Disconnect battery?
Latioboy
Bros.. How to disconnect batt?
Cause as said earlier, going perth for 11 days from this sunday
night...
So. thought of disconnecting battery from cefiro to prevent draining?
And also, how many days period must start once?
So i can ask my bro in law help start.. hehee
THANKS!
[rolleyes] No Need to Do Anything to the Car.............Jus call yr Brother in Law to
start every 2 Day..... run for 10 min ............that OK... [thumbsup]
11 days only. No need lah. No big deal.
If you want to disconnect battery, why bother to ask how many days period must start once ? Once every 2 days for 5 minutes more than enough.
to disconnect battery.
1)Open bonnet
2)Locate battery and their terminals
3)Look for the "-ve" terminal and the wire that is linked to it.
4)Loosen the nut in the "-ve" terminal and remove the wire
5)Pat urself on the back for a job well done
6)beware when u put back, there may be sparks, this is normal. its becoz battery high amperage, so can cause "arcing". No worries, wun kill u, if u do not touch the "+ve" at the same time.
No need to disconnect batt. If batt is good, even after 2 weeks, you can still start the car.
Starting the car not good enough. You need to drive the car.
Yea ... starting the car alone might not have enuf amp to charge ... stationary flooring also no good for the batt ...
night...
THANKS!
Have you considered taking out all the 4 tyres as well?
Erm, compare taking out 10 fuses to unscrew 1 wire. u say lei? no need open fuse box also. pop engine bay easy access battery.
Just relax and go for your long deserve break from the daily heat and pressure. Leave yr rid as it is, and it if you wish to get yr someone to start up - please make sure he or she takes the " horses" for a long drive to charge up all the battery( every time the battery crank the engine about 60amp is be used up) and to burnt up all the water vapour inside the engine.Happy holiday and pl don't forget to buy soverniers for all MCF kaki
[wave]
HAHA!!! think i so rich meh ?
LOL
I going there with my parents and bro in law and sis...
My bro in law gonna drive.. from perth to marg river.. COOL !!
rented a estima there!
HAHAS!! i will take fotos and post up here de!!
MEANWHILE.. i still have till sunday night to chiong MCF then gtg le.. WHO WANTS TO SEND ME OFF AT AIRPOT?
night...
THANKS!
As yeobh said, just leave the car as it is. no need to start or disconnect the battery.
If going for a much longer trip then either one of the other can be done. and starting every 2 days is overkill. once a fortnight for 10-15mins is all that is needed.
Why all the worry. Just leave the Cefiro with me during the trip & get it back in tip-top running condition when u come back. I can even send u off at the AIRPORT & not just the AIRPOT. [laugh]
I can even pick u up when u return but make sure u leave a cash-card with $50 in the car & a full tank of gas first. [sly]
Better make a decision fast cos u only got a couple of days left.
