Astro 1st Gear April 28, 2005 Share April 28, 2005 I'm driving an Auto car and every morning without fail the "frog" in my car will always "craok" when I apply the brake. Such as stopping on the red light and going off when it turn green. Or when I need to drive the car under raining eather the "frog" is back. But it eventually goes off after some time, I presume the "frog" had lost his voice after so much croaking. Do any of you guys know what is wrong or how to go about preventing it... Thanks for any advise. ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 6, 2005 Share May 6, 2005 Sound from where - front or back wheels. What type of rear brake system - disc or drum. Link to post Share on other sites More sharing options...
Osiris 1st Gear May 6, 2005 Share May 6, 2005 mine does. onli when release from stop or when wet. what is your ride? Link to post Share on other sites More sharing options...
Etayhm Neutral Newbie July 9, 2005 Share July 9, 2005 (edited) probably from the rear drum brake. previous car (skoda octavia ambiente) had the same groaning/croaking problem. most apparent in the morning because of condensation on rear drum brake pads. removing accumulated brake dust (i.e. brake service) helps to a certain extent. Characteristic of rear drum brakes. Edited July 9, 2005 by Etayhm Link to post Share on other sites More sharing options...
Cherrysour Neutral Newbie December 16, 2019 Share December 16, 2019 On 4/27/2005 at 8:31 PM, Astro said: I'm driving an Auto car and every morning without fail the "frog" in my car will always "craok" when I apply the brake. Did you ever figure out what this problem was? My car is doing the same thing, and my local mechanic doesn’t know what is wrong. Thanks. 🙂 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged December 16, 2019 Share December 16, 2019 1 hour ago, Cherrysour said: Did you ever figure out what this problem was? My car is doing the same thing, and my local mechanic doesn’t know what is wrong. Thanks. 🙂 new car or old? After market calipers or original? sometimes its consider normal depending on what u did to the car. If its cloak sound when you brake , its the pads or the caliper free play that is causing it. You need the expansion gap for expand and contraction. Link to post Share on other sites More sharing options...
Cherrysour Neutral Newbie December 17, 2019 Share December 17, 2019 (edited) 49 minutes ago, Sdf4786k said: new car or old? It’s a 6 year old car. We just had the rotors rotated and new brake pads put on to try to fix the sound. It didn’t help. The mechanic mentioned the rear differential motor assembly, but the sound only happens as I come to a complete stop and when I first release the brake. I don’t hear it at any other time. Edited December 17, 2019 by Cherrysour Link to post Share on other sites More sharing options...
Beregond Supersonic December 17, 2019 Share December 17, 2019 1 hour ago, Cherrysour said: It’s a 6 year old car. We just had the rotors rotated and new brake pads put on to try to fix the sound. It didn’t help. The mechanic mentioned the rear differential motor assembly, but the sound only happens as I come to a complete stop and when I first release the brake. I don’t hear it at any other time. tell them put some grease inside the caliper try first Link to post Share on other sites More sharing options...
Cherrysour Neutral Newbie December 17, 2019 Share December 17, 2019 1 hour ago, Beregond said: tell them put some grease inside the caliper try first I will! Thank you so much! Link to post Share on other sites More sharing options...
Xtrah 3rd Gear December 17, 2019 Share December 17, 2019 4 hours ago, Cherrysour said: It’s a 6 year old car. We just had the rotors rotated and new brake pads put on to try to fix the sound. It didn’t help. The mechanic mentioned the rear differential motor assembly, but the sound only happens as I come to a complete stop and when I first release the brake. I don’t hear it at any other time. Did you wash the car yourself? Do you use powerful jet spray? If no, I suggest you go to petrol station for car wash. They will wash away the brake dust with the jet spray. Then drive around for a short period of braking, the sound may go away. No harm trying it. Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 17, 2019 Share December 17, 2019 (edited) 27 minutes ago, Xtrah said: Did you wash the car yourself? Do you use powerful jet spray? If no, I suggest you go to petrol station for car wash. They will wash away the brake dust with the jet spray. Then drive around for a short period of braking, the sound may go away. No harm trying it. Did it happen all the time or is it intermittent ? Can you have someone standing beside the car and see if he could locate which particular wheel is making the noise? It could be a case that your caliper is stuck, the rotor forces open the caliper again when the car move forward. Edited December 17, 2019 by Ct3833 Link to post Share on other sites More sharing options...
Cherrysour Neutral Newbie December 17, 2019 Share December 17, 2019 12 hours ago, Ct3833 said: It could be a case that your caliper is stuck, the rotor forces open the caliper again when the car move forward. Thank you so much, everyone who mentioned calipers and break dust! We oiled and cleaned them all, but the car was still making the noise. It turned out to be a loud valve in the rear differential motor assembly. That has been greased, too, and it’s a bit quieter now. The mechanic doesn’t think it’s going to be a problem, so we’ll just watch it for now. I really appreciate everyone’s help! Link to post Share on other sites More sharing options...
Sdf4786k Twincharged December 17, 2019 Share December 17, 2019 (edited) 19 hours ago, Xtrah said: Did you wash the car yourself? Do you use powerful jet spray? If no, I suggest you go to petrol station for car wash. They will wash away the brake dust with the jet spray. Then drive around for a short period of braking, the sound may go away. No harm trying it. Bad bad bad advice.. you have high chance of crack rotor if u do that . Very harmful Edited December 17, 2019 by Sdf4786k Link to post Share on other sites More sharing options...
Dilemma 5th Gear December 18, 2019 Share December 18, 2019 2 hours ago, Sdf4786k said: Bad bad bad advice.. you have high chance of crack rotor if u do that . Very harmful So u mean every 1 that goes to the petrol station car wash will have crack rotor? Link to post Share on other sites More sharing options...
Sdf4786k Twincharged December 18, 2019 Share December 18, 2019 (edited) 5 hours ago, Dilemma said: So u mean every 1 that goes to the petrol station car wash will have crack rotor? You can’t go against sciences. Hot rotor cold water fast contraction = crack rotor . U may not see it does not mean damage has been done try this boiling water pour into glass .. pour boiling water out n pour cold water. Just because it does not shattered does not mean the glass hairline crack is not there .. perhaps a Mug will not crack but sure as heck it will crack if u continue to do that. you can alway try on your car to find out Edited December 18, 2019 by Sdf4786k Link to post Share on other sites More sharing options...
Xtrah 3rd Gear December 18, 2019 Share December 18, 2019 (edited) 14 hours ago, Sdf4786k said: Bad bad bad advice.. you have high chance of crack rotor if u do that . Very harmful Who ask you brake hard go petrol station wash? Just travel slowly and light brake. Anyway, still have to wait for the turn. By then rotor already cool down. Think about it before you post your reply. Edited December 18, 2019 by Xtrah Link to post Share on other sites More sharing options...
Jcteo Neutral Newbie August 5, 2020 Share August 5, 2020 mine have croak sound on driver side when i go pass humps at low speed. got my suspension checked, no problem leh. Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 5, 2020 Share August 5, 2020 When there is no physical leak on the dampers, it may not necessarily mean the dampers are in good condition. There are also the worn out undercarriage control arms and anti roll bars that could attribute to the noise. What's the mileage done then? ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Understanding Anti-lock Braking System (ABS)
Right side speakers no sound
