Orixy 2nd Gear February 11, 2006 Share February 11, 2006 Guys, went to Carrefour Suntec yestrday and saw STP Injector Cleaner on sales at $6.90 per bottle. Got lotsa stock left on the shelf. Best price I've ever bought before was $6.50 but that shop closed down already... So $6.90 is IMO a very good price to grab a few bottles if you do use this. ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 12, 2006 Share February 12, 2006 Injector cleaner that you put into the tank is a double edge sword - it can help you clean , it can also chok up your fuel system if your tank is full of sediment and rust. Link to post Share on other sites More sharing options...
Ngck 3rd Gear February 12, 2006 Share February 12, 2006 or for the better or worse? better for newer cars because less rust/sediments? Link to post Share on other sites More sharing options...
Apollo 1st Gear February 12, 2006 Share February 12, 2006 how is tat so? since the fuel injectors r by themselve very clean unless they r dirty, they can't bring more sediments, can they? i would say neber pump in any station if u see a petrol truck there. tat's the time when the sediments is stirred up when the new fuel is pumped into the storage tank below. Link to post Share on other sites More sharing options...
Stary Turbocharged February 12, 2006 Share February 12, 2006 how does it choke up your fuel system? Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 13, 2006 Share February 13, 2006 (edited) If you have the opportunity to look into a fuel tank of five years old car and the fuel pump sediment filter you will have a better idea of why injector cleaner will cause more harm than good. Get hold of a used in-line fuel filter and cut it open and you will see the amount of sediment and foreign particles inside. Edited February 13, 2006 by Yeobh Link to post Share on other sites More sharing options...
Dwoon 1st Gear February 13, 2006 Share February 13, 2006 So, does it mean that .... do the injector treatment only when the car is due for fuel filter replacement? Link to post Share on other sites More sharing options...
Stary Turbocharged February 13, 2006 Share February 13, 2006 well, that has to do with dirty fuel.....what has it got to do with the cleaner? The cleaner cleans the injector head. That's already after the fuel filter. Or are u saying that the cleaner itself is dirty? Link to post Share on other sites More sharing options...
Genie47 1st Gear February 13, 2006 Share February 13, 2006 No need actually. I just replaced my inline fuel filter. I did a "reverse flush" and all kinds of stuff came out. Link to post Share on other sites More sharing options...
Genie47 1st Gear February 13, 2006 Share February 13, 2006 Its solvent that loosens up stuff in the tank as well because you dump the cleaner into the tank. Link to post Share on other sites More sharing options...
DarkLord 1st Gear February 13, 2006 Share February 13, 2006 Regular change of fuel filter helps? I just changed mine at 40K.. Looking at the filter.. I reckoned change at every 20K will not be overkill.. Link to post Share on other sites More sharing options...
Genie47 1st Gear February 13, 2006 Share February 13, 2006 Actually no. You don't clean injectors unless you experience loss of power and all that sort of symptoms that tells you the fuel system needs servicing. Then again, you pray that it is not the fuel system because to clean injectors, you need to hire a professional that knows injectors and take them out for ultrasonic cleaning. Even with carburation, I pray that it is not the carburetor acting up because it costs a bomb just to service the carburetor. Injectors no need to say. Finally, usually fuel delivery systems are usually hard to clog up or spoil unless your fuel is very very poor quality like in former East Germany or now North Korea. If anyone experiences loss of power or anything like that, my first suspect is never the fuel delivery but the ignition. That is easier to fix and troubleshoot first. Link to post Share on other sites More sharing options...
Stary Turbocharged February 13, 2006 Share February 13, 2006 Is it expensive to change the fuel filter? I am not sure if SA had my Fuel filter change at 40K Link to post Share on other sites More sharing options...
DarkLord 1st Gear February 13, 2006 Share February 13, 2006 "Benefits" of JB petrol. Ehz, are you free to join us this Wed at West Coast? Link to post Share on other sites More sharing options...
Genie47 1st Gear February 13, 2006 Share February 13, 2006 (edited) Supposed to be every 30k. The inline filter is cheap at $9-10. You can DIY if you like. I know where it is but it will require resetting your ECU and all because you have to disconnect the battery for safety. Else get those memory savers from Yeobh. Edited February 13, 2006 by Genie47 Link to post Share on other sites More sharing options...
DarkLord 1st Gear February 13, 2006 Share February 13, 2006 The filter (Vios) costs me $30+.. Part of my 40K servicing menu but will do it at every 20K from now on.. Link to post Share on other sites More sharing options...
Stary Turbocharged February 13, 2006 Share February 13, 2006 I dun remember I was ever asked to pay for the fuel filter..... damn, maybe they didn't change. Link to post Share on other sites More sharing options...
Genie47 1st Gear February 13, 2006 Share February 13, 2006 (edited) I don't think it is JB petrol. Lukie's filter when back flushed also has very fine sediments in it. She gets her petrol locally. Might come on Wed. Edited February 13, 2006 by Genie47 ↡ Advertisement Link to post Share on other sites More sharing options...
Any recomendation for Robot cleaner??
SONAX rim cleaner
SONAX rim cleaner
Can those sales team survive with given transport allowance?
🚗🔥 The BIGGEST Black Friday Car Deals by Sgcarchoice Are Here! 🔥🚗
Mitsubishi to suspend sales in Singapore as revised emissions scheme set to downgrade some new cars
No more TikTok buys: Indonesian shoppers fret over higher prices as analyst says ban a ‘partial step’ to aid local firms
