Titanium 4th Gear April 23, 2006 Share April 23, 2006 Beside change engine oil, anything else is required? Battery??? Btw, any workshop wif reasonable price to recommend? STAR? CAS? TIA! ↡ Advertisement Link to post Share on other sites More sharing options...
Zoomster Neutral Newbie April 23, 2006 Share April 23, 2006 40K should involve the following: spark plugs change battery (if it is more than 1.5years) cabin air filter change air filter change Fuel filter change Brake fluid change coolant change ATF (depends on condition) i did my 40K servicing at shell proserve, quite fast and good Link to post Share on other sites More sharing options...
Nutty 4th Gear April 23, 2006 Share April 23, 2006 Sparks plugs if you are using platinum ones. Link to post Share on other sites More sharing options...
Titanium 4th Gear April 23, 2006 Author Share April 23, 2006 Y platinum must change? i thou plat last longer? mine is plat. Link to post Share on other sites More sharing options...
Titanium 4th Gear April 23, 2006 Author Share April 23, 2006 my battery 2.5yrs liao, still stronge... Link to post Share on other sites More sharing options...
Nutty 4th Gear April 23, 2006 Share April 23, 2006 I read from someone one la. The best is ask your mechanic for advice. Link to post Share on other sites More sharing options...
Titanium 4th Gear April 23, 2006 Author Share April 23, 2006 did my 40K servicing at shell proserve, quite fast and good How much u paid? oil included? Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear April 24, 2006 Share April 24, 2006 (edited) 40K servicing is a major one Should includes the following:- 1) ATF flush & changed. 2) Power Steering fluid. 3) Brake fluid. 4) Coolant flush & change. 5) Spark plugs 6) Front brake pad (Depends on condition) 7) Air filter 8) Fuel filter 9) Incabin air con filter 10) Engine oil change 11) Battery (Depends on condition) It's a hole on our pocket Edited April 24, 2006 by Mzrmazda3 Link to post Share on other sites More sharing options...
Nutty 4th Gear April 24, 2006 Share April 24, 2006 Does 40k servicing differs across different makes? Link to post Share on other sites More sharing options...
Tploh Clutched April 24, 2006 Share April 24, 2006 Read your manual. Different brand/make has different schedule. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear April 24, 2006 Share April 24, 2006 IMHO, i think for most of the japanese makes 40K servicing is almost the same For other makes, i'm not so sure Link to post Share on other sites More sharing options...
Robin 4th Gear April 24, 2006 Share April 24, 2006 Platinum should be able to last at least 80k km... Link to post Share on other sites More sharing options...
Titanium 4th Gear April 24, 2006 Author Share April 24, 2006 40K servicing is a major one Should includes the following:- 1) ATF flush & changed. (Just changed) 2) Power Steering fluid. (Electric PS) 5) Spark plugs (Plat.) 7) Air filter (Using Green filter) 9) Incabin air con filter (Dun have AC filter) 8) Fuel filter (Must) 10) Engine oil change (Must) 3) Brake fluid. 4) Coolant flush & change. 6) Front brake pad (Depends on condition) 11) Battery (Depends on condition) anymore?? Link to post Share on other sites More sharing options...
Titanium 4th Gear April 24, 2006 Author Share April 24, 2006 anymore suggestion??? Thank! Link to post Share on other sites More sharing options...
Garlic 1st Gear April 24, 2006 Share April 24, 2006 Besides the above, CM did the following as well during 40K. 1) Change aircon belt 2) Change alternator belt 3) Change gasket 4) Wheel balancing & rotation 5) Engine tunning Our Ignis is using a timing chain thus no change is required. Link to post Share on other sites More sharing options...
Titanium 4th Gear April 24, 2006 Author Share April 24, 2006 (edited) Is all these necessary? si mi is engine tuning? Edited April 24, 2006 by Titanium Link to post Share on other sites More sharing options...
Kcseah Neutral Newbie April 24, 2006 Share April 24, 2006 Can try CAS. But is your car still under warranty ? Link to post Share on other sites More sharing options...
Titanium 4th Gear April 24, 2006 Author Share April 24, 2006 Yes, but i not going back... cos is freaking expensive. ↡ Advertisement Link to post Share on other sites More sharing options...
Workshops with engine oil flushing machine
Volvo Servicing
Volvo Servicing
Lee Sheng Auto - One Stop Auto Repair Centre! From accident repair & claims, spray painting, diagnostics, general repairs to servicing.
Servicing car at Shell station
