Ambious Neutral Newbie May 31, 2006 Share May 31, 2006 Hi all, In the market, there's various brands of volt stabilizers. which is good to use? There's also 1 type for voltage and the other for amp voltage. I have amps in my car, so should i use both or just get one? If just get one, the normal volt or the amp one? Eva ↡ Advertisement Link to post Share on other sites More sharing options...
Muffler 1st Gear June 3, 2006 Share June 3, 2006 I personally feel that Sun's Hot Inazma range is one of the top VS around. Though a tad expensive, it works very well for me. Get another capacitor for your ICE (if u need the extra ommp) Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 3, 2006 Share June 3, 2006 max volts Link to post Share on other sites More sharing options...
Valor79 Neutral Newbie June 3, 2006 Share June 3, 2006 Pivot Link to post Share on other sites More sharing options...
S9550i Neutral Newbie June 4, 2006 Share June 4, 2006 pivot Link to post Share on other sites More sharing options...
Skyz82 Neutral Newbie June 4, 2006 Share June 4, 2006 RMK voltage stabiliser not bad... used for quite sometime liaoz got no complains!!! Link to post Share on other sites More sharing options...
Lanceteo Neutral Newbie June 4, 2006 Share June 4, 2006 max volt Link to post Share on other sites More sharing options...
Ambious Neutral Newbie June 5, 2006 Author Share June 5, 2006 Whoa, so many brand. So any of them sure can lah, not necessary must but the volt stabilizer that support amplifier one lah, is it? Eva Link to post Share on other sites More sharing options...
Gary84 1st Gear June 5, 2006 Share June 5, 2006 Pivot Raizin... Link to post Share on other sites More sharing options...
Chivas Neutral Newbie June 6, 2006 Share June 6, 2006 so bro where to get this Pivot Raizin ?? regards Link to post Share on other sites More sharing options...
Gary84 1st Gear June 6, 2006 Share June 6, 2006 bro alot of shops selling this stuff...Autobacs... Maybe u can try Express motion along 920 upp Thomson rd...tel: 64534522 Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear June 6, 2006 Share June 6, 2006 Using Pivot 'Blue' box & Pivot 'Transparent' ones on my ride So far so good 'Blue' box one is for the general voltage while the 'Transparent' one for amps voltage Normally, shops that sells these voltage stabilizers will ask you to do up the grounding as well Link to post Share on other sites More sharing options...
Khee Neutral Newbie June 6, 2006 Share June 6, 2006 look to be EZ-stab is operating the same function as well... you might want to try tat since it is locally design and cheaper also... Link to post Share on other sites More sharing options...
Laojiao 2nd Gear June 6, 2006 Share June 6, 2006 Using PIVOT RAIZIN ... good stuff ... can't go wrong as its very well established. Can get for abt $80/90 cash & carry. Check out www.speedworks.com.my - look under Contacts for Mr Loo in Singapore. Cheers! Link to post Share on other sites More sharing options...
Ambious Neutral Newbie June 6, 2006 Author Share June 6, 2006 So is it necessary to get both as i've 2 amps in my car? The blue and transparent one are connected to the battery together? Eva Link to post Share on other sites More sharing options...
Frozebite Neutral Newbie June 6, 2006 Share June 6, 2006 Pivot razin is good Link to post Share on other sites More sharing options...
Discoburg Supersonic June 6, 2006 Share June 6, 2006 Yeah i am also using the Hot Inazma VS Link to post Share on other sites More sharing options...
Frozebite Neutral Newbie June 6, 2006 Share June 6, 2006 I thought that the pivot is selling less than $60 ↡ Advertisement Link to post Share on other sites More sharing options...
2 lanes turn right to 3 lanes - which lane to go?
Which brand of honey to buy?
Which airline is the best?
