Luckcent 4th Gear July 25, 2003 Share July 25, 2003 All, anyone heard or installed damper for engine block. ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie July 25, 2003 Share July 25, 2003 Yes, I have heard of people putting in extra engine damper....why? you intend to put also... Link to post Share on other sites More sharing options...
Luckcent 4th Gear July 25, 2003 Author Share July 25, 2003 It does help in stabilising the engine and gear shift changing will be much smoother. Now is to how to do it and mount damper. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie July 25, 2003 Share July 25, 2003 usually will be mounted to the top where there is a hook for engine support during overhaul and the other point usually to the top of the suspension mounting with a strong bracket....maybe you can look at the AR156SW for some idea, I believe they came stock with it... Link to post Share on other sites More sharing options...
Luckcent 4th Gear July 25, 2003 Author Share July 25, 2003 I know roughly where to mount but the question where to buy such dampers. Any idea. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie July 25, 2003 Share July 25, 2003 why don't you try garage R? Link to post Share on other sites More sharing options...
Luckcent 4th Gear July 28, 2003 Author Share July 28, 2003 I have found another way of stopping the engine from rocking during gear changes and will try to stop it to ensure smooth gear changes. If not will try R to see if can get dampers. Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 28, 2003 Share July 28, 2003 I have found another way of stopping the engine from rocking during gear changes and will try to stop it to ensure smooth gear changes. If not will try R to see if can get dampers. dampers will be the better way out, IMO. Link to post Share on other sites More sharing options...
Luckcent 4th Gear July 28, 2003 Author Share July 28, 2003 In fact, there is a mount fixed below engine block but it is flexible. Now trying to fix this movement if not dampers will be added. Link to post Share on other sites More sharing options...
Vtim 3rd Gear July 28, 2003 Share July 28, 2003 In fact, there is a mount fixed below engine block but it is flexible.It's meant to be that way, if it's non-flexible, all the vibration will goes to the chassie, just like some of the fixed engine mount on Harleys Link to post Share on other sites More sharing options...
Luckcent 4th Gear July 28, 2003 Author Share July 28, 2003 The best will need to use the dampers. OK will do that. Link to post Share on other sites More sharing options...
Rizkilz Neutral Newbie June 21, 2004 Share June 21, 2004 if you're looking for engine dampers, i carry them... visit my website: http://rizkilz.bravehost.com/ Link to post Share on other sites More sharing options...
Zrun Neutral Newbie June 21, 2004 Share June 21, 2004 (edited) I've just ordered a set of Energy Suspension Engine Mount Inserts for my car. There is a kind called a "torque brace", which simply a metal rod connecting your engine block to the chassis. I do not recommended this, because your engine will still vibrate on the soft engine mount and cause alot of stress on the torque brace and chassis. The other kind is motor mount inserts. It is a plastic polymer version of your rubber motor mounts. You only need to support your engine with a jack, pop out the old rubber, and put in the plastic inserts. I estimate install procedure to be about 20 mins. Alot of people just pour polyurethane mix directly into the engine support. It is very cheap, you can choose the stiffness but you need to take out the engine mounts one at a time. Usually, pre molded aftermarket inserts are very stiff for high performance use. I've test driven a Corolla with the upgrade, it makes a big difference with gear changes. HOWEVER, there'll be definitely an increase in vibration inside the car. Edited June 21, 2004 by Zrun Link to post Share on other sites More sharing options...
Cyrix Neutral Newbie June 5, 2005 Share June 5, 2005 bro.,..so u saying that the torque damper is no good??? Link to post Share on other sites More sharing options...
Zrun Neutral Newbie June 5, 2005 Share June 5, 2005 The type that is a rod locking the motor to the chasis is no good... The type that reinforce stock motor mounts is good.. Look at pictures here ==> http://matrix.newobject.org/tech/esinstall Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 7, 2005 Share June 7, 2005 Maybe it good for you to try and narrow down the cause of the engine vibration rather than to try to arrest it. If the vibration is not properly reduce ,absorded or cancelled out then some component will have to give way!! ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
