Fuzzylogic 2nd Gear February 26, 2007 Share February 26, 2007 How much do workshops usually charge for changing a set of 4 plugs if I bring my own? ↡ Advertisement Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear February 27, 2007 Share February 27, 2007 (edited) I think it should be around 5-8 bucks Edited February 27, 2007 by Mzrmazda3 Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie February 27, 2007 Share February 27, 2007 if it's your regular workshop, and u are ok with the mech sometimes they do it for free. anyway the estimate cost should be in the region of wat bro Mzrmazda3 mentioned. cheers Link to post Share on other sites More sharing options...
Dwoon 1st Gear February 27, 2007 Share February 27, 2007 Labour for mine costs $40.... Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear February 27, 2007 Share February 27, 2007 (edited) 40 bucks jus to change the spark plugs??? Edited February 27, 2007 by Mzrmazda3 Link to post Share on other sites More sharing options...
Dwoon 1st Gear February 27, 2007 Share February 27, 2007 What to do.... boxer engine.... some more the I/C must come out, as my upgraded one won't allow access even when the filter box and water container are removed. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear February 27, 2007 Share February 27, 2007 Normal Plug......Include labour....Around $20......... Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear February 27, 2007 Share February 27, 2007 Bro, your ride must be heavily modded Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie February 27, 2007 Share February 27, 2007 wah... but wat's your ride bro? cos i know my fren's WRX need a lengthy time just for spark plugs change. so maybe the cost is much higher. Link to post Share on other sites More sharing options...
Dwoon 1st Gear February 27, 2007 Share February 27, 2007 No leh.... Used to be $20 when the I/C didn't need to come out. Average time taken to change plugs is like 45 mins. Link to post Share on other sites More sharing options...
Dwoon 1st Gear February 27, 2007 Share February 27, 2007 Wrx has slightly bigger clearance at the sides once the water container and filter box comes out. But if your friend also upgraded his I/C.... then sama sama liao. But still slightly easier because of larger side clearance. Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie February 27, 2007 Share February 27, 2007 sorry... noob qnn, wat's I/C ? dun think he mod his WRX much, except that he put on the legal Fujisubo exhaust which sound not too bad at all, i must say Link to post Share on other sites More sharing options...
Dwoon 1st Gear February 27, 2007 Share February 27, 2007 I/C = Intercooler. The radiator thinggy that sits under the air scoop..... Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie February 27, 2007 Share February 27, 2007 oh... thanks if u mentioned that u upgraded your I/C wldn't it be covering your entire engine now? Link to post Share on other sites More sharing options...
Dwoon 1st Gear February 27, 2007 Share February 27, 2007 No lah.... not so big till it covers the entire engine..... just that it makes it even more difficult than it already is.... so removal will make it heaps easier to access the coils/plugs. Like filling the ATF or even the front differential oil will definitely need the I/C to be removed as it blocks the access to the filling neck. Can't even check their dipstick anymore. And NOBODY warned me about this prior..... ok.ok...its OT. Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie February 27, 2007 Share February 27, 2007 sounds like, it's a nitemare for mech and you in terms of maintenance.. but hey, if it does help in car performance some inconveniences is 'worth' it lah yup, OT liao Link to post Share on other sites More sharing options...
Dwoon 1st Gear February 27, 2007 Share February 27, 2007 Nightmare for me.... Ka-ching for the mechs. More work = I pay more leh..... Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie February 27, 2007 Share February 27, 2007 possible to revert to the stock I/C if it causes more issue$? ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Tool to change Spark Plug
Change Disc Rotors
Change Disc Rotors
X for twitter change request
