which you have just copied onto the line "NTP_SERVER=" immediately after the = without the quotations. Please verify by using cmd in Windows to ensure that the time servers you have chosen are active and online. Just simply do a ping and a tracert. Note: if you find the ping times are ridiculous, you can opt to use the continental time servers e.g. i can use Asia NTP servers instead. Good ping times are about 20ms or less. Ok, now copy and paste the whole code (which you have inserted your new NTP servers earlier on) onto Notepad and saved as gps.conf (all files instead of .txt) Copy and paste this gps.conf to overwrite the original gps.conf at /system/etc. Original gps.conf Code: NTP_SERVER=north-america.pool.ntp.org XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin SUPL_HOST=supl.google.com SUPL_PORT=7276 PHONE_TYPE=UMTS secgps.conf Code: #Generated by GpsLocationProvider. #Thu Dec 02 13:09:21 EST 2010 SSL=1 SSL_TYPE=0 POSITION_MODE=7 OPERATION_TEST_MODE=0 ACCURACY=50 SESSION_TYPE=1 SERVER_MODE=0 ENABLE_NMEA=false START_MODE=HOT GPS_LOGGING=0 AGPS_MODE=0 DYNAMIC_ACCURACY=1 ADDRESS_MODE=1 TIME_BTW_FIX=2000 OPERATION_MODE=MSBASED USE_DEFAULT=true DYNAMIC_ACCURACY_VALUE=50 SUPL_PORT=7276 ENABLE_XTRA=true SUPL_HOST=supl.google.com NUM_OF_FIX=999999999 TIMEOUT=3600Instructions: Copy and paste the code above for secgps.conf onto Notepad and save as secgps.conf (all files type instead of .txt) Use Root explorer to copy and paste this file in /data/gps. ================================================== ================================================== ===================================== I was inspired by the thread over here http://forum.xda-developers.com/show....php?t=1034631 My motivation to do up my gps.conf and secgps.conf is partly of the fact that PFGPS fix didn't work for me and configuring the GPS using the secret code ie *#*#1472365#*#* didn't work as well. Please don't blame me if this breaks anything. I have tested this on my system and i got a GPS lock by the windowside (indoors) under a minute. Accuracy is 6~8m which i thought was impressive. it should work on all ROMs because i have tested this on a stock ROM, XXKPO. Note: if you have applied PFGPS fix, this WILL overwrite whatever settings PFGPS fix has made. Be warned. So troublesome and technical..... luckily my desire with papago could lock down in less than 20sec most of the time....and if lucky, less than 5sec occasionally .... Link to post Share on other sites More sharing options...
Happily1986 5th Gear October 28, 2011 Share October 28, 2011 But AGPS need 3G data network to connect, will it still work without that? I find iPhone GPS faster in locating. yes because A GPS is just used initially for the phone to establish the rough positions of the various satellites during a warm startup. otherwise, time is wasted to do random polling in order to search for satellites Link to post Share on other sites More sharing options...
Happily1986 5th Gear October 28, 2011 Share October 28, 2011 So troublesome and technical..... luckily my desire with papago could lock down in less than 20sec most of the time....and if lucky, less than 5sec occasionally .... Good for you then. Well, just sharing for those who are keen. *Shrugs Link to post Share on other sites More sharing options...
Jman888 Moderator October 28, 2011 Share October 28, 2011 yes because A GPS is just used initially for the phone to establish the rough positions of the various satellites during a warm startup. otherwise, time is wasted to do random polling in order to search for satellites not good for overseas if no network (data roaming very expensive!), last i went to Perth with the Navfone on iphone without data connection, very fast and accurate. Link to post Share on other sites More sharing options...
Happily1986 5th Gear October 28, 2011 Share October 28, 2011 not good for overseas if no network (data roaming very expensive!), last i went to Perth with the Navfone on iphone without data connection, very fast and accurate. If you check no roaming in Settings, then that will automatically override AGPS because data cannot be sent over GPRS/3G/HSDPA. Under my gps.conf, i have configured the GPS transceiver to use not just AGPS but also SUPL (Secure User Plane Location) and also Skyhook. I have not tested when overseas though. Link to post Share on other sites More sharing options...
Aimnfire 4th Gear October 28, 2011 Share October 28, 2011 search for fasterfix in market Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged October 28, 2011 Share October 28, 2011 Thanks for sharing.. but I don't really wanna root my phone.. very tedious procedure ↡ Advertisement Link to post Share on other sites More sharing options...
Android Phones
Android Phones
Oppo Mobile Phone Discussion Thread
Mirrorlink vs Apple CarPlay vs Android Auto.
Android’s emergency call shortcut is flooding dispatchers with false calls
Huawei Mate 20 Pro / Leica Camera
iphone screen time n app limit not working on instagram
IPhone Chinese Ringtones
Machtig Android Player / Head Unit - Anyone here using
