Glendon Neutral Newbie February 3, 2007 Share February 3, 2007 intend to install these on my 3-mth old stock lancer (auto): 1. drop-in air-filter 2. performance spark plugs + cables 3. voltage stabilizer can someone recommend a reliable workshop? also, which order should i go with if i'm not installing them at one go (e.g. 1. drop in, follow by 3. stablizer, then 2. spark plugs). thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Bondx Neutral Newbie February 3, 2007 Share February 3, 2007 Bro, Tink of safety mods first. Consider yr ride handling performance, rather than power mods. VS - u can start first though. Link to post Share on other sites More sharing options...
Porche 5th Gear February 3, 2007 Share February 3, 2007 not much use for the VS.... for auto grounding ok, plugs a must Link to post Share on other sites More sharing options...
Vit4wd 1st Gear February 3, 2007 Share February 3, 2007 No offence to you, but personally, I find that it is better to buy the normal spark plugs at S$4 each and change them annually rather than buying the irridum performance ones at $20 each and changing them at a longer interval... reason being there will be wear and tear for eth performance plugs and they may not perform at optimum level once they reach 1/2 their lifespan. Link to post Share on other sites More sharing options...
Casey Neutral Newbie February 3, 2007 Share February 3, 2007 performance spark plugs definately helps Link to post Share on other sites More sharing options...
Kyousuke Neutral Newbie February 3, 2007 Share February 3, 2007 You are not driving a performance car. Or even an attempt at it. So those 3 mods you are mentioning are completely useless. At best the K&N drop in filter makes sense because you will never have to replace it. so you save on replacing the air filter every 20K. Save your $$$ on the other 2. Link to post Share on other sites More sharing options...
Yr1985 1st Gear February 3, 2007 Share February 3, 2007 Start with struct bar. Link to post Share on other sites More sharing options...
Ken1898 1st Gear February 3, 2007 Share February 3, 2007 Apexi air filter Sound nice but affect FC Link to post Share on other sites More sharing options...
Yr1985 1st Gear February 3, 2007 Share February 3, 2007 But if I were him , I'll do up on the cosmetics rather than performance, VIP style bodykits and rims..haha! Link to post Share on other sites More sharing options...
Simonbht 1st Gear February 3, 2007 Share February 3, 2007 bro, dun waste time. i suggest u do a 1. CAI with close pot, that won't affect FC much. 2. performance plugs do help. 3. get power pass rather than VS to some maybe these things won't work, maybe to them the performance gain is too marginal. to others maybe it'll do wonders. u need to do trial and errors in order to find out what suits your needs. Link to post Share on other sites More sharing options...
Glendon Neutral Newbie February 3, 2007 Author Share February 3, 2007 hi simonbht what's a power pass (i googled but came up empty)? i know a drop-in air-filter will not void my warranty, not too sure about a CAI with close pot though. Link to post Share on other sites More sharing options...
Glendon Neutral Newbie February 3, 2007 Author Share February 3, 2007 hi, the only reason why i'm going for the performance mods is that i find the pickup for lancer too sluggish. i'm not using my lancer to cheong, i just want it to pickup effortlessly and smoothly. you mentioned K&N drop-in filter, any experience with 'simota sports drop-in filter'? Link to post Share on other sites More sharing options...
Glendon Neutral Newbie February 3, 2007 Author Share February 3, 2007 hi, quite interesting. most of the replies seemed to favor changing to performance spark-plugs. may i know if you are using any VS - if so, can you feel the difference after installing it? Link to post Share on other sites More sharing options...
Glendon Neutral Newbie February 3, 2007 Author Share February 3, 2007 (edited) i don't see myself doing any sharp-cornering at high speed any time soon. i guess i have to give the strut bar a pass. Edited February 3, 2007 by Glendon Link to post Share on other sites More sharing options...
Glendon Neutral Newbie February 3, 2007 Author Share February 3, 2007 hi, if we change to top-grade performance spark plugs, do we have to change to high performance spark plug cables too? thanks! Link to post Share on other sites More sharing options...
Glendon Neutral Newbie February 3, 2007 Author Share February 3, 2007 hi does auto grounding serves the same purpose as a voltage stabilizer? Link to post Share on other sites More sharing options...
Pallmall Neutral Newbie February 3, 2007 Share February 3, 2007 Lancer is sluggish. You can do mods to it but the improvement is very small. Save the money for petrol and ERP charges. Link to post Share on other sites More sharing options...
Bondx Neutral Newbie February 3, 2007 Share February 3, 2007 U nvr know when u encounter a cornering situation or taking on a bend on a road at high speeds. Call it an emergency or urgent situation. When tat happens, u won't regret hving stiffer suspension supported by struts. If u r a seasoned driver n know yr ride well enuf, u may say tat throttle response is sluggish. Then focus on that aspect. Find out if the ECU can respond faster than, if not, then the lag is simply going to be prevent u from coming out from an emergency situation above safely. Otherwise when u take bends in a fast speed, u'd appreciate the stability - less body flexing, n slightly lesser body roll, tighter steering, dun feel the ride going out of control. Again u never know when u need it, but u'd appreciate hving it everyday w a more stable ride. ↡ Advertisement Link to post Share on other sites More sharing options...
Golden Village opens first all-laser cinema in Paya Lebar
China First Aircraft Carrier ....
First-timers must select BTO flats when invited by HDB or lose priority for a year from August launch
2 lanes turn right to 3 lanes - which lane to go?
Which brand of honey to buy?
