Kelpie 2nd Gear October 29, 2006 Share October 29, 2006 Did you guy catch a copy of the latest Hotstuffs Mag, there was a mention on the Harmonic Damper by Alutec exclusive agent: "There has been much internet hearsay and rumors on this common myth - that harmonic dampers are needed on aftermarket crank pulleys. people are getting their crank pulleys confused with the harmonic dampers found on some American domestic V6 / V8 engines, found commonly on their "muscle cars". These older American engines need an external balancer, AKA torsional damper / balancer to balance the crankshaft rotating assembly. However, this is non-existent in moden engines today as our engines are internally balanced. Technically, the harmonic damper does not exist in modern engines especiially so in Japanese and Korean makes. What you may see on O.E pulleys found on some cars is a rubber ring called an elastomer. This elastomer is NOT a harmonic damper and DOES NOT aid in the balancing of the crank pulley in any way. The elastomer in the O.E pulley serves as an isolator, which is there to supress natural vibration and noise from the engine itself. The elastomer is only found on selective car makes and not every car has one. Adding an elastomer, including the sealing agent to glue it to the pulley, adds weight to the pulley and defeats the sole purpose of installing a lightweight crank pulley - which is to reduce weight to gain lost horsepower and torque." True? Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Mage Clutched October 29, 2006 Share October 29, 2006 is this true? .. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear October 29, 2006 Author Share October 29, 2006 is this true? .. I don't know either hence I ask lor . Perhaps, the experts here can tell us more. Regards, Link to post Share on other sites More sharing options...
Falc 3rd Gear October 29, 2006 Share October 29, 2006 It's true that some OEM pulley clearly doesnt have any rubber in between, those who have, it's also not sure if they act as damper or silencer. But on evidence wise, havnt come across anyone with a broken engine because of lightened pulley. Lightened pulley plus lightened flywheel yes IIRC. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched October 29, 2006 Share October 29, 2006 (edited) not recommended fer conti engines.......... for japs, as their engines parts are very well-balanced (result less noise), so forged lightened crank pulley should post no prob. so far no problem on my prev Mazzie protege for 3 yrs. Help low-end pickup only. High end no benefit. My S$0.02. Edited October 29, 2006 by Normal_aspirated Link to post Share on other sites More sharing options...
Brock 1st Gear October 29, 2006 Share October 29, 2006 (edited) Kelpie, Before that HotStuff article, I saw it over here already. Here's another interesting read about the lightweight crank pulleys. Even Evo's are using them (Ralliart Lightweight Crank Pulley), as seen from this article. It's best to have a lightweight crank pulley WITH the harmonic damper. Edited October 29, 2006 by Brock Link to post Share on other sites More sharing options...
Brock 1st Gear October 29, 2006 Share October 29, 2006 According to this article, one of the company's employee, who used a lightweight crank pulley w/o the harmonic damper, had his pulley cracked into two. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear October 29, 2006 Author Share October 29, 2006 (edited) Seems like crank pulley is ok to go ahead. I will get one soon. Thanks all. But now which brand to get? Alutech or RPM? Anyone have recommendation? usually costs how much har? Thanks again. Regards, Edited October 29, 2006 by Kelpie Link to post Share on other sites More sharing options...
Falc 3rd Gear October 29, 2006 Share October 29, 2006 Got meh? Anyway, the damper is to damp the vibration on engine's crank as oppose to damping the pulley itself. So if pulley split, probably means that guy use lousy aftermarket pulley lah. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 29, 2006 Share October 29, 2006 RPM one got harmonic damper it seems. I saw it at Riverview Auto. Link to post Share on other sites More sharing options...
Zrun Neutral Newbie October 31, 2006 Share October 31, 2006 Many new cars do not have the damper in the crank pulleys. It is combination of two factors: to cut costs and the overall improvement of engine quality/internal balance. However these crank pulleys are still much heavier than lightweight crank pulleys. The heaviness provides good amount of damping effect. Link to post Share on other sites More sharing options...
Cooldown Neutral Newbie November 2, 2006 Share November 2, 2006 The most important is will the belt slip.. My frd install another brand of crank pulley and after not long, the belt keeps slipping off for nothing.. don know is it the mechanic or the product.. so abit put off to install this product Link to post Share on other sites More sharing options...
Zrun Neutral Newbie November 2, 2006 Share November 2, 2006 Slipping belt can be caused by belts in bad condition, bad belt tensioner, or belts length doesn't match very well. Very seldom have to do with the crank pulley. If you plan to change crank pulley, might as well change the whole sets of accessory pulleys for maximum power.. Link to post Share on other sites More sharing options...
Cooldown Neutral Newbie November 3, 2006 Share November 3, 2006 Change whole set .. then think the car will be having super light throttle.. haha. Not to say the cost of all the pulleys.. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear November 5, 2006 Author Share November 5, 2006 I just installed an underdrive pulley. It does make the car feel lighter at pickup. Perhaps, due to the lighter weight, you will somehow hear the "unqiue" pulley sound when your start the engine. This translates to additonal noise to some. Once inside the car, I don't hear anything at all. I wonder if noise is an issue to those who have installed aftermarket pulley? Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Shock absorber damper
Bonnet Damper
Bonnet Damper
Torque Damper on firewall
Damper?
Damper?
Damper for engine block
Sage(Coilover) VS Sach(Damper with matching spring)
Arospeed Engine damper or other similar makes
