Hlkh Clutched July 12, 2006 Share July 12, 2006 Hi, This problem bother me for almost a year... my steering would easily pull to the right on slight bump and sometime even straight road. I have visited 2 different workshop to do computer 4 wheel alignment, but problem still there.... 1 of the workshop is highly recommandedin forum. can anyone help ?? thank you ↡ Advertisement Link to post Share on other sites More sharing options...
Paffendorf Neutral Newbie July 12, 2006 Share July 12, 2006 Go check the physical tyre or not since your alignment is ok? Must check suspension also der.... Check tyre pressure correct or not 1st then go for suspension check. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 12, 2006 Share July 12, 2006 u can try go eng seng at level 1 amk autopoint their alighment machine is pretty much accurate compared to tyre shops cos its much better Link to post Share on other sites More sharing options...
Apollo 1st Gear July 12, 2006 Share July 12, 2006 you bought this new? or 2nd hand? did anyone check ur steering column, clip bracket, rack & pinion or something? i had an accident once, and the clip bracket becomes dislodge, then will hv this problem also. car go straight, but steering is almost 10 o/clock. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 12, 2006 Share July 12, 2006 When you're driving or braking or what? Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 13, 2006 Share July 13, 2006 Looks like the wheel steering linkage is giving the problems. Check ball joints and wheel end front bearing. If all ok chances the wheel toe need some adjustments. 4 wheel computerised whelel aligner is of no use one who do not understand the basic wheel geometery set-up and thier relationship. Just by ajdusting according to the display reading without any mechanical feeling is a perfect receipt for failure and burning a big hole in one's pocket. PS if yr ride has ever meet an accident that caused serious undercariage damage, under such condition it is advisable to get the undercariage measured and pull back to spec before doing the wheel alignment. Link to post Share on other sites More sharing options...
Mirage_77 Neutral Newbie July 13, 2006 Share July 13, 2006 Where is a good place to measure the undercarriage and pull back? Any rought estimate of the price? Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 13, 2006 Share July 13, 2006 (edited) Vicom have the computerised measuring bend, you can call them to get the price quote. As for pulling maybe vicom can adv you the best shop to go to Edited July 13, 2006 by Yeobh Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 13, 2006 Share July 13, 2006 How abt steering wheel vibrating at 80km/h only? Above and below that no vibration. Done wheel balancing twice oready. Something to do with steering shaft? Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 13, 2006 Share July 13, 2006 The vibrations only appears at a certain speed range - this type of virbation is very difficult to solve as it is inherent - the speed rang window is know as critical speed where almost all rotating components vibrate at the same frequency.Try rotating or changing tyres and doing on car balancing at 80 instead of the default 120 kmh. Link to post Share on other sites More sharing options...
Jack0909 Neutral Newbie July 13, 2006 Share July 13, 2006 same problem as me bro.. i tink u should check ur rims... hmmm... or ur tyres have uneven wear.. Link to post Share on other sites More sharing options...
Hlkh Clutched July 13, 2006 Author Share July 13, 2006 ok ... i have checked my tyre pressure all round and my suspension i feel that right side is harder then left side Link to post Share on other sites More sharing options...
Hlkh Clutched July 13, 2006 Author Share July 13, 2006 i get my car new now coming 2yrs no accident. any recommended workshop to check? Link to post Share on other sites More sharing options...
Hlkh Clutched July 13, 2006 Author Share July 13, 2006 driving and braking also have. when uneven rd and braking some time harder pull to right Link to post Share on other sites More sharing options...
Hlkh Clutched July 13, 2006 Author Share July 13, 2006 ok bro, got workshop that is good to recommend? i m tired of this problem Link to post Share on other sites More sharing options...
Aveolution Neutral Newbie July 13, 2006 Share July 13, 2006 got workshop that is good to recommend? try RiverView Auto Services 6481 2025 http://www.riverview.com.sg/ 10 Ang Mo Kio Autopoint #04-07/16 he is the Best so far High-Tech workshop with reasonable fee Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 13, 2006 Share July 13, 2006 High tech equipment can actually creat more confusion for the trained mechanics not to mentioned the less well trained .To do a good wheel alignment job, one must have in depth understanding of the basic wheel steering geometry and good mechnical hand skills. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 13, 2006 Share July 13, 2006 same problem as me bro.. i tink u should check ur rims... hmmm... or ur tyres have uneven wear.. U facing the same problem oso? Still not solved? Actually it's my fren la, he asked me what's the problem but I'm oso not sure. He went for wheel balancing again but didn't solve the problem. According to him, the problem started only after he changed tires so can't be uneven wear. Maybe it's the rims then... ↡ Advertisement Link to post Share on other sites More sharing options...
2 lanes turn right to 3 lanes - which lane to go?
Citroen C4 1.2 Sensor & Display
