S2P2 Neutral Newbie April 20, 2003 Share April 20, 2003 japanese cars normally is only 55W.....the product has many brands but all will have the standard H1/3/4/7....take the H4 and see that it says its 55W.....autobacs selling for 12.50 ↡ Advertisement Link to post Share on other sites More sharing options...
Unkn0wn Neutral Newbie April 20, 2003 Share April 20, 2003 thanks... don't mind me asking but what's the diff between h1,3,4 and 7? the higher the number, the whiter the light? $12.50?? that's cheap.. if so, why is it that others are buying blue vision at $50 plus? is there any diff between the two? Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie April 20, 2003 Share April 20, 2003 no lah.....h1/3/4/7 for diff cars only....most contis should be 3 and 7 i think....most japs are 4. diff is 50 ones are the hight watts one lor........and TP magnet lor.......not legal hor....12.50 or 50 Link to post Share on other sites More sharing options...
Unkn0wn Neutral Newbie April 20, 2003 Share April 20, 2003 u mean both h4 and blue vision also not legal?? is there any legal ones which is white in color? Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie April 20, 2003 Share April 20, 2003 white light bulb is only legal if it comes as stock. Lexus uses HID and pass coz BM givems them HID. our normal cars suppose to use the yellow light loh.... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 20, 2003 Share April 20, 2003 The only white halogen light bulb that is approved is the Philips BlueVision.... and All aftermarket HID light installation is not legal.... Link to post Share on other sites More sharing options...
Cool Neutral Newbie April 20, 2003 Share April 20, 2003 err. you both new car ? You need to get the 100watts converter. you can get it from www.pro-rv.com.sg at serangoon plaza. With that, you won't fry the cables. cheers Link to post Share on other sites More sharing options...
Car_guru Neutral Newbie April 20, 2003 Share April 20, 2003 H1, H3, H4, H7 etc are different types of bulbs... H4 is a twin-filament bulb for cars that have only one reflector... so both low and high beams are from one bulb. H4 bulbs are usually rated at 60/55W. H3 is usually used for fog lamp bulbs and is rated 55W as well... H7/H1 are used for headlights, both rated at 55W. Link to post Share on other sites More sharing options...
Unkn0wn Neutral Newbie April 20, 2003 Share April 20, 2003 sorry.. really confuse now... after all the above posts, can anyone tell me how should i go about changing my lights to white and at the same time make sure it's legal? From what i gather, h4 55w lights are illegal. So does that mean that i should opt for blue vision which is legal and change my cable to 100w at serangoon plaza?? Thanks a lot and sorry very the blurness. Link to post Share on other sites More sharing options...
Car_guru Neutral Newbie April 22, 2003 Share April 22, 2003 Stock bulbs are rated 55W... but those white bulbs have an extra tint of blue on the bulb envelope... this is to turn the slightly yellowish halogen beam into white... because of this blue tint, the wattage needs to be increased in order to maintain the same brightness... therefore you can see those aftermarket white bulbs are rated 100W or above... it is dangerous to use higher wattage bulbs on stock relay as it could cause overheating... so the safer way is to upgrade your relay as well... Blue Vision is rated at 55W as well, so there's no need to change your relay... unless you're changing to those 100W and above white bulbs. Link to post Share on other sites More sharing options...
Unkn0wn Neutral Newbie April 25, 2003 Share April 25, 2003 thanks car_guru for verifying... so it will be safe and legal for me to change to blue vision since it's LTA approved? Blue vision offers white light right?? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 25, 2003 Share April 25, 2003 Blue vision still yellow but lighter yellow.....don't expect white light.... Link to post Share on other sites More sharing options...
Unkn0wn Neutral Newbie April 25, 2003 Share April 25, 2003 thanks saaber... so effectively, there's no legal aftermarket white lights around? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 25, 2003 Share April 25, 2003 yep, you're right... Link to post Share on other sites More sharing options...
Unkn0wn Neutral Newbie April 25, 2003 Share April 25, 2003 10q Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 25, 2003 Share April 25, 2003 you're welcome.... ↡ Advertisement Link to post Share on other sites More sharing options...
Christmas lightup 2022!
Are LED lights subject to brightness checks?
Traffic junction without traffic lights
Electrician lobang?
Electrician lobang?
2022 Orchard Road Christmas Lights
Car Interior LED Lights
