Dennisk Clutched January 19, 2006 Share January 19, 2006 (edited) remember to ground to the base of ECU. Tks, why i din tot of it oso. you did yours already? i haven't ground to the base of ECU yet... Edited January 19, 2006 by Dennisk ↡ Advertisement Link to post Share on other sites More sharing options...
Normal_aspirated Clutched January 19, 2006 Share January 19, 2006 you did yours already? i haven't ground to the base of ECU yet... not yet........later. Link to post Share on other sites More sharing options...
Dennisk Clutched January 19, 2006 Share January 19, 2006 maybe during meetup... Link to post Share on other sites More sharing options...
Sujoy Neutral Newbie January 19, 2006 Share January 19, 2006 PISCES69, what gauge you used? 4? 8? Link to post Share on other sites More sharing options...
Katou Neutral Newbie January 20, 2006 Share January 20, 2006 Bro.. u noe how to DIY? mind to DIY for me? i don't mind paying labour fee to u as outside market rate damn high.. =) Link to post Share on other sites More sharing options...
Sujoy Neutral Newbie February 19, 2006 Share February 19, 2006 Do you guys add on the new ground cables to the existing factory ones, or removed the factory ones totally? Link to post Share on other sites More sharing options...
Apollo 1st Gear February 19, 2006 Share February 19, 2006 add Link to post Share on other sites More sharing options...
York Clutched February 19, 2006 Share February 19, 2006 grounding can improve what?? btw, me driving lorry.. possible to ground?? i think i am going to be the first lorry to try grounding.. what is ECU?? lorry boh ECU lah....using the convertional rotary pump for ur injectors. Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear February 19, 2006 Share February 19, 2006 like that means cannot ground ar?? Link to post Share on other sites More sharing options...
Reneson Neutral Newbie February 20, 2006 Share February 20, 2006 mi quite new here, i just got my ride a 1.3 auto car two week ago. do i need to wait till run-in before doing the grounding work does grounding make any different for auto car? Link to post Share on other sites More sharing options...
Yc86 Clutched February 20, 2006 Share February 20, 2006 so long as the engine is touching your body (still in your car), and you have a wire going to the negative battery.. your car is grounded. grounding just reduces charge buildup caused when things (engine, alternators, motors) rotate.. which may interfere with electrical components am i right? Link to post Share on other sites More sharing options...
York Clutched February 20, 2006 Share February 20, 2006 diesel engine...grounding...wat for... does'nt ve a ignition firing system...high tension coil..etc..etc Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear February 21, 2006 Share February 21, 2006 i know nuts about the engine sia.. only know, pour diesel in fuel tank.. turn the key and the engine is running liao.. Link to post Share on other sites More sharing options...
Civic2004 Neutral Newbie February 23, 2006 Share February 23, 2006 Some cars have two ground 1)engine and 2)battery, which are not connected together. ↡ Advertisement Link to post Share on other sites More sharing options...
Grounding VS Voltage stabalizing
HKS grounding kit
HKS grounding kit
Need advice on grounding for Pivot Mega Raizin kit
Grounding useful?
Grounding useful?
Spiltfire Dspark Grounding for ignition with noise filter
Grounding/Earthing the Car
Toyota/Nissan/Mazda/Daihatsu/Non-Jap Car with Xtra Grounding Take Note!!!
What's the advantage of grounding the car?
