Tploh Clutched November 20, 2005 Share November 20, 2005 My left head lamp seems to have mist / water inside. There seems to be a leak on the sealing of the head lamp. What can I do ? ↡ Advertisement Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear November 22, 2005 Share November 22, 2005 Just one thing actually. leave it for a few day for the vapour to evaporate. This is mainly due to the headlight is not water-tight. (maybe by design or workmanship) Frankly saw that happen to KIA and HONDA too. (esp the Euro Accord) I think most of the Euro Accord use to have this problem (saw that in Singapore and also macau) Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear November 23, 2005 Share November 23, 2005 Bro, if your ride is still under warranty you can bring it back to the agent and demand for a replacement Remember to take photos of it first and show it to them Link to post Share on other sites More sharing options...
Fisherman Neutral Newbie November 24, 2005 Share November 24, 2005 Why muz take photos first le.. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear November 24, 2005 Share November 24, 2005 Take photo first is just in case that when you go to the agent's place the next day or next moment and the mist inside your head lamp happened to dry up liao at least you still have evidence to show them Link to post Share on other sites More sharing options...
Spikedoll Clutched July 4, 2006 Share July 4, 2006 one of my fog lights also has mist...can't seem to evaporate and dry up .. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear July 4, 2006 Share July 4, 2006 my passenger side fog light also have water. But not in the bulb region, its flushed with the bumper with a peice of clear plastic. inside wet even when it never rains. Noticed it after expressway sxxt created a hole beneath my foggies Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 4, 2006 Share July 4, 2006 My left head lamp seems to have mist / water inside. There seems to be a leak on the sealing of the head lamp. What can I do ? Well fastest way to clear it is to remove all the bulbs and use a hair dryer on low heat. Be careful not to melt the black plastic. blow for a short while then stop and repeat till the headlamp is clear again. Also check that the U shaped rubber "hose" attached to the drain hole is there (yes you read right, all headlamps are not 100% sealed!!!). If its not its very easy for water to enter. If thats still there then the headlight isnt sealed properly and water is entering from another "hole" between the clear bit and the black plastic. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 4, 2006 Share July 4, 2006 zyro can't be helped... his is between the foggie and the plastic protector. in your case, check that the U shaped rubber bit is still attached to the back. other than the projector ones, every OE foglamp other than the mini's bumper mounted ones i've seen has a drain hole as well. Link to post Share on other sites More sharing options...
Godibado Neutral Newbie July 5, 2006 Share July 5, 2006 im facing the sam eprob. they will change izit? ok datz nice Link to post Share on other sites More sharing options...
Godibado Neutral Newbie July 5, 2006 Share July 5, 2006 oh yeah n tanx! Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear July 5, 2006 Share July 5, 2006 My left head lamp seems to have mist / water inside. There seems to be a leak on the sealing of the head lamp. What can I do ? Years ago my honda civic also like that after just 3 months. I went back to KM and bang tables n they replaced the rubber rim n then ok liao Link to post Share on other sites More sharing options...
Aaronlkl Supersonic April 1, 2015 Share April 1, 2015 Any remedy to headlight fogging? 1 Link to post Share on other sites More sharing options...
tyco_kia 4th Gear April 1, 2015 Share April 1, 2015 Any remedy to headlight fogging? There is a thread of one of the merchants here. Suppose you can give him a call. http://www.mycarforum.com/topic/2693831-dr-glass/ Link to post Share on other sites More sharing options...
Aaronlkl Supersonic April 1, 2015 Share April 1, 2015 There is a thread of one of the merchants here. Suppose you can give him a call. http://www.mycarforum.com/topic/2693831-dr-glass/ Thx bro. Appreciate it! 5 Link to post Share on other sites More sharing options...
Kchew21 1st Gear April 1, 2015 Share April 1, 2015 Hi: U can drill one or two small holes below the the headlight plastic casing...this way no mist trapped inside. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
Citroen C4 1.2 Sensor & Display
