Passion 5th Gear March 15, 2007 Share March 15, 2007 Anyone can enlighten on this technology?I saw a Evo and lancer ralliart turbo having such technology?Is it OEM or can be installed somewhere? ↡ Advertisement Link to post Share on other sites More sharing options...
Try_conti 2nd Gear March 15, 2007 Share March 15, 2007 what do you mean auto engine shut off ? do you mean that you saw the driver shut off the ignition, remove the car keys but the engine still runs for a certain period before it shuts off ? If so, its a delay to let the turbo spin down because shutting off engine will cut off coolant circulation. Bad for turbos ..... Link to post Share on other sites More sharing options...
Bluemice 2nd Gear March 15, 2007 Share March 15, 2007 aka turbo-timer mice Link to post Share on other sites More sharing options...
Passion 5th Gear March 15, 2007 Author Share March 15, 2007 is it?so the engine still consider running or shut down? Link to post Share on other sites More sharing options...
Boyboy 1st Gear March 15, 2007 Share March 15, 2007 running. when the preset time is up, the engine will shut down Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 15, 2007 Share March 15, 2007 Any car can do that, juz install a turbo timer. You set a countdown time, take out your keys, activate your alarm and walk away. The engine will continue to run for the time that you set and after that it will shut off by itself. Hell, I even installed one for my Hilux. Any car can install it but frankly, it's a waste of money for those without turbo. Link to post Share on other sites More sharing options...
Apollo 1st Gear March 15, 2007 Share March 15, 2007 if u want is apexi turbo timer. Link to post Share on other sites More sharing options...
Nazaki Clutched March 15, 2007 Share March 15, 2007 haha, like very cool ma. Walk off when engine is still running. but true, a waste of $$. Am wondering, how u pump petrol? must wait for the timer to stop before u pump? or is there a button to stop it straigt away? Link to post Share on other sites More sharing options...
Wish1719 1st Gear March 15, 2007 Share March 15, 2007 Anyone can enlighten on this technology?I saw a Evo and lancer ralliart turbo having such technology?Is it OEM or can be installed somewhere? All turbo car comes with turbo timer, of which after the driver had switched off, the timer will run for a couple of mins before shuting off. quite normal, thing is for the engine to run down before totally shut off. Link to post Share on other sites More sharing options...
Nazaki Clutched March 15, 2007 Share March 15, 2007 I don't think all turbo cars come with it.. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 15, 2007 Share March 15, 2007 Not all turbo cars come with it. Link to post Share on other sites More sharing options...
Wish1719 1st Gear March 15, 2007 Share March 15, 2007 Oops! maybe i should say "Most Turbo cars come with it then" Link to post Share on other sites More sharing options...
Turbine Neutral Newbie March 15, 2007 Share March 15, 2007 (edited) [reply] Am wondering, how u pump petrol? must wait for the timer to stop before u pump? or is there a button to stop it straigt away? they just pump the petrol w/o waiting but you can deactivate the turbo timer. Edited March 15, 2007 by Turbine Link to post Share on other sites More sharing options...
Jho0001 Neutral Newbie March 15, 2007 Share March 15, 2007 Do not believe it standard fitting. Most Evo's, STI's etc that have them are all aftermarket fitting....Apexi usually around sS100 - 130 bucks inc fitting. I believ the reason why they are used is to give a chance for the turbo to cool down thus prolonging the life of it, especially after hard driving. On my car..if the handbrake is released the Turbo timer does not activate (useful when i fill up with fuel). Waste of time unless you own a turbo car. Link to post Share on other sites More sharing options...
Refeer Neutral Newbie March 15, 2007 Share March 15, 2007 For some reason, when I installed the APEXI, the mechanic say I have to rev the car a little to push up the RPM before switching off the engine, otherwise the turbotimer will not keep the engine running. Something about my car's idling RPM being too low. Any ideas? Link to post Share on other sites More sharing options...
Watwheels Supersonic March 15, 2007 Share March 15, 2007 Anyone can enlighten on this technology?I saw a Evo and lancer ralliart turbo having such technology?Is it OEM or can be installed somewhere? Is it the turbo timer?? Actually it'll help to further cool the TC and engine at idling rpm. U set the timer to delay the shut down. If your car is N.A., it is a waste of $$ and fuel. Link to post Share on other sites More sharing options...
Watwheels Supersonic March 15, 2007 Share March 15, 2007 Your mechanic scared not enough fuel to keep the engne idling. By doing this is to prevent the engine from stalling prematurely. Link to post Share on other sites More sharing options...
Robin 4th Gear March 15, 2007 Share March 15, 2007 got OEM u interested arh... ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
