Passion 5th Gear March 15, 2007 Author Share March 15, 2007 no lah.I was like kind of stunt that the car still running after the driver left the car.after a while,the car then shut down.Is it a new technology or people fit it for "sei bin" purposes? ↡ Advertisement Link to post Share on other sites More sharing options...
Robin 4th Gear March 16, 2007 Share March 16, 2007 like other have mentioned its usually for TC cars to cool down the turbocharger before shutting down Link to post Share on other sites More sharing options...
Liping24 Neutral Newbie March 16, 2007 Share March 16, 2007 I know many european cars like renault/seat have the radiator fan 'running' after the engine is off feature. Although the engine is not running, the radiator is still running to cool down the hot coolent. I wonder why? Link to post Share on other sites More sharing options...
Robin 4th Gear March 16, 2007 Share March 16, 2007 they this feature meh? probably to cool down the engine ... Link to post Share on other sites More sharing options...
Watwheels Supersonic March 16, 2007 Share March 16, 2007 Engine not running but fan running?? Never heard of such thing cos it'll most likely drain your battery flat. Link to post Share on other sites More sharing options...
Dwoon 1st Gear March 16, 2007 Share March 16, 2007 Errr.... actually, my jap car will also have the radiator fan running if I shut off engine..... but provided I leave the electricals activated lah. It'll only do so if the engine temp is above 95 deg for my case. Once reach 90 deg, it'll stop. Link to post Share on other sites More sharing options...
Darkness3006 Neutral Newbie March 18, 2007 Share March 18, 2007 Turbo timers are kinda cool. Most foreigners seem to be fascinated by it. Dunno why.... ONly Asia has such device? Link to post Share on other sites More sharing options...
Imamiah Clutched March 18, 2007 Share March 18, 2007 dun install, no use one lah Link to post Share on other sites More sharing options...
Yc86 Clutched March 18, 2007 Share March 18, 2007 (edited) should be a turbo timer ba.. Can set auto or preset countdown mode (not sure how auto mode works exactly thou) When u turn off the ignition, the display will countdown from ur preset time, and switch off everything upon 0. Its basically just a delay switch, can be override by holding the button when u need to shutdown immediately. Useful for when you need to keep the engine n aircon running (eg. for a quick stop at 7-11 or petrol station), you can take your keys with u and lock the car to prevent car theft Can be used for NA or turbo, thou i rem reading for turbo nowadays, a cool down is not required? also depends on how hard you drive prior to shutdown. Edited March 18, 2007 by Yc86 Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear March 19, 2007 Share March 19, 2007 Oops! maybe i should say "Most Turbo cars come with it then" You mean no cars come with, just uninformed ppl who install them. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear March 19, 2007 Share March 19, 2007 Anyone can enlighten on this technology?I saw a Evo and lancer ralliart turbo having such technology?Is it OEM or can be installed somewhere? Is it the turbo timer?? Actually it'll help to further cool the TC and engine at idling rpm. U set the timer to delay the shut down. If your car is N.A., it is a waste of $$ and fuel. Its a waste of $$$ even with a TC car. light footed driving for the last 5mins is all you need. All the timer does is encourage heatsoak. ↡ Advertisement Link to post Share on other sites More sharing options...
Teck Lee LRT station remains shut for 10 over years
Bad Auto Dealer - Salesman!
