Hlkh Clutched February 19, 2006 Share February 19, 2006 hi all i experience when i wanna slow down at 150km/h when i tap brake the is some virbration at the steering wheel, and some virbration in my bonnet. anyone encounter this? is this normal or got problem? ↡ Advertisement Link to post Share on other sites More sharing options...
Typhoon125 3rd Gear February 19, 2006 Share February 19, 2006 (edited) Your car's age? Anyway, have her check, shouldn't vibrate... Edited February 19, 2006 by Typhoon125 Link to post Share on other sites More sharing options...
Kelpie 2nd Gear February 19, 2006 Share February 19, 2006 It is ABS at work. Regards, Link to post Share on other sites More sharing options...
Koren Clutched February 19, 2006 Share February 19, 2006 hmm.. vibration of bonnet? how would u know? are you brakes worn out already? if one side of the brakes is worned out more than the other side.. u may feel vibrations on soft brakings.. Link to post Share on other sites More sharing options...
Typhoon125 3rd Gear February 19, 2006 Share February 19, 2006 Doubt taping brake will have abs kicks in... Link to post Share on other sites More sharing options...
Koren Clutched February 19, 2006 Share February 19, 2006 cant be abs if he's just tapping on the brakes.. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear February 19, 2006 Share February 19, 2006 (edited) 1. IMHO, depending how hard he tap the brake, how sensitive the ABS is and the road situation. I assume that the car has no vibration problem hitting 150km/h and above or when cornering. 2. If not ABS, probably there is a need to do high speed balancing. Remembered guys, sometimes back I started a thread on steering vibrate problem? Here you go: http://www.mycarforum.com/forum/Aftermarke...rates_P1187443/ 3. Must add that I'm no expert but just suggesting. Regards, Edited February 19, 2006 by Kelpie Link to post Share on other sites More sharing options...
Hlkh Clutched February 19, 2006 Author Share February 19, 2006 my is 04 lancer... now milage 39k Link to post Share on other sites More sharing options...
Hlkh Clutched February 19, 2006 Author Share February 19, 2006 but i nv jam brake... i just tap abit by bit to slow down Link to post Share on other sites More sharing options...
Hlkh Clutched February 19, 2006 Author Share February 19, 2006 you something like right wheel brake worn more then left wheel brake?? i tot both side shld be the same? Link to post Share on other sites More sharing options...
Koren Clutched February 19, 2006 Share February 19, 2006 should be... but due do circumstances like having one diskrotor wetter than the other @ times will cost uneven wear.. but veri rare.. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear February 19, 2006 Share February 19, 2006 The tyre shop guy told me once that it is common for larger wheels to have uneven wear and tear. Regards, Link to post Share on other sites More sharing options...
Vit4wd 1st Gear February 19, 2006 Share February 19, 2006 (edited) It is ABS at work. Regards, ABS at work happens only when you feel vibration on the brake pedal only. Bonnet and steering wheel not affected at all. Shd not have any vibrations at all. Could be wheel alignment problems if its steering wheel vibrating. Edited February 19, 2006 by Vit4wd ↡ Advertisement Link to post Share on other sites More sharing options...
Understanding Anti-lock Braking System (ABS)
Braking - "Croaking" Sound
Screeching sound when braking
Toyota Camry 2.0L (2007) Braking Issue
Ten automakers to make automatic braking a standard feature
Braking issue
Braking issue
Hel Steel Braided Brake Hose - Enhance your braking power
Issue on braking
Issue on braking
