Mivec9 1st Gear January 14, 2006 Share January 14, 2006 did it recently at around $280 inclusive of clutch cable..guess w/o the cable shd be $250. ↡ Advertisement Link to post Share on other sites More sharing options...
Rustyz 5th Gear January 16, 2006 Share January 16, 2006 The piping is leaking according to Workshop..got it fixed Link to post Share on other sites More sharing options...
Dennisk Clutched January 19, 2006 Share January 19, 2006 Full face race clutch plates are usually not for high hp applications. Probably good up to 250hp. Stock tranny should be able to handle 250. If you're making in excess of 350hp, then you gotta drive conservatively. Have a friend broke 2nd gear on his super charged S2K tunned to slightly above 350hp @ wheel. Thats from hard launch shifting. The strength of your tranny depends on what your car's stock power. Jap cars usually have parts rated to handle power slightly more than stock. US and European domestic cars usually have alot stronger parts. If you're making so much power that you run the risk of breaking gears, its also a good idea to get beefier axals and stiffer motor mount bushings as well. so for NA car, we can go for full face race clutch plates? what actually we need to change? Link to post Share on other sites More sharing options...
BlueSi Neutral Newbie January 20, 2006 Share January 20, 2006 If its a daily driver, not putting out crazy amount of torque, yes a full face race is the way to go. You can go online and look for clutch kits for your car. The companies making them will tell you which one will best suit your needs and you can mix and match clutch disk, pressure plates and flywheel. I suggested changing the pressure plate and flywheel as well simply coz when you're doing a clutch job, your tranny is already pulled and to reach the disk, the pressure plate would need to be removed anyways, and the flywheel will be in full view, so why not just get everything and change everything at once? Save on the labor cost to pull everything out again next time. Link to post Share on other sites More sharing options...
Dennisk Clutched January 20, 2006 Share January 20, 2006 does it cost more than 1k for all these changes? Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie January 20, 2006 Share January 20, 2006 Depends on what your after. My Exedy or AVO clutch cost $1050AUD. AVO flywheel 7.7kg (stock 14) at $750AUD, Pressure plate unknown ... Mech require 1-2 days to tune both flywheel and clutch to work in harmony. If you are after factory components it'll be cheaper but I'm sure parts and labour will most likely exceed the $1k region ? Link to post Share on other sites More sharing options...
BlueSi Neutral Newbie January 20, 2006 Share January 20, 2006 My clutct and pressure plate was in the region of $500+ and flywheel around $170. Labor was expensive ... I think its a standard 5h job so around $300. So my total came up to be around $1000 .... USD Hopefully labor cost will be cheaper there. Or you can try doing it urself? It'll take anywhere from a wkend to a week since u are limited in equiptment and experience, the time depends on how fast u can solve problems when u screw things up. I've tried it on a friend's car ... tranny jobs really suck! just bring it to a shop. Link to post Share on other sites More sharing options...
Dennisk Clutched January 21, 2006 Share January 21, 2006 can i just change flywheel alone? those lighten one... Link to post Share on other sites More sharing options...
Normal_aspirated Clutched January 21, 2006 Share January 21, 2006 (edited) bro, going the darkie side liao........ too much power cannot handle oredi.......need racing or heavy duty clutch. [sly] Edited January 21, 2006 by Normal_aspirated Link to post Share on other sites More sharing options...
Dennisk Clutched January 21, 2006 Share January 21, 2006 erm......was trying to learn new things... Link to post Share on other sites More sharing options...
Sujoy Neutral Newbie January 21, 2006 Share January 21, 2006 Adjusting clutch diy anyone? Link to post Share on other sites More sharing options...
Mivec9 1st Gear January 22, 2006 Share January 22, 2006 The piping is leaking according to Workshop..got it fixed how's the damage?? Link to post Share on other sites More sharing options...
Mivec9 1st Gear January 22, 2006 Share January 22, 2006 wahz...diy....think need experience diyers... Link to post Share on other sites More sharing options...
stevenzhu1981 Neutral Newbie November 7, 2023 Share November 7, 2023 it's better to replace pneumatic clutch actuator together with the clutch cover and disc,we often buy from online www.tzclutch.com/6482000155,then bring it to the workshop,haha Link to post Share on other sites More sharing options...
Gnahp Twincharged November 8, 2023 Share November 8, 2023 wah, pneumatic actuation what car is that? ↡ Advertisement Link to post Share on other sites More sharing options...
Clutch for Volvo V40 T4 2013 Price?
Clutch Problem - Hyundai Avante
Kia Cerato Clutch Issue
Need to replace clutch???
2013 Manual Honda Accord with clutch issues
RPM goes up but Speed goes down
