K2000 Neutral Newbie August 26, 2005 Share August 26, 2005 does it mean the crossover is useless if i wanna run active for my front component? ↡ Advertisement Link to post Share on other sites More sharing options...
Wankie Clutched August 26, 2005 Share August 26, 2005 u mean your spkr x-over? usually yes unless the spkr x-overs are active x-overs. i think most of the ppl here who r running active use the HU's x-over, so you will have to get an HU with digital x-over function. someone pls correct me if i'm talking rubbish Link to post Share on other sites More sharing options...
K2000 Neutral Newbie August 26, 2005 Share August 26, 2005 walau...then the HU must be super expensive type? Link to post Share on other sites More sharing options...
Wankie Clutched August 26, 2005 Share August 26, 2005 i think about $500 onwards (export set pricing). think the pioneer 7650 or alpine 9851 onwards shld have...i'm assuming you have looked at both passive & active setups before wanting to try active?? Link to post Share on other sites More sharing options...
K2000 Neutral Newbie August 26, 2005 Share August 26, 2005 $500 still ok leh, got other cost or not? I am now in passive setup, will there be a big difference if i upgraded to active? Link to post Share on other sites More sharing options...
Wankie Clutched August 26, 2005 Share August 26, 2005 a lot of other costs... antidote for poison will kill you liao dunno, not interested to try active for the time being. speak to your installer lor or ask thhose who are currently running active Link to post Share on other sites More sharing options...
K2000 Neutral Newbie August 26, 2005 Share August 26, 2005 okok, thanks, think i will boost my current setup before i think of running active Link to post Share on other sites More sharing options...
Sunny9036 Neutral Newbie September 9, 2005 Share September 9, 2005 i am selling away my 4ch amp and a MB Quart 6.5comp.. if interested, audit my set up first b4 deciding.. contact me at 91114047 Link to post Share on other sites More sharing options...
Coupe07 Neutral Newbie September 9, 2005 Share September 9, 2005 how much are u letting go ur MB quartz 6.5comp?? Link to post Share on other sites More sharing options...
Sunny9036 Neutral Newbie September 10, 2005 Share September 10, 2005 pls sms me for more detail..thks Link to post Share on other sites More sharing options...
Darkness Neutral Newbie September 10, 2005 Share September 10, 2005 Hi dude...currently i have 1 amp (JBL CS50.4) powering my front 2 speakers jbl 6000 GTO (i think) and my single 12" cevin vega woffer. The rear speakers are stock and are powered by the HU. At very high volumes i end up getting craking (ie the voice starts to break music gets cranky like poorly tuned radio). Will the adding of a seperate amp to power the woffer, then use the current amp to power the 4 speakers be a good idea? ie HU will not power anything. 1 amp (2 channel) power the woffer and 1 amp (4 channel) power the 4 speakers. Thanks dude. Link to post Share on other sites More sharing options...
Headshok 1st Gear September 10, 2005 Share September 10, 2005 hey hey. i tink ur problem is due to ur stock speakers being lousy. i had the same problem my stock speakers were like paper like tat.. if u add another amp to power ur stock speakers, it'll prob still distort.. if u wanna blast and blast, best change ur rear speakers too lah.. cheers man.. Link to post Share on other sites More sharing options...
Darkness Neutral Newbie September 10, 2005 Share September 10, 2005 but the cracking i observe is not from the rear speakers only. It seems to be uniform. Like as if there is no more juice to feed the all the spakers or like the HU cannot take it anymore...lol.... wat is a relativly good speaker to put for the rear since i just need it as a fill and not for really for the sound quality (i hope i am not confusing u here ) looking at within 50-100 max. I guess it will be 3 way speakers? Also my tweeters are super bright at high volumes...even sometimes at low volumes...anyidea how i can overcome this with minimal hardware changes? My treble is at the minimum liao thanks... Link to post Share on other sites More sharing options...
Headshok 1st Gear September 10, 2005 Share September 10, 2005 huh.. u try to fade ur sound to the front, see whether ur front got distort or not.. if coming from the front too, go and turn down the gain on ur amp.. then play around with ur vol control.. mix and match until u reach a satisfyin level..if u got an external EQ, then play around with that too.. as for rear speakers, if got crack, means thay buay tahan.. for changin of rear speakers, just go down sim lim and look ard lah, got a lot of speakers.. since u say ur tweeters on the bright side, wat HU are u usin? if u are using the new SONY ones, there is this DSO function.. OFF IT!! cos last time i kena also.. can die man.. but if don have, see whether ur HU got small EQ, and play ard with the high freqs until u happy lah.. just play around with ur HU.. see what u can do.. if got nothin, look at ur cross over, see whether for the 'tweeter' output, got the different db levels... have fun man with ur setup man.. cheers.. Link to post Share on other sites More sharing options...
Darkness Neutral Newbie September 10, 2005 Share September 10, 2005 hee hee thanks man...well HU is stock, factory fitted - VDO tuner list so not much to play ard with hummm...crossover...that one can tune is it? hummmm.... hee hee maybe i should attend one of ur ICE meets and u can help me tune? lol I shall try wat u said abt fading the music to the front and isolate the cracking first for now... thanks Link to post Share on other sites More sharing options...
Headshok 1st Gear September 10, 2005 Share September 10, 2005 heheh.. cos some cross overs can adjust the tweeter one.. aniway.. for the moment, just isolate where the crackin is coming from. if comin from the front, adjust down the gain on the amp and mix and match with the vol control until u happy lah.. drop by the meetup la.. we see wat can be done to help u out.. heheh.. u go read the manual first lah. heehh.. never play with VDO b4.. heheh.. my stock HU got EQ one.. heheh.. so don look down on urs.. heheh.. cheers man. Link to post Share on other sites More sharing options...
Jamesgetz 4th Gear September 12, 2005 Share September 12, 2005 is your JBL CS50.4 50W max per channel? the cracking at high vol is prob due to insufficient power of the amp... the newer HUs are already 55W max per channel Link to post Share on other sites More sharing options...
Kwongwing Neutral Newbie September 12, 2005 Share September 12, 2005 If u r coming to the ICE meet-up, do bring yr mauals too so that we can see what the specs and features r for yr HU. See ya ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
Mitsubishi Space Star
BudgetMealGoWhere Portal
Sim Ann shares details of her budget meal after netizens slammed her in a previous Facebook post
SGD 300,000 budget for a used car... 740i or Panamera or ?
