Octopus 3rd Gear October 9, 2005 Share October 9, 2005 Bro, the difference between 195/55 R15 and 195/50 R15 is more than 3% difference in overall diameter, which is not recommended. Its better to maintain the overall diameter within 3% of your original tyre size. ↡ Advertisement Link to post Share on other sites More sharing options...
Kinetics Neutral Newbie October 10, 2005 Share October 10, 2005 Hi May I know the reason why within 3%? As I'm thinking of changing from 65 to 55. Tks Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 10, 2005 Share October 10, 2005 Read here: http://www.1010tires.com/tech.asp?type=wheels#plussizing According to info from the net, wrong sizing (overall diameter) will cause problem to transmission system, braking system, speedometer and odometer will be inaccurate....if possible, better to keep it within 3% difference. You can use the calculator here: http://www.1010tires.com/TireSizeCalculator.asp to help you determine what are the different sizes available. Link to post Share on other sites More sharing options...
Kinetics Neutral Newbie October 10, 2005 Share October 10, 2005 Thanks. Just curious what happen to those car with normal stock profile tyres but change to low profile type aftermarket? Tks Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 10, 2005 Share October 10, 2005 There's a specific procedure to follow for such case.....for example: 175/70 R13 vs 185/60 R14 vs 195/50 R15 all have very close overall diameter, but rim size is different. Preferably should not upgrade more than +2 sizing. Read more from the website I had quoted in my post earlier and it should explain how to upgrade your rim size properly. You can also use the 'calculator' I had posted earlier to see which combination allows similar overall diameter compared to your original tyre size. Link to post Share on other sites More sharing options...
Genie47 1st Gear October 10, 2005 Share October 10, 2005 Use the Ejelta one stickied. Lists a whole set of sizes you can change to. Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 10, 2005 Share October 10, 2005 Thanks. That's a useful tyre calculator too. Link to post Share on other sites More sharing options...
Kinetics Neutral Newbie October 10, 2005 Share October 10, 2005 Thank you all. If I stick to within 2-3% but go for lower profile but wider size, will this increase my FC? Tks for tolerating my newbie qns Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 10, 2005 Share October 10, 2005 Don't worry about the increase in FC cos it will be rather minor. I've personally switched from 175/70 R13 to 195/50 R15 and didn't noticed and notable increase in FC. The plus points is that the ride after changing tyre & rims size is that feedback from road surface is more noticeable, and cornering much better. Link to post Share on other sites More sharing options...
Kinetics Neutral Newbie October 10, 2005 Share October 10, 2005 Thank you, I'm glad to hear that as the tyre shop people told me that FC will increase and with the current petrol prices......sigh Link to post Share on other sites More sharing options...
Dennisk Clutched October 10, 2005 Share October 10, 2005 currently mine is 185/65/14...so which should i choose? any good tyres to recommend? Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 10, 2005 Share October 10, 2005 It depends on your requirement. Do you prefer grip or comfy/quiet tyres? Link to post Share on other sites More sharing options...
Dennisk Clutched October 10, 2005 Share October 10, 2005 erm....6/10 for grip 4/10 for comfort...what about ZIEX-512? i read the specs...it "seems" good to me...not sure too... Link to post Share on other sites More sharing options...
Kaiserdome 1st Gear October 10, 2005 Share October 10, 2005 I find 512 noisy and poor on wet Link to post Share on other sites More sharing options...
Dennisk Clutched October 10, 2005 Share October 10, 2005 erm...if compare to ST115? or any better tyres out there? Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 10, 2005 Share October 10, 2005 I've never used ZEIX 512 before, but read somewhere that it got good grip in dry and wet, but noise will increase gradually.... If you really aiming for 512, perhaps you can try getting some quotes from other tyre shops, cos I think Stamford Tyre's pricing for 512 is higher. Link to post Share on other sites More sharing options...
Dennisk Clutched October 10, 2005 Share October 10, 2005 erm...not really aiming for that...haven't really settle my mind set which should i get... Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 10, 2005 Share October 10, 2005 Here's some website on tyres to help you in deciding your tyre choices. But some of the model are not available in S'pore.... http://www.1010tires.com/tires.asp http://www.tirerack.com/tires/index.jsp http://www.blackcircles.com/tyres_uk ↡ Advertisement Link to post Share on other sites More sharing options...
New Ford Mondeo
New Ford Mondeo
Bridgestone Re004 Users
Bridgestone Potenza S007a
Bridgestone Ecopia EP300. New Eco Tyre.
