Poortraveller 1st Gear July 13, 2006 Share July 13, 2006 how u regap? i read somewhere is that for street driving, not much use to regap... mainly for those racing car where 1 second time difference make a hell lots of difference ↡ Advertisement Link to post Share on other sites More sharing options...
Linus Clutched July 13, 2006 Author Share July 13, 2006 SNA ? simi lai de ? sensitive new age guy ? Link to post Share on other sites More sharing options...
Poortraveller 1st Gear July 13, 2006 Share July 13, 2006 can run @ 92 with no problem??? hmmmm .... Link to post Share on other sites More sharing options...
Linus Clutched July 13, 2006 Author Share July 13, 2006 can lah. sure ur experience with us. Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie July 13, 2006 Share July 13, 2006 its a fuel additive, but doesn't increase octane. if used for every tank, its cheaper than STP 1 quart bottle is $36, 1 quart got 32oz, i use 1 oz per full tank 1 oz is $1.125 cheaper than STP le What will FP60 do for my car ? FP60 is special blend of chemicals designed to clean your vehicle Link to post Share on other sites More sharing options...
Linus Clutched July 13, 2006 Author Share July 13, 2006 but when u think abt it, for our autos, our FC ok mah. Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie July 13, 2006 Share July 13, 2006 i bought the gapping tool from yeobh, then go check my spark plugs gap, 3 out of 4 of them out of recommended spec liaoz, then i take my old coppers denso plugs that i used for 5k km, regap them to 1.0mm, (recommended is 1.0mm~1.1mm) then good to go the thing is, when the spark gap too big, the coil may not be able to produce sufficient voltage to produce the spark, so misfire may occure more frequently, thus lost of power.. but gap it too small, and the spark won't be bright enough for complete combustion.. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched July 13, 2006 Share July 13, 2006 u mean "Viagra" fer yer car? Check out this webby : http://www.onemotoring.com.sg/publish/onem.../additives.html Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie July 13, 2006 Share July 13, 2006 i don't experience the "marbles in your cylinder" sound that genie describes.. hehe, so i guess its ok low end power is as good as ron95, its only when u floor it, the higher end (in my case, above 4k rpm) not so good liaoz, but that can be explained because ron92 resistant to detonation is lower than ron98, so when under stress or load situtations, then the ron factor comes into play. so the engine retards more than compared to using ron98. ron98 also retard the engine, just that retard lesser than compared to using ron92. FP60 could have help by maintaining the combustion chambers clean, thus lesser carbon deposits, which results in lesser "hot spots" which in turn results in lesser chance of detonation again.. hope i'm explaining correctly so good enough for SG city driving and our overcrowded expressways, heh Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie July 13, 2006 Share July 13, 2006 (edited) yeah! hahahaha my not so young car needs viagra liaoz Edited July 13, 2006 by Cyberet Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie July 13, 2006 Share July 13, 2006 SNA ? simi lai de ? sensitive new age guy ? single and available.. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched July 13, 2006 Share July 13, 2006 (edited) Good explanation, bro. yup, new car ecu smarter, with knock sensor will retard when knocking appear.... Tats why, after tried ron95 on my mazzie, go back to ron98 becuz i'm more of HRF, liao. Edited July 13, 2006 by Normal_aspirated Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie July 13, 2006 Share July 13, 2006 ta ma da..my last 2 tanks giving me only 12++km/l...dunnoe what happen? Period liao becoz going 3yrs?? after i regap my spark plug, i'm getting back the FC i used to get 2yrs ago seems like quite a no of my plugs went from 1.1mm to 1.2mm over time, which is out of spec. even those iridium ones.. somemore using 92oct now hmmm..i didnt change my spark the last servicing coz its not 30k yet...i using thos twin head copper type..cheap and good according to uncle NA. maybe being getting into lots of the slow traffic nowadays? Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie July 13, 2006 Share July 13, 2006 broke back mountain no leh....i not into that...i favour more to hua guo shan de shui lian dong.... Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie July 13, 2006 Share July 13, 2006 used to have HRF then petrol keep rising until i change my driving style used to use 98, then 95, now 92 i want diesel but if i know going to chiong NSHW, i sure put 98 Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie July 13, 2006 Share July 13, 2006 hanor.. jam here, jam there.. small accident on the road shoulder also can cause congestion Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie July 13, 2006 Share July 13, 2006 maybe that cause the high FC....realised i been touching the stick very often comparing to last time... Link to post Share on other sites More sharing options...
Dennisk Clutched July 14, 2006 Share July 14, 2006 i am now running on 95...seems to loss alot of power....erm.... should i stick back to 98? ↡ Advertisement Link to post Share on other sites More sharing options...
Nissan QashQai 2014 Part 2
Mercedes Owners Thread
2022 Mazda CX-60
2022 Mazda CX-60
MAZDA 6
MAZDA 6
2026 Mazda EZ-60 / CX-6e
