Seanboi 1st Gear August 1, 2006 Share August 1, 2006 Wish to noe which CAI gives the most effect. Is it longer or shorter? ↡ Advertisement Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear August 1, 2006 Share August 1, 2006 Makes no difference unless the filter is at the end of it. The important bit is the distance from the filter to the TB. The shorter the better. Link to post Share on other sites More sharing options...
Seanboi 1st Gear August 1, 2006 Author Share August 1, 2006 oic. noted. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear August 1, 2006 Share August 1, 2006 so u mean Filter which is further away from the TB is less effective compare to filter nearer to TB??? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear August 1, 2006 Share August 1, 2006 yup. it equals to using a narrower piping = more restriction. same thing with more bends. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear August 1, 2006 Share August 1, 2006 but i felt that my AEM CAI is pretty good... the filter is located at the bumper area...:) i tot it was this way that more cold air cld be draw.... Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear August 1, 2006 Share August 1, 2006 (edited) hey if more air is getting though the piping than the TB and inlet manifold can take in, who cares But if your TB has say a 3inch diameter and the long piping is 3inch in diameter, you'll find that the car will be able to breath easier with a bigger diameter pipe. why do you think that the original intake piping between the filter and TB is bigger than the diameter of the TB. not to mention its always very short. Edited August 1, 2006 by Elfenstar Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie August 1, 2006 Share August 1, 2006 Wish to noe which CAI gives the most effect. Is it longer or shorter? This is the typical CAI vs Short RAM intake question Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie August 1, 2006 Share August 1, 2006 Some dude did a test: Cold-air intakes vs. short ram intakes....this is one of those eternal topics like sc vs. turbo. Being the scientist that I am, I decided to do my own test. And being the good guy that I am, I'm gonna share my results with you lucky people :zzz: - With my cold air extension, my intake temperature rises to about 180F (82.2C) after some very aggressive acceleration. With just the SRI, my intake temp rises to about 193F ( 89.4C) after some similar driving. - Cruising intake temp is around 146-148F (63-64C) with the CAI and 148-152F (64-67C) with the SRI. - Both types of intakes take about the same amount of time to reach the max intake temp and the same amount of time (about 11-12 sec) to fall back to cruising temp (about 1 min). - This is was all done with the outside temp being 54-55F (13C). - Intake temp was measured with the intake air temp sensor on the intake manifold (courtesy of Honda) and was recorded with Hondata datalogging. - Note that this was done with and Injen 3" intake on a supercharged integra so your results may vary :angel: ↡ Advertisement Link to post Share on other sites More sharing options...
More MRT Lines Announced
More NS defaulters in 2011 than in 2010
More frequent filter and engine oil change due to haze
Car battery lifespan getting shorter?
Which insurance is the cheapest and is more detail?
Authorised Dealers no longer offering manual options??
Renault Fluence 1.6, 1k more than Toyota Altis
