Workshop to install Window Visors
Zakuii
beri simple to do, 1st u sort out the visor by placing against the relevant window.
next you wash down the area to stick to make sure it is clean and apply soapy water to the location to stick.
next, you remove the sticker backing strip up to 50mm long both ends, and twist them up
place visor against the door. pull the strip up and away, top 1st towards middle of visor, follow by the bottom end. remember to press down as it will slip due to soapy water.
hold in place for at least 3 minutes or so.
repeat as needed and lastly, do not drive after installing, best to do it at night.
thanks for the tips. if it is a stick on, i'd gladly do it myself. but the visors came with clip as well, so not comfortable installing it. however, finally installed it myself after receiving tips from how to remove the rubber lining from the window frame.
got clips arh...lagi simple lah.
easier to install, btw, u driving Jazz?
Edited by Apollo
